Question about Sony Cyber-shot DSC-M2 Digital Camera
My camera says "Turn the power off and on again" and the lens doesnt open. what will i do? please help. :(
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 11, 2011
jackboy
  • 2985 Answers
SOURCE: dark screen
Two reason for the screen to be dark
1. If you can see 'shadow' images on the screen, this implys the backlight tube or the inverter circuit has blown.
2 If No images show up at all then this is a mainboard failure
This is assuming the batteries are ingood condition and the camera powers up..
Check Vivitar support for repair/replacement options.
If under ewarranty it will be replaced
If out of warranty - New Camera Time
Posted on Dec 31, 2007
bobint17
  • 270 Answers
SOURCE: please turn camera off & then on again
off the camera again and try to open the menu and try to reset it .if the problem persist send it to the survice center
Posted on Feb 03, 2009
pauman
  • 248 Answers
SOURCE: casio ex-z77/ lens error
you might have pushed the lens into the barrel. small lens barrel has 3 metal pins that ride inside the larger lens barrel as it twists. Pushing it sometimes cracks the plastic holding these 3 pins in. one way to fix it is to carefully disassemble the entire lens barrel. be careful...sometimes a part just snaps, or is already snapped. The easiest way would be to replace the lens assembly with a good one you can get from another camera like this. There are no spare parts for cams like this so you can try to get another cam that has a different damage other than the lens barrel.
Posted on Jul 05, 2009
SOURCE: camera lens keeps opening and closing and message
I followed the other people's suggestions with the compressed air and shaking the camera. I also, turned the lens a little to the left and the camera works perfectly. Thanks, again for everyones help.
Posted on Oct 11, 2009
SOURCE: Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Posted on Mar 02, 2010
My Benq DC 3410 suddenly doesnt turn on but seemed to be in a semi-open mode..Its screen has a low light but doesnt charge anymore.Any idea how i might open it so i can completely turn it of. Your help...
Hello
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
Sep 15, 2010 | BenQ DC3410 Digital Camera
My lens to my camera wont close when it is turned off,it doesnt even move when it is on. The screen just tells me to turn it off and on again, but that hasn't worked. Please help!!
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
Aug 02, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Please turn camera off & then on again
Feb 03, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Says lens error!!!!!
The best solution is to take it to Best Buy and have them look at it. The Kodak camera could still be under warranty.
Jun 30, 2008 | Kodak Easyshare M753 Digital Camera
When i turn on my camera it says Turn the power off and on again
Hey, my camera the dsc- w80 did the same thing. When I turned it on, the lens opened 3-4 times and then it said "turn the power off and on again".
When the lens opened an closed, I pulled on it with my fingers and twisted it. I kept doing that: Turned the camera on and off, kept pulling and twisting the lens and now my camera works again!
May 15, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Turn the power on and off again
I fixed this issue with my Sony Cybershot by gently (carefully) hitting the camera 3 times against a carpeted bench with the lens retracted and the camera turned off. It seems the lens gears were stuck. Now the camera works fine again.
Apr 23, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
"Turn the power off and on again" error message
You probably have a defective lens assy. When turned on lens has to move to certain position but because of broken gear or some mechanical problem it can not perform that funtion. Remedy is to disassemble the lens assy and repair the problem. Many time the whole lens assy are replace to repair the problem. normal repair charges for this kind problem is $125-200 in US depending on parts use.
Mar 19, 2007 | Sony Cyber-Shot DSC-T33 Digital Camera
Lens stuck
If the lens is not coming out, its stuck, or it wont completely open or close, that is the lens assembly, that needs to be repaired. You need to take it to somebody, that can either repair it or replace it for you. There is nothing that can be done, other than that......
Jan 24, 2007 | Sony Cyber-Shot DSC-P8 Digital Camera
Sony Cyber-shot DSC-M2 Digital Camera Logo
23 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
