CAN YOU FIND ME REMOTE CONTROL CODE FOR WEG TV
Guys I need help for my Hyundai TV...i need help code I used chunghop rm-133E
Hyundai Universal Remote Tv Full remote control with ...
tv.manualsonline.com > ... > Hyundai Universal Remote
Hyundai Tv Full remote control with exclusive Dynamic Database Technology ... replaced, the remote control will stop ... is preprogrammed with codes for the.
Universal Remote Control Remote Control Code hyundai tv ...
www.fixya.com > ... > Universal Remote Control Remote Control
code for Hyundai Q320 TV What is the universal 3-digit remote code for ... Hyundai TV Code hi! my hyundai TV remote is no longer working so i bought a ...
hyundai tv remote code Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Jan 11, 2016 | Televison & Video
Tip
DirecTV Remote Control Code Entry To enter a control code for your TV using...
To enter a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Locate the 5-digit code for your TV. (See DirecTV Remote Control Code List, page 14.)
  3. Slide the MODE switch to the TV position.
  4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
  6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 4 and 5, trying each code for your brand until you find the correct code.
You have programmed your DirecTV remote control for your LCD TV.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Search
on Jun 10, 2010 | Televison & Video
Tip
DirecTV Remote Control Code Search Tosearch for a control code for your TV...
Tosearch for a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Slide the MODE switch to the TV position.
  3. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  4. Enter 9-9-1 followed by 1:
  5. Aim the remote at your TV and press the PWR key once.
  6. Point the remote at the TV or component and press
    CHAN ^. Repeatedly press CHAN ^ until the TV turns off.
  7. When the TV turns off, press and release the SELECT key.
on Jun 10, 2010 | Universal Remote Control DIRECTV Universal...
Looking for a sky remote control code for beko.
Hello
The three digit Sky remote code for Beco TV are:
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
Aug 12, 2011 | Televison & Video
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
Tip
  1. Turn on the TV.
Direct tv remote to visio tv
I can help you with your Vizio TV & DirecTV remote control.
This is a list of all the Vizio TV control codes for DIrecTV remote controls:
11758, 10864, 10885, 11499, & 11756.
Complete instructions on entering DirecTV remote control codes are here.
I hope that helps.
DirecTV Remote Control Onscreen Setup
May 13, 2010 | Universal Remote Control DIRECTV Universal...
I lost my remote and need to switch the tv so I can get Directv - how can I do this without my remote
I can help you with your Toshiba TV & DirecTV remote control.
To get your TV setup so that you can view your DirecTV on it, I recommend you program your DirecTV remote to control your TV and then use the DirecTV remote to change the input of your TV to view the DirecTV programming.
You can choose between searching for the control code and
entering a code from the Toshiba TV list.
This is a list of all the Toshiba TV control codes for DIrecTV remote controls:
11524, 10154, 10156, 11256,
10060, 12006, 11945, 11936,
11935, 11918, 11704, 11656,
11635, 11369, 11356, 11343,
11325, 11306, 11156, 10845,
10832, 10822, 10650, 10149,
10148, 10036, 11971
I hope that helps.
Apr 23, 2010 | Toshiba 24AF42 24" TV
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Televison & Video Logo
311 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
