Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Running lights My 03 softail running lights, beside the headlights wont power on. I have checked power to the switch and there is none. Looks like it comes from the head light? Could the ballest inside the headlight housing cause this?
THERE THE POWER I BELIEVE COMES THROUGH THE LOW BEAM SWITCH ON THE HANDLE BARS........I AM HAVING A PROBLEM WITH THE DRIVING LIGHTS STAYING ON WHEN I SWITCH ON MY HEADLIGHT MODULATOR.............MODULATOR USES THE HIGH BEAM SECTION AND YOU MUST HAVE HIGH BEAM ON TO WORK.............THIS CUTS OFF THE RUNNING LIGHTS........AM ATTEMPTING TO CORRECT THIS PROBLEM..
Posted on Jun 17, 2008
My headlight goes dim and then bright on my 2009 Harley softail custom
Hi, Anonymous if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
Harley Davidson Softail series Service Manual
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
Jul 07, 2016 | 2009 Harley Davidson FXSTC Softail Custom
The 97 Bonneville. That has. The twilight sentinel feature. The dash. Or cluster does not work none of the int light works and the fog lamp all fuses are goods
Twilight feature is used by the BCM to turn on the headlights when light levels diminish. Dash, cluster lighting is controlled by a rheostat near the headlight switch. The rheostat is rolled up for brighter lights. If this does not work the interior module may have burned out or the rheostat may be bad. If interior lights come on when rheostat is rolled fully up it most likely is OK. Interior lighting module is located above the headlight switch beside the cluster on the left side.
Mar 06, 2016 | Cars & Trucks
If the break lights in my 1986 c corvette works but the tail lights do not, what could be the cause
Blown fuse ,bad headlight switch,or wiring issue.
the tail lights have there own fuse and are powered through headlight switch. Do the front running lights come on? If none of them work, switch could be bad if front work and rears dont, check bulbs and power to them when lights are on
Mar 17, 2015 | Cars & Trucks
I replaced a new headlight switch on my 2002 pt cruiser and the lights wont come on
Check fuses! Make sure the plug is secure at back of switch!
Jan 01, 2015 | Cars & Trucks
Running lights on miata
check all ground wires especially going from frame to body, making sure there is no rust there. check for power going to fuse ( both sides ) if there is no power to fuse, check headlight switch ,if no power there, check power at all fusible links. If you have power to the switch and not to the fuse check for a broken wire from there to switch , if none broken replace headlight switch.
Apr 18, 2013 | Cars & Trucks
03 kia sorento running lights and interior light wont work
if you can get your hands on a wiring diagram for head light switch figure out wich is power in and check with multi meter to see how much voltage is going in and check for power out there should also be fuses for both headlights also should be a relay
Mar 27, 2012 | Kia Sorento Cars & Trucks
I have just repaired my taillights and brakes by replacing the ground wire. Now all of a sudden I no longer have high or low headlights. However, when I pull back on the beam selector switch and hold it...
Check power coming from headlight switch if none when on replace headlight switch, if there is power coming from it, replace your high/low beam switch.
Feb 19, 2011 | 1985 Mercury Grand Marquis
2005 vtx 1300 wont start and has no headlight
Check regulator...this powers all running light tail lights etc.
Sep 01, 2009 | 2004 Honda VTX 1300 Retro
Dashboard lights
check the wiring cable and the internal signal cable
Jan 10, 2009 | 1996 Nissan Sentra
98 Sierra 3/4ton 4x4 turbo wont start
When you turn the key to on, the dashlights have to come on and go off when you turn it to the starting position. Make sure you have a good battery first. No dash lights indicate a bad ignition switch. Check all fuses and relays. But I am pretty sure it is the ignition switch.
Dec 05, 2008 | 2003 GMC Sierra
Lands Phones Logo
159 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
