Question about Hitachi 51SWX20B 51" Rear Projection Television
Hitachi 51SWX20B projection TV has no picture or sound
The Remote doesnot turn on or off the TV anymore. I had to do it via TV panel. But in any case there is no picture or sound. I tried many simple troubleshooting like switching off and on many times, changing the power from surge protector to wall outlet, waiting before turning on. But nothing has worked. What can I do? Please help. If it needs change of fuse, do i have to call technician or is it self serviceable?
  • 975 Answers
First lets check the remote to see if its working , with a digital camera facing the front end of remote (where THE EYE is) look thru the camera screen while pressing any button from remote , you should be able to see FLASHING LIGHT coming from the remote. SECOND about your TV , better off to have unit check by an authorized tech . hope this helps
Posted on Apr 27, 2008
My Model TV # is 51swx20B. Two days ago the picture started having a lot of green in it and no blue. What is the repair needed.
Do adjustments on focus block. Will have to open front panel access door, focus block blue will be on left, green will be on top. Top screen bottom focus. Turn clockwise to increase, counter clockwise to decrease brightness. Turn the color all the way down on menu where it's pure black and white and make adjustments for perfect black and white picture, then when you adjust color, it will be perfect.
Aug 09, 2011 | Hitachi 51SWX20B 51" Rear Projection...
My HITACHI 51SWX20B was working fine before dinner. It was turned off for about an hour or so and when we turn it back on the picture was black and neither of the remotes worked (they wont' even turn the...
If no remote function, unplug set for a minute and plug back in; if not the problem something is wrong in either power supply or sweep circuit of set--
DOES POWER LIGHT COME ON AND STAY ON?
sd tech
Sep 20, 2010 | Hitachi 51SWX20B 51" Rear Projection...
I have a 1988 Hitachi Model CT5081K; Serial W8J000983. The problem is the TV can be turned-on via remote control but no PICTURE or SOUND.\r\nAre the fuses and/or bulbs need to be replaced?
I had a TV like that and it did the same thing. There are three Rear Projection lights in the back..once they are done so is the rest of the TV. I had a tech look at mine and they don't fix them anymore. Sorry.
Aug 28, 2010 | Hitachi Televison & Video
I have a Hitachi 51SWX20B. I experienced a power loss and according to the local power company a surge due to a transformer being hit. After power was restored, the TV turns on (red indicator light on...
Unplug,replug the tv back about an hour later.Let the tv to get out of it protection mode,might work again.Not,come back give the new problems,help u some more.
Jun 15, 2010 | Hitachi 51SWX20B 51" Rear Projection...
I used Hitachi TV convergence repair kit to fix tv
Check the Components received are compatible with manufacturers numbers or if they are generic the voltage,ohmage,ampage and resistance must be almost the same.
Using a multimeter take out and test each individual components.They could have sent you faulty parts.
Ensure you follow the instructions very carefully when soldering them onto the board.
Hope this helps you
Mar 26, 2010 | Hitachi 51SWX20B 51" Rear Projection...
The convergence going bad again on my Hitachi 51swx20b
Sounds like loose solder on the chips. Either that or they are failing. You can save money next time by doing it yourself with a kit from www.TvRepairKits.com
Jan 10, 2010 | Hitachi 51SWX20B 51" Rear Projection...
51swx20b manual
Click Hitachi Support to download instruction manual of 51SWX20B TV.
Apr 03, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Old Projection telvision on the fritz
you need to change the CONVERGENCE ICs , if you cant do it then it needs to be serviced by a HITACHI authorize service shop , hope this helps AJ
May 27, 2008 | Hitachi 51SWX20B 51" Rear Projection...
No Picture No Sound
were the colors looking 3D before the set shut down? If so chances are its the convergence amp ICs and thats what has shut your set down. Let me know if you need anymore info.
Mar 28, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Help with project
Can you post a picture of what the picture looks like, and do you have the service manual for this model?
Mar 12, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 51SWX20B 51" Rear Projection Television Logo
126 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
