Question about Zanussi ZWF1430W Front Load Washer
Zanussi washing machine 1432 w - wouldn't spin so cleaned out filter and sump - found a load of coins and nails. Put it all back together but now all the lights keep flashing and nothing else happens. Tried the sequencing, resetting etc - nada. I know this is a simple resetting problem - help me please!!!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Press and hold the start/pause button and the reset button simultaneously for more than 30 seconds and when the washer start beeping release all these buttons. Please do accept the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 08, 2010
Is there a filter that needs to be cleaned in my Indesit washer? I'm not sure what the model number is.
there is a filter that has to be cleaned, its under the machine, remove the panel at the back of the machine down at the bottom, it will be infront of you when the cover is removed. you will see a large clip holding the sump to the drum, removing this clip and the sump can now be cleaned out of coins,buttons etc.
Feb 02, 2010 | Indesit W 123 Front Load Washer
Will not spin dry clothes.
My washing machine doesn't work, alarm on spin function
Mar 13, 2009 | Frigidaire Washing Machines
WD860 Spitting out water & noisy
The spitting water problem is often caused by the filter assembly in the sump pipe just before the pump getting blocked. This easlily clogs up but is not easy to clean out. Hotpoint do not fit an easy access pump filter to this model but they place the filter into the black rubber pipe that runs from the drum to the pump. When this clogged up the machine empties too slowly and starts to spin when too much water is left in the drum, this forces water up and out of the soap tray. There is a minor design fault as the pressure sensor is attached to the same sump pipe and even when the filter is blocked the suction from pump still drops the pressure on the sensor. So you end up with a drum that has not emptied out enough water but still goes on to spin . The result is niagra falls from the soap tray.
To rectify this you will need to pull the machine out, unplug it, remove the rear lower back panel and dismatle the black sump to pump pipe. Once this is clear you will find the machine runs fine again. Its not an easy jobs and water spills everywear but if you are a keen DIY'r you should be OK. I just cleared mine out and found coins, shirt collar inserts and a large washing instruction label in the sump pipe. Now its clear and the machine has stopped spilling water from the soap dispenser.
As for the noise on spin, check all concrete is firmly fixed to the drum as they work loose
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Coin trapped between rotating drum and casing
Get underneath the machine and remove the big black house coming directly out of the drum,this is held in place with either a screw tie or pinch type tie.
Put the machine back level and see if the coins drop out (they should) or have a feel around inside the drum.
Please make sure machine is unplugged and empty before carrying out this procedure.
Some water will come out of hose.
Nov 19, 2008 | Zanussi ZWF1430W Front Load Washer
Won't drain
dip as much water as possible from tub..remove bottom panel remove clean out port on pump clean and reinstall
Aug 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi zwf 1432 front loader
check the filter down on the right and cleane it
May 28, 2008 | Zanussi ZWF1430W Front Load Washer
Washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Dec 10, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
43 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
