Question about Samsung ML-2510 Laser Printer
Constant paper jam
My ML-2510 is less than a year old and jams every time on the second page. All I do is open and close the toner drawer and it prints the next page before the paper jam light comes on again. Any adivce?
  • Anonymous Apr 29, 2008
    I have the same problem.
  • samsung2510 Jun 08, 2008
    I have the same problem and am at a loss on what to do.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
My dads ML-2510 always jammed on the second page. Even if we print just 1 page it would feed second page in right after first and cause a jam condition. When I looked inside where the paper feeds in with flashlight, i could see that the paper lifter keeps moving up and down through out the print cycle. This is not supposed to happen, Its only supposed to lift up once per page. To make long story short, it was the solenoid sticking open. I replaced it and now it works.
Pretty major dis assembly. Get your hands on Service Manual . I bought pdf for $2.50 on ebay. Also take pictures at each step so you can put back correctly including wiring. bought part on www.samsungparts.com Total cost including shipping was $22.00
Posted on Oct 05, 2013
I had the same problem but was using a replacement toner cartridge made by PRINK. When I purchased a true Samung toner cartridge the problem went away.
Also, try changing the paper for a different make, some are "stiffer" than others and cause a jam.
Posted on Jul 29, 2008
    Problem Solver:
  • 12 Answers
How do you put the paper in?It must either be the paper or the paper feed system.
Posted on May 19, 2008
How do I get the paper jam out of the Samsung ml-2510
if it is a whole piece of paper open the toner door and take the toner out and that should give U access to the jammed sheet. If it is just little pieces of paper get as many as possible and them push a piece of card stock through to clear out the rest
Feb 03, 2015 | Samsung ML-2510 Laser Printer
If the paper is jam in the printer
Without more specific information on where the jam is occurring in the printer difficult to provide a specific solution.
However, if you are having problems with paper jams you may find it helpful to work through the interactive troubleshooting guide found on this page under the Troubleshooting tab:
http://www.samsung.com/sg/consumer/pc-peripherals-printer/printer-multifunction/mono-laser-printer/ML-2510/XSS/index.idx?pagetype=prd_detail&tab=support
Under the FAQs tab on the same page you will find 3 guides for avoiding paper jams and 1 guide for clearing paper jams.
Trust this is helpful. Please vote. Thank you. :)
Dec 21, 2010 | Samsung ML-2510 Laser Printer
Om line error red light is on
Try this solution: Check for paper jams when the "Error" LED lights red. Open and close the front cover. The paper may automatically be ejected from the printer. Gently pull any remaining jammed paper straight out. Open the front cover. Pull the toner cartridge out. Pull out any internal paper jams.
Nov 21, 2010 | Samsung ML-2510 Laser Printer
Page prints, but jams, samsung ml 2510 and toner is smeared over page
Your toner might be faulty, also remove toner and clean place with a cloth. Look to see inside if their are any loose pieces of paper in machine.
Feb 21, 2010 | Samsung ML-2510 Laser Printer
Red light stays on, and nothing prints. won't recogonize paper in tray???
Depending on how long you have had this , it might be time for a new one. If its still under warranty, rather send it back as it could be a problem inside.
First do a couple of test.
Turn the Printer off and back on?
Reinstall the software for the printer?
Paper **** under the toner drum? Dont touch the green drum!!!
Pull toner out and reinsert
On the top side above the toner were the paper feed's after printing. Is there a paper jam?
Did you replace the toner with a "compatible" toner? If so the printer does not recognize the cartridge thus another reason for the red light?
if you have had your ML 2510 for longer than 2 years and 4 Toners. This is a good time to invest in another ML 2510 Printer. They are cheap and dont break up the bank's money printer to get.
I hope you find help with this.
AJ
Dec 07, 2009 | Samsung ML-2510 Laser Printer
My printer is stuck and it is a ML-2510 the paper is jammed how i get it out?
Do you know where the paper is jammed? After you have removed it, you need to open the front panel and close it again to reset the printer and allow your document to print.
Nov 13, 2009 | Samsung ML-2510 Laser Printer
Have you found a solution to the Samsung ml-2510 printer red error light staying problem?
There are a couple of reasons why this happen. A paper jam could have occurred. The cover might be open, try closing the
cover. There might be no paper in the tray, load paper in the tray. The toner cartridge is not installed. The printer has stopped printing due to a major error (you need to contact your manufacture for this).
Nov 11, 2009 | Samsung ML-2510 Laser Printer
Paper jams after printing and will not exit top output tray
sounds like the gear drive assy faulty.take it back to where you purchased.Samsung should cover under warranty.
May 25, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Logo
712 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
