Question about Emerson InSinkErator W154 Water Heater
I BOUGHT A USED ONE AND i NEED TO KNOW HOW THE WIRING DIAGRAM IS
  • rdmorriso298 Aug 10, 2010
    tHAT IS NOT THE WATER HEATER i BOUGHT. i BOUGHT AN ASDV-6SR WATERHEATER THAT WAS MADE BY OR MADE FOR AMERICAN STANDARD. it is a recreational vehicle waterheater which has the cabability of remote liting from inside the cvehicle. That is the wiring I need to see. Ron
    President:
  • 2,030 Answers
Here ya go.....
http://www.insinkerator.com/pdf/POU_ICU.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 08, 2010
  • 1 more comment
  • Sean Wright
    Sean Wright Aug 10, 2010
    Please look at your question, and the topic area under which you listed it. You listed it as an Emerson InSinkErator Heater. That is why I supplied you with what I did. You never said it was a different brand.
  • Sean Wright
    Can you please give the correct Brand and MODEL # of your unit.
  • rdmorriso298 Aug 11, 2010
    I never heard of an insinkarator. The only one I have is an ASDV-6SR made for or by american standard
Don't need to talk to an expert just need to see wiring diagram for a LAKQTV-22 Heater.
Request the wiring diagram directly from the manufacturer/distributor.
Jan 15, 2018 | Water Heaters
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
I have bought a used Rinnai R94LS natural gas tankless water heater and need to know which thermostat to buy for it? I have bought a used Rinnai R94LS natural gas tankless water heater and need to know...
Plumbcentre have a parts desk for gas appliances.
most appliances are available to view in an exploded view with clear identification of parts.
However when it comes to gas, I strongly advise on using a GASSAFE engineer
Nov 18, 2014 | Water Heaters
Wiring diagram for EZ-GO Marathon 36 volt golf cart
Excellent......asking for a Golf Cart wiring diagram in a Water Heater posting board....
Works for me
I have a Westinghouse Nuclear Reactor I bought used from the USN. Can you tell me where I buy the Heavy Water for it????? Kroger? Safeway? Whole Foods?
Oct 20, 2014 | Water Heaters
I need a wiring diagram for a ge 240 vac timer please
GE sells several timers rated for 240Volts.
Including the 15307 timer made by Tork, rated 208-277Volts, 40 amp, 60 Hz
Copy following link for wiring GE 240Volt timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 18, 2012 | GE 15307 240 VAC 24-Hour Outdoor...
Wiring
The new thermostat (I assume you must be changing one) will have several possible scenarios. If you have two elements and thermostats you look for the diagram that says two elements working NON-SIMULTANEOUSLY. In other words the top element heats until the thermostat is satisfied and then, and only then the power is sent to the bottom thermostat. The wiring diagram will have the numbers and colors of the wires for everything in the heater except your feed wires. Those colors don't really matter much. You will have three conductors--two hot wires and (likely) a bare ground wire.
Hope this helps.
Mike
Apr 05, 2009 | Water Heaters
Emerson InSinkErator W154 Water Heater Logo
70 people viewed this question
Top Emerson Water Heaters Experts
Gil Shultz
ray gallant
Are you an Emerson Water Heater Expert? Answer questions, earn points and help others
