-   I have a GE XL44 Gas self-cleaning oven. The burners, broiler, and clock work, but the oven does not. I do not know what is wrong.-   biggreyhorse
Apr 24, 2009
-   I tried to replace my safety valve with the correct part, from a 3rd party supplier, and experienced leaks around the supply tube.
Should I replace the Supply tube as well, or is there something wrong with my replacement part?
I'm on a limited budget, and would rather repair than replace, but parts aren't cheap either... -   Guest
Apr 10, 2009
-   Same problem here. No Oven but burners work. I took the oven apart, there is not much to these things. I will try the saftey valve....
-   Guest
Mar 14, 2009
-   My broiler burner works but the oven does not????
-   rsy1209
Jan 19, 2009
-   I also have this problem. Nice to know I'm not alone...well, kinda nice I guess. We plan to have somebody come look at it. Hopefully we can find the solution so I can add it here... -   codaham
The problem is the saftey valve located at the bottom of the stove i have the same problem i took it out once and beat it this freed it up for a while but it eventually froze again, guess im going to have to replace it part number for mine is wb19k14
I need a new oven knob to fit a wb2710140 controller. This controller has a smaller shaft than the...
(More)
I need a new oven knob to fit a wb2710140 controller. This controller has a smaller shaft than the original wb11k65 controller that it replaces on GE ranges. The old knob does not fit the new controller.
Have KitchenAid Superba convection free standing range. Just got F5:E3 error code and oven will not...
(More)
Have KitchenAid Superba convection free standing range. Just got F5:E3 error code and oven will not work. What do the codes mean?
