Question about Gaggia Baby Espresso Machine
Just wanted to know when I make a coffee the coffee drips in slow dropplets from the handle rather than pours out,I have had the machine serviced and they replaced the pump but its still struggles.I`ve never experianced this problem before,could they have put the wrong pump????
  • Gaggia Master
  • 1,711 Answers
How do you hear the sound of the pump, the same loud as before or more silent.
Sometimes the new pumps need to work for while in order to get maximum pressure and sound is loud.
One other thing when you istall a new vibrating pump you must take care not tight the out way too much since this can block the outway of the pump thus you have the problem you have describe.
Since you have the machine serviced then you deserve a second visit for checking the machine.
Good luck and thank you for you positive voding
Posted on Aug 10, 2010
Coffee dripping out of spouts instead of pouring.
You have not included the make and model of the coffee maker.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 15, 2014 | Coffee Makers & Espresso Machines
Why is there coffee on the burner, after coffee brews?
The flow control valve on the strainer basket (where the coffee pours into the pot) is a less-than-stellar device. While adequate to prevent a flow of coffee when you pull out the pot, it will still retain a few drops which slowly drip onto the warming plate while you are pouring a cup. It may even allow a slow, continuous drip, especially if coffee grounds find their way past the filter.
Keep a damp cloth or paper towel near the coffeemaker while it is on. Just before returning the pot to the plate, give it a quick wipe.
Oct 05, 2014 | Mr. Coffee Coffee Makers & Espresso...
My Bunn has a slow drip. Model GRX-B. Have cleaned the disc sprayer and pushed the spring up in the hole. What else can I do? It used to drip a lot faster.
How old is the machine? If you have cleaned it and delimed the machine and it still is dripping slow, the machine may need to be replaced. Please call service at 800-352-2866 with the model and date code.
Oct 06, 2010 | Bunn 10 Cup Home Coffee Brewer
Our Bunn coffee maker has worked great for two years, but all of a sudden when we go to make coffee, the water pours out FAST and not the normal slow drip and the coffee is weak weak weak...we have cleaned...
It sounds like you are missing your sprayhead. If you will call Customer Service at 800-352-2866 with the model we will be able to send you out a new sprayhead.
Aug 18, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Coffee starts dripping down before I can get the water all poured in and the pot on the warmer, causing a mess.
This is common with bunn coffee makers, if you are not fast enough, coffee starts dripping. The only solution I found is to use a water pitcher, first fill coffee pot to cup mark you are using, then pour into pitcher, put pot back on machine, then pour in water. You can mark a line on picture, so you know where to fill to each time.
Jul 15, 2010 | Bunn NHB Coffee Maker
Doesn't drip through. Don't know where the coffee water went to?
When setting up a new machine, it requires 2 full decanters of water to be poured into the machine. After you have done this, then you plug the machine in and turn on the vacation switch on the side of the machine. After 15 min, then you will pour in 4-10 cups of water and it will force out the hot water from the tank in the back and brew the coffee. If this doesn't correct the problem, then please call customer service with the model and date code.
Sep 11, 2009 | Bunn NHB Coffee Maker
Saeco royal
Try to set the grinder to grind coarser, make 2-3 cup of coffee to get coffee with the new settings.
/Mirran
Aug 25, 2008 | Saeco Royal Digital Plus Coffee...
Slow grinding and coffee flow
Your machine has a grinder assembly, a Very expensive part to replace in its entirety. What is happening is that the conical burr set, consisting of the two metal-to-metal grinding surfaces that actually grind the beans, is now worn. Instead of grinding the beans as it once did, resulting in the proper coarseness to make perfect coffee, it is now pulverizing them instead, making the shot too fine and powdery. The result is a long, slow drip-drip-drip instead of the classic crema-rich stream you miss so much.
The cure for this of course, is to replace the conical burr set. If you're a geeky type and can handle a regular screwdriver and a finer precision phillips head, and you can get your hands on a #10 Torx drive screwdriver as well to replace the lower half of the set, the parts are available for around $42 from partsguru.com. If this is beyond your skill-set, it will cost you $95 for a diagnostic (preliminary "bend-you-over" fee), then they will charge you for the entire grider-assembly brand new, approximately $175, plus labor calculated at a Bazillion-dollars per hour. I was quoted a total around $400, with a few days turnaround time... then decided to tackle the job myself, and found it kinda fun. But then I'm a geek.
Please feel free to email me for the step-by-step procedure. It's kinda techy, but most people with the "guy-gene" in their DNA can handle it... especially at a saving of over $300!
Dec 07, 2007 | Gaggia Syncrony Compact Coffee...
Gaggia Baby Espresso Machine Logo
328 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
