Question about LaCie (300770) 250 GB Hard Drive
Hard drive thinks it is full
According to Finder my external HD should have under 50GB. But the 250 GB drive thinks it is almost full. Don't get it.
  • ijkuhn Apr 27, 2008
    That is how I know it is 50GB and nowhere near 250. Thanks for trying
    But.... When I try to back up my 10gb iTunes library the external says there is not enough space. That is the problem. I was probably not very clear.
    Genius:
  • 3,587 Answers
Well..those ext drives can get confused..only way to assess this is to open the drive in the finder, and see how large the folders are..
Posted on Apr 27, 2008
  • Patrick Michaels
    Patrick Michaels Apr 27, 2008
    well..then you already have your answer, don't you?
Lost data
Easy Drive Data recovery would of been my first pick!
Oct 25, 2012 | Western Digital 250GB MyBook External USB...
How to I reallocate my 500 gb external hard drive so I have more space for my laptop - I have 250+GB space avilable for my destop but I am getting "disk full" for the laptop.
you should be able to connect the external hard drive to your laptop and the drive should show up under my computer. Then just drag and drop or cut and paste any files you want to move to the external hard drive.
hope this helps.
May 21, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Beyond Micro BMMDU2 250 GB external hard drive not working
It is highly unlikely that it will work. A circuit board from the same make and model hard drive would be a better choice, but I think a fire damaged hard drive would not work with a functioning circuit board. It depends upon how much heat the hard drive was subject to.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their services. Depending upon how valuable your data is, I suggest you get a quote first.
Apr 01, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Recently purchased eGo Helium 500 GB USB Drive. During installing on Win XP SP3 system it fails the USB to ATA/ATAPI Bridge portion of the installation and reports a problem in the balloon.
I have this external hard drive myself although mine is a 25gb drive. When you first tried to install it did you insert the disk that came with it first? You may need to do this if your system isn't recognising the drive. According to the system requirements it should be compatible with your system. Good luck. Andrew
Jan 18, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
External hard drive will not mount on my mac
Bet the drive is toast. Get the correct software and do diagnostics on drive to confirm
Sep 21, 2017 | Iomega 33089 250 GB Hard Drive
Weird clicking sounds
Clicking sound on an external hard drive is an indication that it's quiting to work. You mentioned that it's just stopped working, you may need to check the Disk Management of your computer to see if you could still reformat it. To do this, please follow the steps below:
FOR WINDOWS XP AND VISTA:
1. Make sure that the HD is properly connected to the computer.
2. Right-click 'My Computer' or 'Computer' folder and then go to "Manage".
3. Locate and click Disk Management.
4. Then, take note of the drive letters that will appear on the screen.
5. While the Disk Management window is opened, unplug the HD and check which drive letter will disappear.
6. If a drive letter disappears, then that is your external 250GB HD. You may reformat it to make it work again.
NOTE: Reformatting the HD will erase all the files saved in it. You may want to bring your HD in any data recovery center to retrieve the important files. If the HD didn't show up under your Disk Management, then there's nothing that we could do but to bring your HD in to the Data Recovery to save the files.
FOR MACINTOSH OSX:
1. Connect your HD to the computer.
2. Click 'Go' (located near the Apple icon, Finder, File, Edit and View).
3. Select Utilities and then click the Disk Utility Icon.
4. Take note the drive letters and then unplug the HD.
If a drive letter disappears, that's your HD. If nothing disappears, then the computer no longer detecting the HD.
Jun 01, 2009 | Iomega (33215) 250 GB Hard Drive
Hard drive not rcognized
Hi i think you need to change the jumper settings on the back of the hd to tell your comp that this isnt the main hd if you have allready done this then the only sollution is to trace down the software that came with that hd.
You might be able to get it off the net i will also look for you and check to see if the jumper setting are causing you problems i will post back as soon as i find anything out ok let me know how you get pn
Jan 03, 2008 | Hitachi HDT725050VLAT80 500 GB EIDE Hard...
LaCie (300770) 250 GB Hard Drive Logo
109 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
