Question about GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker model JVM1851SH will not heat food, smells like something was burned and makes a different noise when running. Easy to fix or better to buy a new one?
fridgetech
  • 473 Answers
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Posted on Oct 10, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Spacemaker Microwave - won't heat
Thanks for making your post very detailed and including the model number. That really helps! :)
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly easy & cheap do-it-yourself fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 13, 2008
  • 111 Answers
SOURCE: GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Posted on Dec 20, 2008
SOURCE: My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
Posted on Mar 19, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a JVM1630WB GE Spacemaker microvwave oven.
It's almost certainly a shorted high voltage rectifier diode or a failed magnetron.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Here are some handy links you or someone you know can use for test help:
(if it's not shorted or burned, it's probably okay)
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If it's within the magnetron portion of the warranty (for this model it's 10 years from the date on the tag inside the unit) but out of the original full warranty (1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
G.E. they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jul 26, 2009
Micro GE Spacemaker XL1400 Sunday I was warming up soup for three minutes when ready open door and I heard a click, micro shut down I tested the power outlet with the blender and It work An hour later the...
IF YOU SMELLED BURNING TAHTS BAD, IT SOUNDS LIKE YOUR MAG TUBE WENT OUT (ITS WHAT MAKES THE MICROWAVES) iT WILL BE CHEAPER TO REPLACE IT, NEW UNIT STARTING FROM $115 FOR THE SAME MODEL
Jun 07, 2010 | GE Microwave Ovens
I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave run with a different noise and stopped heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fkj
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating food
It's most likely the Magnetron. The are not very easy to install and quite expensive. Older models magnetrons cost about 80 bucks from GE. It's probably not something you would want to try and repair yourself. Call a GE service person.
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave won't heat food
hello kmwnky,
You say that Everything went out at first ( which I assume means that all functions went dead) and then functions started to operate again later... if that is correct and you smelled something burning.. you may have a thermal fuse that failed, filament transformer that failed, magnetron tube that failed or a highvoltage capacitor that failed.. None of these components are something the untrained person should attempt to trouble shoot or replace since there are dangerous energies stored inside the electronics compartment even after power is removed.. Your Micro is > 8 years old and it's probably not worth the cost of repairing at this point. You'd be better served replacing it.. The cost to repair would exceed the cost to replace.. ( I feel like the grim reaper here..sorry..)
Regards,
Rick
Nov 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave makes loud noise and does not heat. Smell of light burning
yes anything can be fixed but a do it yourselfer i reccomend against this cause thats a radiated element in the micro
recommend go out and purchase a replacement go with G.E. they have the 7 year warranty great little micro. too change out is easy
Jun 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Burning odor, no heat
A burning smell along with a different sound (growl) USUALLY indicates a breakdown in the High Voltage Side. This is not a direct short (short circuit) or the line fuse would have blown shutting everything down. The High Voltage Side is made up of-- The Secondary ,or High Voltage Side of The High Voltage Transformer, A High Voltage Diode, A High Voltage Capacitor, and The Magnetron. If The High Voltage Transformer is the problem it will smell like a florescent light ballast burning, and will smell each time you turn on the MW. A HV Diode burns and opens, thus no more smell. A HV Capacitor usually does not burn nor does the Magnetron. There is no Cheap-Fix unless you can see that the HV Diode is burned into and you can get to it to replace. CAUTION: Always unplug from power before attempting to repair. NOTE: If you replace a Diode make sure it goes back in the same direction it came out. Yes there is a front and back.
Jan 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM130 001 Over Range Microwave does not heat
It's probably the high voltage rectifier diode or magnetron.
The magnetron will have a guarantee lasting about 5-9 years, so if it might be covered, contact GE at http://www.geappliances.com/service_and_support/contact/
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Also, there should be a very helpful "mini-manual" hidden inside the unit behind the control panel.
Dec 08, 2007 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
114 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
