Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Refrig is making a loud moaning/whirring sound. It's coming from the freezer, behind the ice bin.
    President:
  • 1,099 Answers
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
This is common. Unplug it or turn off the circuit breaker for a full 5 minutes. Then plug-in and follow instructions. Things will be good
Good luck......
Posted on Aug 08, 2010
Why is my refrigeror freezer making a chirping sound?
Check your manual that came with the refrig. Many 'fridges now will make a soft sound, sometimes even a "moan", when the automatic de-icer starts working. Usually it's normal. HOWEVER, if you hear a real loud, shrill, or weird sound of some kind that is different.
Jul 22, 2014 | Whirlpool Refrigerators
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I found and fixed loud whirring noise in freezer
I m not sure what your asking . so let me try . you corrected your problem . and it's working . i think it's great. now in a couple of day's it may do it again. generaly if you have ice build up like you described . then you may have a defrost problem.if you do . then you must correct it . the heater / or timer or thermo may be out . so if the problem comes back /get me the brand & moder #.. **** hope this helped mm
Dec 17, 2009 | Kitchen Ranges
Our LG bottom freezer refridgerator is 2 years old. It is making a whirring noise that stops when the door is opened. It can get pretty loud at times.
The whirring sound is the fan that blows cold air into the refrigerator. It is supposed to stop when the door is opened. If it is making a loud noise there may be ice built up in the fan housing. Turning the power to the refrigerator off for a 2-4 hours may allow any ice in the fan to melt. If you do not open the freezer during that time the frozen food will not defrost.If the noise continues, you may have to take the fan apart to make sure it is not frozen. It is probably located behind the back inside panel of the freezer.
Nov 02, 2009 | Refrigerators
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Loud Buzzing Noise from Behind Freezer
Sounds like the freezer fan blade is hitting on a build up of ice or frost. You may have a defrost issue, or it may be a one time thing, like the door was open for a long time (object holding door partially open) or also check the ice dispenser duct door to make sure it is closing. Sometimes a chunk of ice hangs up in the ice shoot, allowing moist air to enter freezer, resulting in the extra frost / ice near the freezer fan. You might also check the door gaskets, especially the bottom side where sugary liquid spills might cause a gasket to tear. #2: Long run times: If cooling is good, don't worry. Older refrig's often ran less time, but used much more electricity than the newer refrig's, even though new one run longer. (Like having a 40 watt light bulb on for 20 hours a day uses less electricity than having a 100 watt bulb on for 10 hours a day)
Aug 27, 2008 | GE PFS22SBSSS Stainless Steel French Door...
My freezer is buzzing- loudly!
Sounds like ice buildup around the fan that's inside the freezer.  My lousy GE 3-door did that when the bottom freezer didn't get completely closed overnight, and everything behind the back panel, where the coils are froze up like an iceberg.  I had to take the back panel off and melt it with a hair dryer.
See if you see any abnormal ice buildup, or if the refrig compartment is getting warm.  That's usually a result of ice buildup.   Another cause is a failure in the defrost cycle.  It will freeze up after a couple days. This would usually be the defrost timer.
Oct 23, 2007 | Refrigerators
Intermittent Loud Whirring Noise
sounds like the evaputaor fan motor.. may need to replace.. check to see if anything maybe hitting fan blades
Sep 30, 2007 | Frigidaire FRS23R4A Side by Side...
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
230 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
