Question about Cameras
How do i get my video to playback? with-out taking the memory card out?
  • 39 Answers
There is usually a physical switch where you move from viewing pictures/vidoes to taking pictures. Here there should be a setting for viewing. If not, then there usually is a menu option when you are viewing pictures/videos. Not sure which model of camera you are using, so I am not sure how to tell you specifically.
For Canon cameras, usually a menu button or function button. If you press this while viewing your photos, it should bring up a menu that has a play, stop, fast forward, erase, etc buttons on the screen.
Hope this helps. Good luck.
Posted on Apr 28, 2008
Nikon Coolpix S2500 - How do you see how much memory is available after taking photo's
In the shooting and playback modes, if you're in still mode (not video) then in the lower right corner of the screen is a number in square brackets []. This number is a rough estimate of the number of additional pictures you can take before the card fills up. If the card can hold 10,000 or more additional pictures this number will be 9999. In video mode this displays an estimate of the number of additional minutes of video the card can hold.
Mar 16, 2012 | Nikon COOLPIX Cameras
Can't play back videos on my experna; memory card Sandisk class 4 8Gb. Have a canon Vixia HFR10 camcorder
Okay, ours is a different brand (JVC) but they may have some basic similarities in function. To playback video clips stored on the memory card, put the memory card in the card reader slot of the computer and put the files onto the computer. Playback the clips from your computer video or photo file. (Ours won't playback video stored on the memory card through the camera.)
To playback video clips stored on the camera hard drive through the camera, we open the viewer screen, look at the function keys on the camera body, select the "Play" button. On the screen it displays thumbnails of the various video clips. We use the toggle/function key to select from the menu containing options for playback, edit, delete, protect, etc.
May 16, 2011 | Canon Vixia HFR10 Silver Dual Flash Memory...
1.cassette can't playback 2.SD card can't read
please take the camcoder to a tech or return to manufacturer if it still has warranty cos its not likely a problem you can fix yourself...
it may require simple things like cleaning tape head a re-inserting memory card or changing it
or require more technical details....
Feb 13, 2011 | Sharp VLZ7U Camcorder
Hi.i have a really important question and im hoping you can help me.everytime i try to review my videos on my camera it says(video management file is broken to record/playback video,recovery is...
Select "OK" to restore. (Videos that cannot be restored will not be displayed on the index screen, but you may be able to play them back using "PLAYBACK MPG FILE" in the menu.
if the file is damaged....
Select the playback mode.Select video mode.Touch to display the menu.Select "PLAYBACK MPG FILE" and touch.Select the desired video and touc.
May 12, 2017 | JVC GZMS230 Camcorder (Black)
My phone says playback failed when I try to play a video
Hello
You need to first check if the videos are on the phone memory or on a memory card.
If its on the memory card ,you should remove the memory card and put it into another phone to see if it plays the video,if it plays then the problem is from your phone,maybe the phone is not compartible with the memory card.
If it does not play then you might have to format the memory card and save the videos on it again to make it work properly.
BEST OF LUCK
Aug 10, 2010 | Sony Ericsson Cell Phones
My camcorder won't take new video or new pictures. It keeps telling me the message "Memory Full". My memory card is empty. I cleared it onto my computer. When I put the camcorder in Playback mode, there...
Hello...you didn't specify the type of video camera you have...if possible, go into the menu options concerning the memory card. reformat the memory card--since there are no files on it, you don't have to worry about losing anything. Don't format the card on your computer--the formatting for one maybe drastically different from the other! And vice-versa. Hope I helped you...Rick
Oct 14, 2009 | Aiptek PVR Camcorder
Vertical lines on memory card playback
The lcd ribbon cable is cracked and must be replaced
this is a common problem with this model I have fixed over 100
Jan 04, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Need to delete memory
You need to remove the memory card from the camcorder and place it into a pc or photo shops computer. This will allow you to view the saved items on the memory card. You can then save these to disc and delete the contents on the card.
Jun 12, 2008 | Optimus DV-5040 Camcorder
Cameras Logo
98 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
