Question about Microwave Ovens
When we start the microwave and push the start button instead of 30 seconds 15 minutes appear.No other button including start button works.It stops working only on opening the window of the microwave and E7 appears on the times screen.Please let me what is the exact problem and the way to fix it.
  • Obertelli
    Obertelli Aug 08, 2010
    Sorry but your question is currently impossible to answer.
    You must state the exact make and model if you want a useful answer.
  • 909 Answers
That normally means the board needs to be replaced. Without wanting to explain all the details, im almost sure the keypad is still in good order.
Posted on Aug 08, 2010
The microwave keeps stopping
If you are actually selecting heating time rather than pushing the "quick heat" button, the control board may be defective.
Aug 22, 2016 | Microwave Ovens
HOW DO I OPERATE IT, EG HOW TO USE IT TO WARM ALREADY COOKED FOOD AND PASTRIES
I usually just put the food in a microwave proof bowl and put it it and push the button number that I think will be hot enough but not so hot it will burn my mouth .1 or 2 minutes is more than enough for most 30 to 50 seconds for coffee and 10 to 15 seconds for pastry
Sep 03, 2015 | Microwave Ovens
Microwave stops after 59 seconds
Check that a "favourite" setting has not been selected. The unit may think that is the time that you want to cook. Im not sure about your model but see if there is any clear or cancel buttons to clear any pre programmed selections. If not, unplug the machine for 15 minutes to reset the controller and try it again.
Nov 25, 2013 | Electrolux Microwave Ovens
Just start 15 minutes and then stop
Pull the cover if necessary to see if the fan is spinning. If it's running 15 seconds, your door switches are probably ok, and the touchpad is working, main fuse ok. All that leaves is the circuit board and the magnetron.
Personally, I prefer microwaves with twist timers, not touch pads. A lot less to go wrong.
Nov 22, 2013 | Panasonic NN-S969 Microwave Oven
Need to st clock on panasonic nne281mm
follow the steps and fix it. God bless you
1) Press the "Stop" button on the microwaveicon1.png to reset the digital display to the clock setting.
2) Push the "Clock" button once. Locate the "Hour" button and press it once for each hour of time. For example, if the current time is 5:15 p.m., press the Hour button five times.
3 )Press the "Minute" button to set the second half of the time. For the example above, you would press the Minute button 15 times to set a time of 5:15 p.m.
4)Push the Clock button to saveicon1.png the time setting. Check the time on the microwave's digital display.
Feb 07, 2013 | Panasonic Microwave Ovens
Microwave not heating, but does count down minutes.
Press clear/reset button and hold 5 seconds. If this doesn't work unplug unit or shut off breaker for 10 seconds.
Sep 25, 2009 | Hotpoint RVM1435 Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
Convection oven stops every 5 minutes and won't continue
to trouble shoot hold the door securely shut for longer than 5 min to see if it runs longer if it does the you should replace the interlock devise
Dec 25, 2008 | Sharp R-930AK Convection/Microwave Oven
Panasonic Microwave Convection Oven Model NN-8501Vstops after one min. of operation-Display goes to all
If you unplug the ac power cord , wait between 30 and 60 seconds and then replug the cord in, push the reset button and then select the time ot cook desired followed by the start button, it seems to work fine for a while (days) and then for some unknown reason it stops after one minute of operation and returns to all eights on the display. A real mystery as to why this is happening and what is really wromg with the unit.
Jul 25, 2008 | Microwave Ovens
Microwave Ovens Logo
61 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
