Question about Pentax Optio S5z Digital Camera
Pentax optio s5z
I get an error stating my operating sysem does not support this camara(windows XP professional). How do I get my pix to download to my computer?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Posted on Aug 31, 2012
SOURCE: My Pentax Optio s5Z is stuck on one mode
I also had this problem. I think it is caused when the camera is turned off while in the viewing part of the camera. That is, I had gone to look at the video that I had just taken, but didn't and then turned the camera off. The camera is then as you have described it.
The only way I could get it back to normal is to connect the camera to the computer, using the cable, and download the photos and videos. When the download is complete, disconnect the camera and it should be OK.
Good luck, cheers. Phil
Posted on Oct 30, 2007
SOURCE: Unlock Pentax Optio S5z
Thank you sooo much *bsho* I had this exact same problem on my camera for about 3 weeks ,and it was really making my angry!.. Thank you so much for your solution it worked for me!
Posted on Sep 19, 2008
SOURCE: instruction manual for pentax optio s5z
I could send you a copy of the manual on CD.
Where do you live?
Posted on Jun 26, 2009
  • 11967 Answers
SOURCE: Pentax Optio S5z \ Lens will not close
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 14, 2010
  • 23 Answers
SOURCE: My Pentax Optio S5z does not store images to SD
Copy your photos to the SD card in the camera. http://www.pentaximaging.com/files/manual/OptioS5z_web.pdf p. 136
Transfer all photos to your computer from your SD card, and then put the card back into your camera. Try looking through your manual to see if there are any other settings that are required in order to save photos to the memory card.
Posted on Feb 22, 2010
I was given a Pentax Optio s5z the camera does take pictures - however it does not take them or put them on the picture card - only on the camera which only holds about 5 pictures - once I put in the...
What type and size memory card are you trying to use? The S5z works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Oct 01, 2013 | Pentax Optio S5z Digital Camera
Feb 22, 2010 | Pentax Optio S5z Digital Camera
Describe your can pentax s5z 4 gb Problem
Did you format the card in the camera before using it?
Feb 10, 2010 | Pentax Optio S5z Digital Camera
Lens on Optio S5z will not retract. When turned
Please view my FixYa tip on this subject for a complete walkthrough of the potential causes and solutions.
http://www.fixya.com/support/r3556007-camera_lens_stuck_or_wont_retract
Many thanks for using FixYa.
Dec 18, 2009 | Pentax Optio S5z Digital Camera
Instruction manual for pentax optio s5z
Where do you live?
May 10, 2009 | Pentax Optio S5z Digital Camera
Memory card size
The S5z is limited to SD cards, 2GB and smaller. The speed doesn't matter, but larger cards will not work in this camera.
Aug 26, 2008 | Pentax Optio S5z Digital Camera
Sep 09, 2007 | Pentax Optio S5z Digital Camera
Pentax Optio S5z Digital Camera Logo
43 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
