Question about Home
If i was to paint a concrete shower, what would be the best paint to use to stop mold and keep the paint from bubbling and peeling up?
    Brigadier General:
  • 3,513 Answers
Please find the bellow mentioned articles which would help you to paint and take care of your concrete shower.
http://www.ehow.com/how_4761037_make-stick-concrete-shower-floor.html
and
http://www.ehow.com/how_5154869_paint-concrete-shower.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 08, 2010
Paint bubbling and peeling soon after painting a newly rendered wall........how do we fix it?
Sorry for the paint peeling and bubbles. It's not the drywall tape that has bubbles... right? Paint can react like this when it is applied over a sanded wall that has not been cleaned and still has a layer of drywall dust on it. When primer is applied to the wall, it is best to use something to push the paint on the surface to combine the dust with the paint. This could be done using a paint pad but should be more than just rolled on. The paint needs to mix with the dust and stir it in with the paint so the paint get under the dust. You might try thinning the paint a little to allow for better attraction to the wall. So now how do you repair this? By scraping the loose paint off and starting with a new coat. You know. it could also just be bad paint.
Aug 02, 2014 | Drywall
Paint flaking on wood burner
even the best high temp paints don't last for ever
also if you didn't clean the surface well it harder to stick
there not much you can do, depending on the stove type you have it may be something you just have to live with, some stoves get hotter than the paint can handle but even the best high temp paints will peel and blister in time, one small it is sand and clean surface and use a very thin coat, this is one time more is NOT BETTER...less is better and will last longer
Mar 10, 2014 | Garden
I want to strip the concrete floor that I use jasco seal 6 years a go do you have any product I can use .
  • 1 Make sure that the surface of the concrete is cleaned thoroughly. Remove stubborn dirt or stains with a mixture of one part degreasing cleanser and two parts water. Rinse the concrete well and wait 48 hours before continuing.
  • 2 Use a large paintbrush or a long-handled paint roller fitted with a fine-nap roll to coat the entire concrete surface in a thick layer of soy-based or other environmentally-safe chemical stripper. Allow the stripper to eat away at the sealant for 10 minutes, scrape up the peeling sealant with a paint scraper or putty knife. Clean up all of the debris.
  • 3 Rinse concrete to remove all of the stripper. Let the concrete dry 48 hours. Apply the new sealant or the finish of your choice .
  • Oct 21, 2013 | Jasco Wet Look Cure Seal 0613-GL Set of 4
    I painted a section of my garage floor with a cup of paint 1/4c oil base acrylic mixed with 3/4 c water base latex...will it ever dry thoroughly? it is drying slowly and is really sticky. will I just have...
    did you ever try to mix water with oil? what was the result? are you sure that you can cross the street without adult holding your hand?
    unfortunately you need to remove all that paint, just drop few shovels of fine sand over, and scrape it... sand will adhere to the tp surface of the pain and will allow you to scrape it. after you scrape it off, use any degreaser or similar product to wash reminder off, leave it for few weeks to dry through and then in small patch try if it would accept latex pain, roll it very, very thinly and leave overnight, if it is dry (solid dry) after 24hrs and do not peel off, you can then use this paint on the rest of your garage floor.
    now, i would advice strongly against painting garage floor with any paint except concrete paint (they are usually water based with strongly alcalic ph), and after that use concrete seal. this should give you long lasting surface, sealed from oils, dust, water and whatever contaminant you can imagine in the garage.
    Sep 12, 2013 | Sherwin-Williams Best Look Latex Garage...
    Shower walls
    You have got a lot of moisture behind your wall covering. Is that a plastic or fiberglass shower wall liner? You are going to have to tear out the shower walls, clean the studs, replace insulation and put in new walls. You must stop the leak too! You could be growing a lot of mold in the cavity behind your wall.
    Jul 06, 2013 | Tools & Hardware - Others
    I have mold on a plaster wall - how do i fix mold on a wall with mold
    Clean the wall with bleach and then paint the walls with anti-fungal paint.
    If this room is a bathroom then install an exhaust fan to draw out the moisture when you take a shower.
    Oct 28, 2012 | Dell Inspiron E6550 Notebook
    How can i prevent my bathroom ceiling paint from peeling off
    One of the main reasons for the breakdown of paints in bathrooms, is of course moisture. Do you have a fan/ventilation system, (not just a recycling air filter,) that can be turned on when you bathe or shower? This would help. Also, a better type of finish would be an eggshell or satin finish type paint. The moisture cannot gather to the same extent on this type of finish.
    Sep 19, 2012 | Cars & Trucks
    Need to repaint bubbled and peeling paint on top of dryer
    The choice is yours. Money often motivates these decisions. If the model number you have this listed under is correct, the top panel price is roughly $108 to $160 depending on the color you need. White or Bisquit is the cheapest, while Pewter is the most expensive. If you wish to replace it, appliancepartspros.com carries it for the cheapest price.
    If you wish to paint it, remove the panel from the dryer first by locating and removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off. This will allow you to work on it in a more convenient location and avoid any overspray from paint on your appliance. Make sure you clean the surface throughly to remove anything that may have caused the paint to bubble and peel in the first place (Ospho is commonly used to clean metal surfaces in preparation for painting - clean AFTER you sand). I would sand with a fine grit sand paper or emery cloth to ensure you don't leave any surface scratches. Prime the entire panel to provide a good surface for the new paint to adhere to. Once the primer is dry, apply a couple of good coats of appliance paint. If you have questions, please let me know. I hope this helps you.
    Sep 06, 2009 | Whirlpool GEW9250 Electric Dryer
    Inside finish is peeling off
    No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
    Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
    Otherwise, you can have rust and arcing, which can be messy.
    Nov 21, 2008 | Microwave Ovens
    Home Logo
    Top Home Experts
    john h
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
