Question about Hotpoint Ovens
My Hotpoint EW81N dual element is on full all the time. Is it a dual energy regulator I need?
    Brigadier General:
  • 3,513 Answers
Yes All Hotpoint Dual element requires a dual energy regulator. Please check this site to get one:
http://www.europart.co.uk/s.nl/sc.2/category.794675/.f
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 08, 2010
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Two of my Hotpoint EW95 Halogen Double Oven elements have lost temperature control. When switched on they go to full heat and stay there regardless of setting on dial. What is wrong?
    change switch if there is no control if talking cook top elements
    Infinite switch burner control need model number in full for quote
    Nov 18, 2014 | Hotpoint Ovens
    Hotpoint SD97PI oven self cleaning funtion and grill not working
    The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. The most common complaint I have had with built in ovens besides the element burning out, is the oven door locked shut. When I get to the house and I ask to tell me a little bit of whats going on the story always starts " well, I was using the self clean option" or some variation of the sort.
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
    Jun 22, 2012 | Hotpoint Ovens
    Hi...I have a Hotpoint Bu72.and the fan element blew.....I have replaced the faulty element with a new one....but still the fan and the element do not work. the power supply is ok. could a faulty...
    if the element shorted out and broke apart it can also take out the clock assy. or computer board same thing next time send the full model number off of the oven
    Nov 16, 2017 | Hotpoint Ovens
    Hotpoint ew81n cooker. Non working oven thermostat has been replaced. The cooker temperature is hotter than the dial reading. What can I adjust to make them the same?
    Hi.
    Unfortunately, the oven thermostat is non adjustable.
    However, it is normal for oven temperatures to vary by + or - 10% of the setting.
    This is acceptable, so to compensate, set the temp 10% less of the required temp setting.
    Make sure you have the sensor fitted correctly inside the oven compartment
    Make sure that the thermometer is accurate if you are checking the temperature with one.
    Feb 23, 2011 | Hotpoint Ovens
    How much power does my JJW8527C Express Collection Electric Single Oven use?
    If you look on the tag on the oven, that is visible when the door is open, there is a rating number followed by a kw. This number will tell you how much power the unit will use while the elements are on.
    So for example if it says 5kw if the elements were on for one full hour it would use 5 Kilowatts of energy.
    One thing to note is the elements are typically only on for 20% of a normal baking cycle. So for normal baking you would multiply the 5kw by 20% and get a power usage of 1 Kilowatt of energy. This would be higher for using self clean and lower for short baking times like cookies.
    I hope this was not too confusing.
    May 01, 2010 | Jenn-Air JJW8527C Expressions Collection...
    My electric hot point oven doesn't heat properly. The top part of the heating element does not come on.
    It is either a faulty element, or a faulty regulator/selector switch tha t is causing the problem.
    Hope this helps.
    Dec 18, 2009 | Hotpoint Ovens
    Oven on full all the time
    Ypu need to replace faulty main oven thermostat, as it is obviously not controlling the temperature.
    Dec 25, 2008 | Hotpoint UY46 Style Line Stainless Steel...
    Hotpoint EW81 Dual Oven Cooker
    Installed the new Dual Regulated switch which operates the Gril, but have got the wires inserted incorrectly. Need help wiring it up.
    Wires are 2x Red,Black,brown,gray,Yellow and a red link wire which came with the part
    New switch is a Diamond H - 48ER101C1P.
    Numbers on switch are S1,P2,2,P1,4,S2
    At the moment I have no cooker - help.
    Sep 08, 2007 | Ovens
    Ovens Logo
    52 people viewed this question
    Top Hotpoint Ovens Experts
    Jason Harris
    Jason Harris
    Colin Stickland
    Colin Stickland
    Charles T Nevin
    Charles T Nevin
    Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
