My IBM monitor blinks on and off on start up. Then after 15 to 30 mins., it goes well. its annoying.
  • 225 Answers
Take it apart and replace the low voltage capacitors on the power supply board.
Posted on Aug 08, 2010
Monitor screen goes white at start up
That could be the monitor or the video/graphics card in the computer. Try another monitor as a test to narrow the problem. If it's a laptop, therer's usually a VGA port where another monitor can be installed. You might need to press a Fn key combination to turn on the second monitor in that case.
Feb 04, 2018 | IBM ThinkVision L201P (Black) 20.1 inch...
How can i fix the continous on & off blinking of my ibm l170p monitor
If your monitor is blinking or flickering increase the refresh rate.
Apr 07, 2012 | IBM ThinkVision L170p 17" LCD Monitor
When I start my computer, the monitor can take up to a 1/2 hr to display. I have dual monitors; the 'Acer' will eventually blink/show 'Acer', then fade. It repeats every 3 seconds. The...
your problem sounds like you have bad capacitors on your monitors power board. once you start it, they do not have enough capacitance to give to start the monitor, but after letting it for some 10ish minutes or so, they capacitate enough to start. even then, after some time, they will lose the capacitance because they are feeding the monitor in constant power when the power from the outlet drops a bit, but being bad - they will shut off your monitor. some repair shops can change capacitors only, others would make you change the all power board
Aug 04, 2017 | Acer AL1511 15" LCD Monitor
My computer works normally but my monitor suddenly turns dark. I try to turn off the power (monitor) and when I turn it on back, it turns to normal. but few minutes later, the problem goes back. This...
Sir,
Does this happen when you leave your computer idle for few minutes? If so,then the Pc is
simply turning off your monitor to save power when you don't use it.And you can turn it back
on simple by hitting keys on your keyboard or moving the mouse to and fro.However if you
would like to disable/change this option the please do the following.
If you are using Win XP,then
1.Click the windows Start button,then click Control Panel,click Performance And Maintanance
and then click Power Options.
From the window that opens,choose the time period after which you would like your monitor to
get into power saving mode (the default is 5 mins) or choose 'Never' from the drop down box
next to where it says 'Turn off monitor'.Then click the apply button and finally the ok button.
If you are using Win 7 or Vitsa,the please follow the following link to learn how to disable this option.
http://www.howtogeek.com/howto/windows-vista/disable-power-management-on-windows-vista/
Oct 27, 2010 | IBM ThinkVision L170 17" LCD Monitor
HP L1906 flat monitor
why not test the monitor on another PC
works there good.,
if not the monitor is bad.
can be monitor bad, cables bad, power pack if fitted bad.
test it on another PC.
win
if bad monitor start a post how to fix a bad monitor (endless answers)
Mar 20, 2017 | HP vs19 (Silver) 19" LCD Monitor
Hand-me-down IBM Thinkpad 600E 2645 has blinking LCD video XP O/S
This sounds to me like either your flourescent lighting tube is beginning to go bad ,,, or the inverter is going bad ... or even both. :-)
The cheapest and easiest solution for you is to simply replace the LCD screen (replacing the inverter or the tube are actually a bit cheaper, but not quite as easy to do - most computer repair centers will try to talk you into a new screen anyway). This is actually very simple for either you or someone you know who is an avid "do-it-yourselfer". IBM makes ity very easy. You will find easy, detailed instructions in the ThinkPad 600/600E (2645) Hardware Maintenance Manual, IBM S10L-9619-03 June 1999 available for FREE downloading in .pdf format on IBMs website. Follow this link to some really sweet deals on LCD screens for your 600e on eBay for under $35.00. http://shop.ebay.com/items/?_nkw=ibm+thinkpad+600e+lcd+screen&_sacat=0&_trksid=p3286.m270.l1313&_sop=12&_dmpt=Vintage_Electronics_R2&_odkw=IBM+tube&_osacat=0
Remember you can always connect an external monitor to your ThinkPad until your new screen arrives if you have one. The manual should also give you instructions to change out the tube if you wish to save a few more bucks and try that route. Hope this will FIX-YA! Please leave your feedback and let me know!
Jul 27, 2009 | IBM Computers & Internet
Power goes off
the power supply section of monitor is get faulty, check it to an expert.
Jul 16, 2009 | Proview PL926WBi 19" LCD Monitor
Optiplex GX 110
Check your WGA and try another monitor in that pc
Oct 20, 2007 | Dell OPTIPLEX GX150 HEAT SINK & COOLING...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
