Question about Carrier Heating & Cooling
Describe your carrier 42kgl - 018p operating Problem, Remote not operating, battery changed, it shows frequency transmiting signal on remote but does no effect on Unit, how ever unit works fine with mannual button.may be remote is working but it is not senced by unit.
bobotfel
  • 236 Answers
SOURCE: carrier rfl 0601ehl
Try disconnecting the power supply from the circuit breaker tor 10sec., "on" it again and start the unit. If it don't correct the problem you need a qualified technician to check the defective parts in the unit.
Posted on May 02, 2008
SOURCE: Wall Hung A/C unit remote
I just got onto a technician who solved the problem for me. What he had me do was:-
  1. Pull dowwn the slider and use a pen to press the ACL button.
    That didn't fix it so...
  2. Take off the slider (the way you would to change the batteries). There is an ABCD slider switch and mine was set to "C". I moved it back to "A" and now it works! I am not sure how it got to "C" though ???
The other thing is I had been messing around with the "Manual/Auto" button under the grill on the wall unit. It was set so that the A/C was off. I'm not sure if that is significant.
Hope that helps.
Cheers,
Garry Rogers (ausgaz)
Posted on Jan 04, 2009
bobotfel
  • 236 Answers
SOURCE: LG Split system (ceiling cassette)
Check your remote control by using your camera or cellphone camera as your eyes. Point the remote control to the camera and "on" the remote control. If no lights emits in the remote control means that your remote control is defective If lights emits then the remote control is ok. Try also to locate the reset or rst button on the remote control if available and reset it, then try. If it wont work may be the receiver board in the unit is defective.
Posted on Jan 14, 2009
  • 400 Answers
SOURCE: remote doesn't work.
John I suspect that your remote sensor reciever on the ac unit is bad, you may need to replace it. Quite simple two screws and a plug in fitting.
Posted on May 08, 2009
geo_jonas
  • 555 Answers
SOURCE: remote control signal to multi or split air conditioner, samsung
maybe the lightning has something to do with that but to make it sure try to call a service person and try to refer it and kindly ask some explanation if he can fix it so that next time you can justify the reason this thing happened.
Posted on Jun 16, 2009
Need code for Sony DVD and Sony tv and how to program it I have ge 24991 1312 universal remote
Buy a SONY universal remote.
Most universal remotes do not support SONY, but a hand full do.
Packaging should explicitly state support for SONY.
Most IR remotes can use a carrier frequency range of 30-56KHz, with most using normally 38-40KHz, or likely the GE universal. SONY is in the mid 50KHz range, other manufactures in upper 40KHz range and audio equipment Bang & Olufsen and, Kenwood use a 455KHz frequency. The carrier is what your TV or DVD is tuned to see and the codes are transmitted like Morse code for digit ones and zeros to say, change channel or play.
Short to say if you don't find an auto code scan that works then try another manufacture. Manual can be found online at manualslib if lost.
Feb 27, 2015 | Sony Televison & Video
My kenwood kr-v7030 won't turn off anymore with remote or manually.
Either the remote battery are flat or the frequency settings have changed. You can check with the manual the type of frequency it uses to match the that of the Kenwood. Sometimes there are switches you can change to adjust the correct frequency. Others have a learning code set by the manufacturer and are usually in the operation manual. If you want to test whether the remote is transmitting the signal to the Kenwood or not, Please do this...
If you have a digital camera or smartphone camera, switch the camera on and look at the viewfinder or camera screen; for smartphone, in a moment, then point the remote to the camera lens and press the volume button, which keeps sending the signal to the to control the volume of Kenwood system. If you see the infrared light on the remote flashing, then the remote is fine.
Now, about the smartphone camera. Start the camera and switch it for video capture (filming) and then point the remote towards the camera lens, and likewise you should see the remote light when doing the same tests as you with the video camera. If the infrared light lights up when pressing on the volume, the remote is fine.
It could be Kenwood, which requires factory repairs, not by you.
Dec 22, 2014 | Kenwood Audio Players & Recorders
Why wont my channel buttonand on off buttons dont work
Two possible areas: batteries have become too weak to transmit if signal or Vizio remote needs to be synchronize with tv.
I assume it was working. Try pressing button marked 'tv' close to bottom of keypad and then try on/off. A few remotes have a reset hole takes a paper clip, I do not believe your model is one.
You should be able to test your remote with a cell phone or digital camera. Using camera on your phone, aim remote at camera as if cell phone was tv. Press on off key ( vol, channel up/down ) and if you see red light when remote buttons are pushed...remote is transmitting. If nothing...make sure you remote is not enough
radio frequency or RF.
Jul 26, 2014 | Vizio VW32L 32 in. LCD HDTV
Universal remote not transmitting
Universal Remotes are so inexpensive that you are better off getting a new one than to try and spend the time to fix the remote. But here is some things to consider.... Did it STOP working when the batteries went dead? Have you put in the NEW CODES (normally on the Back of the Remote) to communicate with your equipment? Have you set up the Remote yet? You can not SEE Infared, how do you know it is not sending out a Signal?
Start by removing the Batteries and replacing them with new ones (unless you can measure the output of the Batteries with a Multi-meter). They should be close to 1.4 volts. Because a light comes on does not mean it is strong enough to operate the TV or other equipment.
Mar 01, 2014 | Universal Remote Control Televison & Video
Manual switch ok but remote not fundtion sharo tv
Be assured that fault does not lie with the remote handset itself. In that case repair or replace it.Remote control system has two parts. One is the remote hand set and the other lies within the TV or other device for which remote controller is being used. The hand set transmits commands in shape of singnals of particular frequency and pulses per second depending on the key pressed. The other part of the remote system lying within the TV receives, decodes and responds according to the commands received in shape of signals of particular frequency and pulses of paricular width and sequence. The remote controller uses invisible infra red light as the carrier of the signal. As the light moves in straight path, no obstacles should block straight line of sight path between the remote hand set (the transmitter) and IR sensor window (part of the receiver). Hence remove the blockage from the front side of the TV.Check if the IR sensor is not defective. Check if the associated circuit and components inside the TV are not defective.Check if the TV has any switch for selecting only manual mode and locking the remote mode.Hope, some sytematic exercise will bear the successful result.
Feb 19, 2012 | Sharp LC-32SB21U 32 in. LCD TV
My ceiling fan/light goes on when I am not in the room. The remote is on the bureau. I sometimes put the remote in another room but the fan/light still goes on. Model 327185-060
The simple solution is to turn the wall switch OFF when, the fan is not in use. I really don't think the remote alone is the culprit. Because, you say it happens even when it's in the bureau or in another room. Remote controls for ceiling fans have a very short range and are generally infrared remotes, rather than radio frequency remotes. So, if the infrared signal does not reach the receiver's sensor in the fan, it won't function. If it's a radio frequency remote control, do you have any other remote controlled fans in the house? If so, does the suspect fan seem to turn ON after you have activated the other fan? If that happens, it means both remote controls are on the same frequency. Changing the frequency of one, should solve the problem. See your Owner's Manual for directions on how to reprogram the frequency codes.
If none of the above solves the problem, maybe you should contact the "Ghost Hunters" TV show.
Hope this helped you troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 23, 2011 | Hunter Heating & Cooling
Where to get the service manual for carrier 42KGL-018P split A/c???Please help..
Try this site.
http://homeappliance.manualsonline.com/manuals/mfg/carrier/48xl.html
All the best!!
May 12, 2011 | Computers & Internet
Remote control won't work. Brand new batteries in brand new remote. Transmit light comes on remote but amp does not receive.
First of all you will need to cross check the remote with a sensor to confirm. If not while using the remote check for change in voltage in the input of the sensor inthe amplifier. If there is no change then check for failrueof the remote IR emitter/ the remote controller IC or bad tracks. Check this out. If sensor is detecting then trace to the microprocessor of the Amp for any connection issues, solder the joints in this circuit. Sometimes the idications shows on remote but may have a wrong frequency. So check the crystal on the remote. helpful I hope. Good day
Jul 16, 2010 | Yamaha Audio Players & Recorders
Sideband carrier??
im not sure carriers are measured in pounds, but SSB is a supressed carrier mode, in SSB only one sideband is transmitted and the carrier is inserted at the other end in the receiver. In AM mode the carried and both sidebands are transmitted. with regular am there is a carried and when modulation (your voice) is added a signal appears both above and below the carrier frequency at a distance relative to the frequency of your voice. so if you have a carrier at 1000 khz and modulated it with a tone of 100 hertz the signal will contain frequencies of 900,1000, and 1100 hertz, then its changed to SSB by supressing the carrier (1000) and one sideband (1100) if you are on lower sideband and (900) if you one upper sideband, and transmits the remaining frequency.
Nov 06, 2008 | Ranger RCI-2995DX Base Scanner
IR frequency determination
The remote could be using RF, which is why your Niles equipment cannot handle it. There is no way to duplicate the RF or convert it to an IR signal.
If the remote is using IR, make sure the batteries are full and the light is low when you are learning the codes with tne Niles equpment. There is no way if it's IR that the freq is > 100.
Apr 22, 2008 | Televison & Video
Heating & Cooling Logo
63 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
