My proline PFL 1266W-F keeps coming up with an error 1 problem and will not wash. We have hardly used it and there is nothing stuck in the door. Is there a way to reset it or can you suggest what the problem is?
Soundcraft spirit sx stuck in pfl mode
Probably one of your PFL switches is stuck in ON.
If not, the digital decoder went kaput.
Also could be your +5V power rail, that one powers the digital stuff...
Good luck.
Nov 11, 2017 | Soundcraft Music
What does Err4 mean on proline PFL510W-U1 washing machine
proline pfl510w u Washing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > proline pfl510w u
Washing Machines proline pfl510w u questions and answers. ... need user manualfor proline logic on line need user manual for proline logic ... PROLINE LOGIC 6 KG AA WASHING MACHINE- It is stuck on "error2" what does this mean and ...
Washing machine PROLINE PFL510W - Manual.com
https://www.u-manual.com/...manual.../washing-machine-proline-pfl510...
On this page you can get: Washing machine PROLINE PFL510W manual - is available for free download. All information such as file size, preview picture, ...
Anyone know how to reset a Proline washing machine ...
forums.moneysavingexpert.com/showthread.p...
MoneySavingExpert.comApr 3, 2010 - I can't find the manual, either at home, or online. Our washing machine(PFL 1466W-U) is showing off today. We've managed to take ... Does anyone know how to stop it from running this programme, so that we can select the empty/spin cycle. We have .... Ok it's a cover not written but you know what I mean.
Dec 16, 2015 | Washing Machines
Good day. I have a LG T8011TDFP washing machine but does not start to wash...gives an DE error. Any assistance please??
Hello Richard,
DE error is a Door Open Error.
Check that it closes properly and there is nothing stuck in the door.
The door lock assembly may be bad and need to be replaced.
Call in for service.
Best of luck,
JP
Jun 25, 2015 | LG Washing Machines
KitchenAid range ProLine series kesv908 and ykesv908 Oven desplay comes up with err button stuck F2EO
Hi barbsofarell,
The error F2 - E0 code means a shorted keypad (also called touch pad). Please follow the steps below to correct the problem.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | KitchenAid Kitchen Ranges
I have a proline pool pump model # SD-15-1N11CC and it worked fine until I back washed my pool and now it stopped working. It makes a humming noise and nothing else.
C. MOTOR HUMS, BUT DOES NOT START—
Check for:
1. Centrifugal switch stuck in open position.or if capacitator start could be bad capacitator. Possible loose connection.
2. Binding of motor shaft. (something stuck in impeller) Does motor turn free. IF not check for jamed impeller. If it she sp2605x7 you can view a manual here:
http://www.haywardnet.com/products/Manuals/pdfs/manual113.pdf
Aug 17, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
Keeps coming error 1
Error 1 means the door is not closed properly. Could mean the door is not shut correctly or that there is a faulty sensor.
Try shutting the door and powder tray again.
Jun 21, 2008 | Haier Washing Machines
Proline W1000 washing machine keeps on triping main electrical switch
check for water leaks,unplug heating element,and try again.or the motor,then try again.
Mar 28, 2008 | Beko 24 in. D3421F Free-standing...
Washing Machines Logo
264 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
