Question about Ariston Technologies AW125NA 13 lbs. Load Capacity Washer
I have a dicon washing machine, when the wash is finish, I fell that the clothes have not been washed well, or clean enough, and of course you can not smell the nice clean sent of the detergent and comforter. although I changed the detergents more than once and I have excellent experience with the one I used before getting the current machine but not anymore. Why?? I don't have an instruction manual
SOURCE: Fabric softener compartment problem.
Squeee, It's been more than a year since you posted this so I guess you must know the answer. It sounds like a Visit from an engineer(?) I've got exactly the same problem with a Servis Easilogic 1500 and would appreciate knowing what you had to do to resolve the issue.
Posted on Jul 05, 2007
SOURCE: Kenmore He2 shoots out water from the detergent compartment
After searching the internet we discovered that if you slide your fingers in between the metal drum and rubber seal under the soap dispenser area you may find the problem. We had a sock blocking the water inlet. Problem solved! This machine is going to give us a lot of headaches but thanks to the internet we may be able to continue to save money fixing it ourselves.
FYI, I find if you leave the door open a crack after each wash... you avoid the mold smell as well!
Posted on Mar 01, 2008
  • 3 Answers
SOURCE: dryer
It sounds as if you have the dryer button pressed in before you start the wash! If you don't. it is likely it is stuck in or the switch is shorting out on the back. Unless you are a competent DIYer, find someone who is to check the electrical connections and test whether the switch is working correctly.
Posted on Oct 29, 2008
SOURCE: my washing machine is leaking water everywhere when rinsing
you are over filling it!!!!!!!!!!!!!!!!!!!! when you use the rinse cycle it just fills the washer up to get all the soap out of the clothes. try just rinsing less clothes then usual. if that is not the problem then on the bottom of your washer is either rusted out or there is a rubber seal that could be over used!
let me know if that helped at all
zac
Posted on Oct 31, 2008
SOURCE: Ariston "Margarita 2000" Model AL129X [front load washing machine] - Clean sludge from door seal.
Ariston "Margarita 2000 cpu map photo
Posted on Nov 20, 2009
Lost clothes in Whirlpool top load SM 8525492
There is NO way that any clothing fell over the top of the tub into the sides of the washer, Emily. NO way. It's nearly impossible to believe that you even had enough clothing in there to spill water.
If you stuffed it enough to force clothing over the top of the tub, then the agitator could not possibly have functioned.
Just for the... impossibility... that clothing DID spill over the top, to get them out you would have to pull the dryer out and remove the back and/or the top. You'd see the spilled clothing immediately.
No - no, no, no. I CANNOT believe you overloaded it that much.
Aug 04, 2014 | Whirlpool Washing Machines
I always wash in cold water and when a load has finished there is now a very unpleasant smell. I assume there is a build up somewhere. Should I do a hot water wash with washing liquid without clothes?...
Usually this happens when you do wash on cold water only.The soap will remove dirt but with it comes along oils and other stuff will be dissolved but is all concentrated down at the washers bottom.And since the water is cold the oils and scum will solidify as soft scum and of course they do decay in due time and then the smells come.Yes you are right you can just fill a small load of hot water only with a bit washing detergent and let it go through a cycle(without the laundry).Or try going to a store where this product is sold for cleaning washing machines-Tide,clorox and Magic washing machine cleaners.
Feb 02, 2011 | Washing Machines
The spin cycle on my washing machine is not working, the clothes are still wet when the cycle is finished
Make sure that the clothes are not too heavy ( jeans and sweats ), and put in the machine evenly. If the machine is off balance, it won't spin fast enough to wring out the clothes.
Oct 14, 2010 | Hotpoint Washing Machines
Washing not clean after wash
it is recommended that you clean a washing machine every six months. How you do this is get one of the fancy cleaning tabs available on the market or use a dishwasher tab. Put it in the soapbox no clothes in the machine and select the hottest wash. let it finish
May 24, 2010 | Hotpoint WMA46 Front Load Washer
When my bosch washing machine is finished its wash programme the clothes are very hot when I open the door
this sound like another thermostat problem its trying to boile every thing,,,change the thermostat first
Oct 23, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
White marks on my clothes.
Are you using TOO much powder? And is the machine set to the correct rinse tempature? You mention white stuff, does it look like undissolved washing powder? Or fabric softner? Possibly try liquid detergent and see if the problem continues. And follow the recommended amounts of detergent for each wash load, and the tempature settings. And of course the water levels. All of the above are crucial to insure you get maximum preformance and utility out of your machine, with the results you expect. Let us know what you find. Kindest Regards, Slats.
Sep 26, 2009 | Washing Machines
Some clothes not clean or even completely wet after wash cycle finished
Ebay item number 200262803398 is a cheap PDF service manual for this model.
prem
Oct 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage. Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
Jun 10, 2007 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
