Question about Apple eMac G4 Desktop
My emac,s screen is grey and full of letters!
    Scholar:
  • 109 Answers
P.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; min-height: 14.0px}
Check for a failing hard drive
Trying booting from the Mac OS X install disc.
insert the Mac OS X install disc.
press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
If you have repaired the permissions without any errors, you need to reinstall the Operating System.
Posted on Mar 02, 2011
Need to transfer data from old computer to new computer
You have a bad situation. Only a mac repair pro can help you in this case as it's hard to arrange some tools to solve the problem. A pro can gain access to your emac hard drive and free up some space or transfer your data using special tools and knowledge. Thank you and good luck.
Mac Repair Mississauga Apple MacBook screen repair Service MacBook pro...
Oct 17, 2014 | Apple eMac Desktop
Desktop E-Machine ET1161-07. Problem I have grey rectangle in the middle of the screen . It has a volume Icon with a range of volume from 0 to 100. It is showing at 100 (or full volume). I want that...
hold down alt+f4 and select the icon for the program that is giving the volume icon, make a note of the name of the offending program, then press alt+f4 to close the program. Simply go to add/remove programs and remove the program if you want to, or look in its options to disable the volume display.
Mar 08, 2011 | Computers & Internet
I have an emac G$ 700Mhz 128MB/40GB/Combo with two related problems: 1. On power up, I get a blank grey screen that, after a while, changes to a similar screen, except that at its center is a small...
I've never used a hair pin-- a straightened paperclip has always worked for me.
One alternate solution (if you have another computer available) would be to boot the eMac into target disk mode by holding T during startup. It should show a firewire icon on the screen, and should act like an external hard drive when you connect it to another computer via a firewire cable. You can use this method to install the OS onto the eMac from another Mac. You can try Googling "Target Disk Mode" if you need more information.
Nov 13, 2010 | Apple eMac G4 Desktop
EMac screen stays as grey screen whith swrling grey pinwheel-wont boot beyond that point?
Your best bet is to reset the System Management Controller;
http://support.apple.com/kb/ht3964
...and then reset the Parameter RAM:
http://support.apple.com/kb/ht1379
If it persists after that, try Safe Mode:
http://support.apple.com/kb/ht1455
...if that persists, try booting to your install DVD and running Disk Utility:
http://support.apple.com/kb/ts1417
..also note in this article that if for some reason you are unable to boot into your Install DVD the instructions for using fsck will do the same thing.
If that fails to resolve the issue, you'll want to reinstall the system:
http://support.apple.com/kb/ht1710.
If none of these steps resolve the issue, it will likely need repair at an Apple Authorized Service Provider or Apple Store.
Aug 27, 2010 | Apple Computers & Internet
Emac g4 1.25GHZ 256 wont read hard drive or cd drive
I take it you just get a grey screen and spining wheel when you try to start up
Aug 12, 2009 | Apple eMac G4 Desktop
My emac is on but the screen is dark and blank.
On the keyboad, above the numbers are the function keys. Depending on the keyboard being used, there is a key that changes the brightness of the screen. You can also go into your System Preferences under Displays and change it there.
Hope this helps
Verb
Mar 16, 2009 | Apple eMac G4 Desktop
Emac stalls on the OS X start-up
Start here...   Resolve startup issues and perform disk maintenance with Disk Utility and fsck  Mac OS X: How to start up in single-user or verbose mode  If that doesn't help, try booting into Safe Mode and see what happens, if it comes up hopefully another restart may solve, if not, you can at least use this as a starting point to try and resolve. Safe Mode will allow you to get around, surf, etc...   What is Safe Boot, Safe Mode?   Mac OS X: Starting up in Safe Mode
If Safe Mode comes up alright, I would install AppleJack, excellent troubleshooting article can be found here... Troubleshooting Tools: AppleJack  Another excellent free tool for performing maintenance is Onyx (be sure to download the right version for your system). Install the package, then run it, it will check your drive and the structure, after this, click on the automation tab and check on everything for Maintenance, Clear Cache, Cleaning, and check on Reset -> LaunchServices database and Mail's Envelope Index. When it completes, restart. Repeat any time something seems flaky, if not try to run at least once a month.
Feb 01, 2009 | Apple eMac G4 Desktop
Network a G4 (OS 9) to a eMac (OS X)
OK - first, crossover cables let you network PCs together without a switch or router. I would strongly recommend returning the crossover cable and buying a router so that you can use both computers on the internet at the same time.
Second, the eMac monitor can not directly be used as a monitor for your G4 - it's not built that way. However, you can use Screen Sharing on OS X (if both have Leopard) or Apple Remote Desktop software (if you buy it) to remote control the G4 using the eMac.
You will DEFINITELY need a monitor on the G4 in order to set it up at all, so I hope you have that.
Keep in mind that you can buy, for less than $200, an LCD screen that is larger and better quality than the eMac, and it would leave the eMac useful as a second computer. Since the eMac is unlikely to work at all with Leopard, and you'd have to buy Apple Remote Desktop, you're going to spend less money by buying a separate screen for the G4.
Nov 22, 2008 | Apple eMac G4 Desktop
APPLE MAC
How many beeps? DOES the white light flash? Whats the specific model?
Oct 29, 2007 | Apple eMac G4 Desktop
Apple eMac G4 Desktop Logo
82 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
