Question about Gale Moviestar 5 System
Hi ther i was wondering the max power i can put through my gale moviestar bookshelf speakers? i have them as mt main speakers on a sony av amp mod- TA-VE700
    Novelist:
  • 85 Answers
Realalema60,
The main speakers can handle up to 120 watts and the satellites about 60 and the center near 90. As long as the speakers are 8 ohm rated, you have no issues with your receiver over powering them so play away.
-Chris
Posted on Aug 13, 2010
I have a gale 3070 sub woofer. When I connect it to the power with no audio connection being made, the inner fuses blow. can anybody help
if a fuse keeps on blowing there is a problem with the amp, Take it in to be repaired, Or just get a different one, It will probally cost you less just to get a different one,
Nov 29, 2012 | Gale Audio Players & Recorders
Can you tell me model number of the speakers who compatible with my sony str-333s receiver.
HI,
Sony STR 333S have an out put power of 25W into 8 Ohms speakers. You can use any bookshelf speakers with an impedence of 8 Ohms.
Ok
Mar 06, 2012 | Audio Players & Recorders
Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
May 21, 2010 | Sony STR-DE675 Receiver
Can Bose accousticmass speakers (cubes) be used directly with any AV Receiver without the need for a network of crossovers?
yes you can use directly. Just connect the output of the speaker to the input of the receiver. it will work.
Take care.
May 18, 2010 | Bose 6-1/2" Direct/Reflecting Bookshelf...
My gale 3080 sub has a bad mains hum
Check that it properly grounded so that you don't have "ground loop hum" and that you have no power cords crossing other connections.
Oct 12, 2009 | Gale 3080W Subwoofer
I WANT TO SELL 4 MIRAGE AVS 200 AND ONE avS 100 SPEAKER. WHAT IS THE VALUE IF THEY ARE IN EXCELLENT CONDITION?
There is a set of 4 avs 200's on Ebay for ~$200 OBO so figure around there. Really though these are 10 year old bookshelf speakers so the market for them is pretty soft especially now that Polk and the other big names have affordable bookshelf speakers... (I'm just giving my set to a friend when I move this month)
Aug 08, 2009 | Mirage AVS 200 Speaker
Can I run 8 speakers and 1 sub through 1 1200watt 2:1 Sony Xplod?
asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
series; posative of one speaker to negative of other speaker and that doubles your ohms
parallel; posative to posative negative to negative and that cuts the ohms in half
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Wharfdale moviestar 70 speekers and sub
i have the same moviestars 70+ plus a yamaha rx-v750 put the crossover on the sub to maximum (left knob) volume (right knob) about 2/3 clockwise. change the crossover on the yamaha to anywhere from 80-120 ( the 120 will put more bass to the sub) if your yamaha has sub level/volume control set it higher, also if it has LFE/sub out set it to sub only.
Dec 17, 2008 | Wharfedale Moviestar 70+ System
Replacement speakers
You should be able to use any of the "bookshelf" speakers to replace the Front Left/Right and Rear Left/Right. I would go ahead and get a dedicated Center speaker. I bought a Pioneer center speaker and a pair of KLH 3-way bookshelf speakers at Radio Shack at low prices. I also bought a pair of Insignia 3-way bookshelf speakers. I put this all together with a Durabrand Home Theature system (dumping the satellite speakers). There is better range and a much fuller tone with these speakers versus the originals. Even if you hadn't lost the speakers, I would recommend this as a good upgrade.
Hope that helped.
Leonard
Aug 12, 2008 | Durabrand HT-3915 System
Gale Moviestar 5 System Logo
188 people viewed this question
Top Gale Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Gale Audio Player and Recorder Expert? Answer questions, earn points and help others
