Question about Toshiba Televison & Video
Instead of turning the TV on, the red light on/off indicator just keeps blinking.
  • Toshiba Master
  • 11,800 Answers
This is caused by the failure of the tv's power source. To fix that the tv must be opened, tested, the defective parts identified(most likely here the electrolytic capacitors, they have aged and are now starting to fail) and replaced. At least a basic knowledge of electronics is required. If you don't have it then it's time to call the repair men.
Posted on Aug 08, 2010
Tv shut off while watching tv and blinks with a red light
How many times the standby light blinks at one time of switch ON? These blinks are fault indications. You can get an idea about faulty section inside, by these blinks numbers. Just count it carefully and inform me by Fixya or just visit this link, which has details about the blinking codes to Panasonic brand Plasma TVs.
If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 27, 2013 | Panasonic VIERA Televison & Video
6 red blinking lights
You have a bad thermal fuse.
Oct 23, 2009 | Televison & Video
I lost my codes
USING THE RMC10 REMOTE WITH AN UNLISTED DEVICE.
MANUAL CODE SEARCH:
If your product does not respond after you have tried all the codes for your brand, or if
your brand is not listed, try searching for your code by following these steps:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then
release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red Indicator
blinks off once.
4. Face the remote control directly to the device you want to control (TV, VCR etc).
5. Press the ON/OFF button repeatedly (up to 300 times) until the device to be
controlled changes channel. The red indicator blinks off with each button press.
6. Press and release ENTER to install the code.
Most users will store VCR codes under the VCR button, Cable codes under CABLE,
etc. If (for example) you want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and press CABLE in step 2 of Direct
Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search (or Brand Search, below). Note: If the device does not
have a CHANNEL UP button, use PLAY (VCR only) or POWER instead. Code Search
starts from the currently stored three digit number under that mode.
AUTO CODE SEARCH:
your brand is not listed, try searching for your code by following these steps.
2 Press and hold the CODE SEARCH button until the red indicator stays on, then
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator
blinks off once.
5. Press the ON/OFF button down till the Red Indicator Light stays on.
6. The red led indicator will keep on flashing till your device (TV, VCR etc) turns off.
7. Press and release enter to Install the code.
CODE RETRIEVAL:
1. Manually turn on the device (TV, VCR etc) to be controlled.
2. Press and hold the CODE SEARCH button until the red Indicator stays on, then
release the CODE SEARCH.
3. Press the device control (TV, VCR etc) you want to control.
4. Press the CODE SEARCH button again and the red indicator should blink once.
5. Follow the sequence of (0-9)and press once for each number button until the
Indicator flashes one time.
6. Repeat the procedure 5 till 3 correct codes are confirmed.
7. If the red indicator light flashes, than you have entered an incorrect number, and
please follow the sequence (0-9).
also here is your manual. For your remote.
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
please rate me, or recommend me it will be most helpful in letting me and other know how im doing.
Oct 03, 2009 | Sentry SE-RMC10 Remote Control
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Sharp 19" LCD blinking red light
Your tv needs servicing, it has developed some kind of circuit malfunction. You can send it too me for fast repairs and return. Or find a shop in your area.
e-mail me...
Feb 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Jun 04, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
21 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
