My touchpad has stopped working and the only way i can properly use it, is by plugging in a computer mouse. The touchpad allows me to move the mouse arrow icon all over the screen, but when trying to select or highlight or click to open anything with the touchpad it wont work unless i plug in a computer mouse. and yes, i did check that the touchpad was turned on. I went into the mouse settings through control panel and it recognises both the touch pad and plug in mouse and says they are both working normally. Except, it isn't. Help?
  • 225 Answers
You can turn on "tapping" and will be able to tap instead of click. It seems like hardware problem. Take the computer apart and check the flat cable from the touchpad to the motherboard. Check with a mutltimeter whether the buttons are making contact on click.
Posted on Aug 08, 2010
What can I do I plugged in a mouse to my laptop and now my touchpad wont work
There will be a setting in the touchpad interface to allow the use of both.
Mar 17, 2014 | Targus Corded Mice AMU75US Compact Optical...
Mouse Pointer of Dell vostro 1014 laptop touchpad is working in reverse i.e. while moving finger on touchpad towards right the pointer move in left direction & vice versa
Hi, the laptop touch pads have an icon near the clock or u can find it on the control panel, there is a check mark that said" mouse reverse"or "mouse look up" or something like that,uncheck it to work properly and download the latest driver,
kind regards
Apr 17, 2013 | Dell Vostro 1014 Laptop Computer
Touchpad doesn't work
Step 1:
The touchpad of any laptop is always subject to heavy use.
Most touchpads are designed for their durability to sustain the daily wear and tear for the lifespan of the laptop.
However, there may be instances or accidents that cause the touchpads to malfunction or stop working entirely.
There are ways to troubleshoot such problems and there are also remedies to salvage the touchpad's functionality without heavy repair or replacement cost.
Determine What's Wrong
A laptop's touchpad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touchpad may be damaged by excessive use or foreign substances such as water, dirt or food items. Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return." Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touchpad to become unresponsive. But if any of these steps fail to remedy the problem, then the touchpad may need to be repaired or replaced. b> Repairing/Replacing Touchpad b> A touchpad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touchpad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touchpad is deemed a necessity, such repairs are rarely worth the cost. Attempting to replace the touchpad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop. Long-Term and Better Solution b> The simplest, and best, solution to a malfunctioning touchpad is to replace its functionalities with an external mouse. Most PCs sold after 2000 come with USB ports and getting a USB mouse either a corded or a cordless one--will remedy the problem. A cordless USB mouse may be bought for as little as $10 and some of the better-designed ones allow the user to tuck the USB stick inside the mouse's belly when not in use. Even when a touchpad is working properly, a laptop user should be advised to plug in a mouse anyway whenever possible as touchpads are notoriously difficult to use and also leaves the user in an ergonomically incorrect position.
http://www.microsoft.com/ b> http://www.streetdirectory.com/travel_guide/116002/hardware/touchpad_keyboard_for_personal_computers__pc.html
Feb 19, 2013 | Computers & Internet
Dell Vostro 1510 (Win 7) - Can't enable/disable the Touchpad
There is an option to disable the internal touchpad when you connect and external mouse. Please check the screenshot attached.
May 06, 2017 | Dell Vostro 1510 Laptop
My elan touchpad is not working. the mouse will not move unless i plug in an external mouse
There is a FN + Key (F9 for me) Hotkey to disable the elan touchpad on ASUS Laptops.
This might be the problem if someone activated it by accident.
Also the correct drivers might be missing.
You can get the latest drivers on ASUS Homepage
http://support.asus.com/download/download.aspx?SLanguage=en-us
Mar 20, 2011 | ASUS Computers & Internet
My laptop is working fine, However the touchpad won't work at all. it will allow me to plug in a mouse but the cursa will not move. What do I do?
Hi. Try reinstalling the touchpad driver of yor computer. For some computers you need to Press Fn + F6 key to enable/disable the touchpad. If this problem occurs recently then you can restore the computer back to the date from where you remember that the computer is working fine. You may use system restore. Click start then all programs then click accessories then click system tools then system restore.
Aug 07, 2010 | Computers & Internet
Laptop touchpad is left-clicking when it is touched.
hi,
Please reduce the touchpad sensitivity. that shld take care of teh issue.
inu
Dec 09, 2008 | Gateway MT3705 Notebook
Mouse/touchpad issues
Try to connect a external mouse.
If it does work ok with the external mouse . It means that their is a problem the touchpad.
Who can take it to a service center for repair or you can use the external mouse.
Thank you
Thewho1
Jun 29, 2008 | Computers & Internet
Compaq Presario V2000 touchpad/battery charging problems
I noticed you were talking about over heating issues. Does the mouse issue happen when the computer is on for a period time?
I know with some laptops there is software for the "gadgets" on the mouse pad. If you have software related to it.. try reinstalling.
I am getting mixed thoughts of what you maybe talking about... please explain.
Nov 13, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
76 people viewed this question
Alun Cox
David Payne
David Payne
