Question about LG 42LG30 42 in. LCD HDTV
The sound works although no picture. The screen tunes on but is all black. I've tried turning it off but nothing work.
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 17, 2010
  • LG Master
  • 8,457 Answers
The 2 long boards call the LCD inverter boards are dead.These 2 long inverters help the LCD screen to get a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverters for the replacement.
Can't Upload Pictures
Try putting the memory card in a USB card reader attached to your computer, which should see it as another drive. Write-protect the card first.
Sep 16, 2017 | Fuji Finepix T410 Black 16mp Digital...
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
Re, all i get is a distorted picture of the game screen. I've tried fine tuning the TV around that channel but it doesn't help.
hi sounds like the av sender inside the ps could be getting dodgy, have you tried it on another tv?
Apr 07, 2012 | Sony PlayStation (PS) Console
Technika 32-270 LCD TV won't stop scanning
Need help stopping scan on tv, won't turn on and no remote will activate anything on the monitor. Help flat screen tv.sanyo keeps on percenting
Dec 31, 2011 | Televison & Video
Hi. I have an ALBA LCD32880HDF television which I purchased in August 2009 so just outside warrenty. I have been on holiday for a week and had switched the television off at the wall and returned home...
hi all the black screen solution for me was this (this is assuming you have alba brand tvs and have the black screen BUT can still hear the sound) i after much fekkin around with it eventually found the solution in it (its the bloody backlight brightness in the settings you need to turn it from high TO LOW) ....... now this can be a bit tricky because usually when you have the black screen problem if u unplug the tv for a few hours and plug it back in you only get or should get probably like 30-1min of picture time before the picture goes black so u have to be reallllly fast with the menu button to get into settings before the picture dies (i learned the sequence for my alba lcd32880hdf) it was the following (for this part use the remotes arrows the one with the ok button usually in the centre of them) turn the tv on then click menu then press the up key 2 times then press ok then use the right arrow/button twice (although u cant see what ur doing ur navigating the menu hehe) then press the down arrow/button seven times before finally pressing the left arrow/button (once) <-- (now this bit may need to be done twice if you can remember setting ur backlight to max use it twice it will put it on minimum if in doubt only press it the once remember to totally power the tv off before repeating the steps to reset menus default posistions) remember thats the solution i found for my tv stands to reason (since i did infact buy another tv same brand different model which got the same problem) that this could be a solution for all alba tv users try it worked for me 2 times if ur not sure of the menu look up you tv models menu navigation online to find out the buttons you press gl hopefully it works for you too
Oct 24, 2010 | Televison & Video
I ve just opened the box and turned on phone.Nothing on screen!
send it back. It sounds like even if your were to fix this by taking out the battery and putting it back in, it should not do that new. Get it replaced ASAP
Aug 29, 2009 | LG Prada KE850 Cellular Phone
Black out
Try turning off the Closed Caption..
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Screen is blank although sound and lights are evident
Try removing and reseating your CPU, video cable and or memory. If nothing stills hapens, your video card or chip may have gone bad. Please let me know if this works.
Dec 13, 2008 | IBM ThinkPad T43 Notebook
LG 42LG30 42 in. LCD HDTV Logo
108 people viewed this question
