Question about Whirlpool ET8CHEXSQ Dryer
Just wanted to know what is a good temperature for the fridge, so drinks are not too cold? Many thanks
  • 251 Answers
Hi , ideal temperature is probably between 35F (1.6c) and 38F(3.3c)
38 is the standard pub temp for beer .
hope this helps :)
Posted on Aug 08, 2010
I have a small daewood refrigerator with icebox. If I want to lower the temperature do I increase or decrease the number?
Good question :>) You should always have a small thermometer in the fridge and freezer.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you need.
Refrigerator Temperature Control Dial What Do The Numbers Relate To Cold...
Mar 22, 2018 | Refrigerators
Ignis fridge isn't cold enough, and seems unable to maintain a constant temperature. I bought a fridge thermometer to get some accurate data: fridge is typically between 9 - 15 degress c. Generally, a good...
the compressor is acting weird because the fridge might need regasing if the tempreture
uness the fridge controls for the tempreture nside the fridge are buggered and the thermostat
Jul 05, 2008 | Refrigerators
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
What is the correct temperature for beer? Or wine. Or pop? Please
Hi Laraine:
Beer:
- If you're British, warm. Canadian, wet. Otherwise, who cares?
Wine:
- white - chilled, red - warm. If you're Canadian, wet.
-Pop - cold, but if you're Canadian, stick to beer and wine so....... Who cares?
Cheers
Jun 06, 2016 | Furniture
What should the temperature inside the refrigerator be, I have it set at 37
On the fresh food side you have it set at the proper temperature. Most thermostats have a scale from 1 to 7 or 9. If you set the thermostat at 5 this equates to about 37 degrees. Thermostat do lose sensitivity after a while and need to be replaces. The switch inside the thermostat wears out and the sensing bulb sometimes loses the fluid inside the sensor and the thermostat stops controlling temperature. So sounds like you have it set properly.
Oct 14, 2014 | LG LFX25960ST Stainless Steel French Door...
What is the right temperature for white wine?
For storage, 10c is fine. For drinking, put it in the fridge at about 4c
Apr 25, 2012 | Refrigerators
We have a Hoover No frost refrigerator/freezer. There is no control for the fridge temperature which is now running very cold (it freezes drinks, etc.). What can I do to increase the temperature of the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 16, 2010 | Hoover HCA391FFK Bottom Freezer...
Freezer and Fridge temperature not very cold
I can find only one good reason why your refrigerator may not be cooling. There is a control board inside the fresh food compartment and no signs of a defrost timer. If there is someone that go through some test to eliminate other possible problems would be good. If the refrigerator is still running, unplug and open the freezer compartment. Remove the back panel so we can have a look at the evaporator coils. Clean or are they frozen with a large piece of ice? Let me know, Thanks Sea Breeze
Mar 23, 2009 | Maytag ZigZagW / B Side by Side...
I have a samsung fridge, model # rs-2545sh
check the cold for what you want but the ideal settings would be 5 for the freezer and 37 for the fridge
freezer can be really cold but the fridge if too cold will freeze vegetables and lettuce
Jan 03, 2018 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool Beverage Center (WBC127BLS) - Won't cool enough
If you're handy with a soldering iron, it's possible to 'trick' the fridge into cooling down a few more degrees.
Long version:
If you open the door to the fridge, on the right wall near the bottom is a small plastic grate. You should be able to pull this straight out from the side wall. There is a temperature sensor attached to the back of the grate. Unplug the sensor. (The fridge will then give you a very annoying error beep and display "EE" on the readout. Pushing the °F-°C button stopped the beeping.) This sensor will change resistance with temperature. (The lower the temperature, the higher the resistance) I was reading a resistance of about 3700 ohms at 43°F and 2460 ohms at 68°F. Throw in a rough assumption that the response is linear and it works out to almost 50ohms/degree. In order to 'trick' the fridge into cooling down more, you need to drop the resistance. I was aiming for about 6 degrees cooler. Assuming the resistance response was linear, 6 degrees cooler would give me about 4000 ohms from the sensor. By jumpering a 50000 ohm resistor (yes, 50K ohm) in parallel with the sensor, I should get about 6 degrees cooler. I did the soldering, plugged the sensor back in, and ended up about 8 degrees cooler. Two days so far, everything appears good and the beer is cold.
Short version:
Put a 50K ohm resistor in parallel with the temperature sensor behind the grate on the inside right hand wall.
The temperature read out will be inaccurate forever after though. But then, I just want cold beer, my wife wants cold water, and the kids want to play with the cool blue light. I don't care what the number on the readout is.
Oct 03, 2008 | Refrigerators
Whirlpool ET8CHEXSQ Dryer Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
