Question about Whirlpool AKZ159IX Oven
Used our Whirlpool AKZ451 last night and everything was fine, but this morning, the small centre button on the front panel will not press. All the dials are set to '0' and the screen displays STOP. Usually you press the cente button and then you can select what mode you want, but it won't do anything now and so we cannot use the oven at all. Anyone know what the problem is?
  • Alan Bell Aug 24, 2010
    Yes I did.
    Behind the clock button is a spring, and behind this spring is a little red button. For some reason, the spring wasn't moving anymore and so the contact with the little red button was not being made, and therefore the whole oven was not coming on.
    If you remove the top panel and slowly pull away from the oven, you should be able to remove the button from the front. What you will be left with is the little red button, press this to see if the oven still works.
    I had to visit the Whirlpool website to buy a replacement, cost me nearly £30 :os
  • 4 Answers
My button didn't work, i had a look and water had got in and crusted up the switch, i scrapped off and a bit of WD 40 (or switch cleaner spray) and it was fine. make sure POWER is turned OFF to be on the safe side.
The switch is the same as the one's used in your computer mouse, but you would need a soldering iron !
Posted on Jun 19, 2012
    Problem Solver:
The same has happened to mine. i used it last night as usual and this morning the button just wont press?? did you manage to find out what was wrong?
thank you x
Posted on Aug 24, 2010
Whirlpool oven AKZ451/IX/01 display has intermittent display. How do I change it?
Open the oven door and look at the underside of the control panel.
Oct 19, 2014 | Whirlpool Ovens
My AKZ451 oven has stopped heating up. The grill, light, fan is working fine.
You need to replace the oven element, located at the rear of the oven compartment, behind a removeable cover.
Oct 30, 2010 | Whirlpool AKZ159IX Oven
The oven works fine as in it heats up but when turned off the cooling fan keeps going...used it last night and this morning the fan is still on...turned oven on and it is heating up but as I said the fan...
most ovens use a cut in limpet themostat(sometimes called button stat) typically normally open and closed at 40deg c. it will be this that will be not resetting to the open position at room temp. on rarer models the timer controls the cooling fan. some models of aeg and electrolux have a thermal delaying device located in abulb in the wiring loom. hope this helps
Aug 02, 2010 | Ovens
My Whirlpool AKZ451/IX/01 will not heat up correctly
I can fix this for you. Where are you residing please? Thanks David. "The Famous Forry'
Oct 20, 2017 | Philips Ovens
Whirpool Accubake Control Panel
try turning power off and wait 10mins and see if it resets.
Sep 14, 2009 | Whirlpool RBD305PD Electric Double Oven
Cold Whirlpool AKZ451!!
You may have had a surge during the storm. Check main control board in console for damage.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 01, 2009 | Whirlpool AKZ159IX Oven
Whirlpool - akz451/ix/01 - Fan oven blowing out cold air
could be a blown element if not it could be a safety cut out or the stat
May 17, 2009 | Whirlpool AKZ159IX Oven
Whirlpool AKZ451 oven not working properly
If the fan is still working ,then you need a new oven element fitting, it will have blown, there by causing trip to operate.
Plz rate this solution .
Thanks.
Dec 12, 2008 | Whirlpool AKZ159IX Oven
Whirlpool AKZ159IX Oven Logo
196 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
