Question about Pride Mobility Products Health & Beauty
I have a 610 qantumn powerchair,all of the lights are flashing when i turn on the controller and the chair will not operate.can you advise what the fault might be.thank you.
  • 692 Answers
The chair could be in freewheel and will not work until you move the levers to drive position. Or you could still have the charger still plugged in Hope this helps
Posted on Aug 17, 2010
Shoprider Powerchair has full charge and turns on. Once I touch the joystick it shuts off. No flash code is present. Verified all connections. Replaced joystick, problem still occurs.
Hi , when you say shut off, you mean like it been turned off ? if so check the connector going into the controller , the issue could be with the controller connect, not the joystick end if it's been replaced...
Regards
Rob
www.gewizrepairs.co.uk
Jan 21, 2014 | Shoprider Streamer Sport Power Wheelchair...
Catalina powerchair 8 wrench flashes
8 flashes on a invacare means controller fault,please contact dealer,and have a tech look at first so they can ordor u one,recomdation take chair to dealer if u can will save u money on a house call
Dec 21, 2013 | Electric Mobility Pronto M41 Power Chair...
Issues with Streamer Sport Model 888WA power chair
please can you tell me how ofter the light's flash ? does there appear to be some kind of sequence ?
Dec 09, 2012 | Shoprider Streamer Sport Power Wheelchair...
How to reset controller on jazzy power chair
yellow light is flashing and i can't turn chair off. still operates.
Jun 20, 2012 | Pride Jazzy 1103 Ultra Standard Power...
Quantum 610 error #107 Charger Inhibit
I just had same code. I took off rear cover and unplugged a rubber cap at the end of a long skinny group of a few wires. looks like a charging wire kinda. and unplugged the main plug. I did not unplug the two larger battery plugs. when I plugged them back in firmly everything was back to normal.
Mar 03, 2012 | Health & Beauty
Our church has 2 Jazzy's one is blinking the code all lights flash 7 times the other 9 times all lights flash can not find what I need to do in our book. Can you help is there a web site I can get a...
mtp see the below list
The listed Flash codes are pretty standard and are applicable to powerchairs only not scooters:
1 flash User Fault (do not touch joystick) and turn back on
2 flashes Battery Fault Recharge batteries or replace
3 Left motor fault check connections or replace
4 Right motor fault check connections or replace
5 Left park brake fault check freewheel lever or brake connections
6 Right park brake fault check freewheel lever or brake connections
7 Remote fault check connections and wiring replace remote(joystick) (Check cable to the joystick unplug connector at rear of chair and plug back in then try turning on to see if you are getting same code)
8 Controller fault Check connections and wiring replace controller
9 Communication fault check cable replace (almost same problem as 7) try same fix if doesn't work joystick will have to be replaced
10 and 11 are unusual and will not be seen if at all Hope this helps you
Apr 04, 2011 | Pride Mobility Products Health & Beauty
Powerchair doesn't move 1 red light blick's on the leftside of VSI
John,
This flash code indicates that the battery needs charging or there is a bad connection to the battery. Check the connections to the battery. If the connections are good, try charging the battery.
This flash code can be seen at the following link:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
With the battery voltage too low the chair will not move. Hope this helps.
Jan 08, 2011 | Jet 7 Portable Power Chair
1 red and 3 amber lights flashing after stopping and goes around in circle on a jazzy 1121 powerchair
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
Try to reset your manual brake release as this is a common problem.
The powerchair going in circles may indicate a motor is bad and needs to be replaced.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Aug 23, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Shoprider nippy powerchair when i switch it on lights on control flash and it keeps beeping
Here are some ideas :- Is the charger disconnected from the chair, are the brake levers in the drive possition. do the batteries need charging. Failling that it could be a controler fauld so you will need to consult an engineer.
Apr 30, 2010 | Electric Mobility Shoprider Electric Power...
Pride 1121 wheelchair led 8bars flashing wont unlock batteries new ,the connections good. had just unloaded it ran it over a bump then it started flashing. Controler is bad or what? contiuity from motors...
trent618,
The 8 bar flashing lights indicate a possible control system trip. Without a serial Number or knowing which controller system you powerchair has, I will cover the common used controller systems for the model of powerchair you have.
If you have the Pilot or VSI control system the control system detects an internal problem within its self or the joystick, and I've seen it a couple of times when both the controller and joystick have an internal problem.
If you have the Pilot + or VR2 control system the control system detects an internal problem within its self and/or the joystick and/or a communications error between the joystick and controller. I've seen it once when the controller, joystick and cable between the joystick and controller being deffective. Due to the flashing lights and you have a Pilot + or VR2 there is a good chance the problem is the cable between the joystick and controller.
The possible solutions and repairs above will require the need for an authorized person to perform the tasks. Give the company that sold you the power chair a call, or anyone or different company which works on power mobility products as the part(s) needed will only be sold to authorized deallers or service providers.
Hope this helps, if so, please respond to this solution which will help others who may have the same question.
Thank you for using FixYa.
Flavadave75
Feb 15, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Health & Beauty Logo
56 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
