Question about HP Compaq Presario V2000 Notebook
I have a problem with my compaq presario v2000 that when i start my laptop it gives error with blue screen hardware malfunctioning call your vendor for support nmi: channel check/ io check plz guide
  • 624 Answers
Hello and Welcome to FixYa!
This behavior can occur if a hardware component malfunctions, or if there are damaged or incompatible drivers installed, Try these advices;
  • Remove any extra memory modules that are in the computer, leaving only the least amount that is required for the computer to start and run Windows. Restart the computer to see whether the error messages persist. You can use this utility to diagnose the Memory Module.
  • Remove any adapters that are not required to start the computer and run Windows. In many cases, you can start your computer with only the drive subsystem controller and the video adapter.
  • Verify that you have installed the latest revisions for your computer's BIOS or firmware configuration software. Go into the BIOS and set load Fail-safe defaults or BIOS defaults, disable any antivirus protection in the BIOS, and then set Plug and Play OS to No.
  • If the Error is still there, better contact the Vendor's to save yourself from further loss.
I hope this will give you a bit clearer picture, and an insight to the problem.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
Posted on Aug 08, 2010
  • 225 Answers
It seems like a hardware problem with the motherboard. Just in case you try the following:
1.Wipe with rubber the contact plates of the RAM and test it with GoldMem. In case of a faulty ram any false error may appear.
2.Test your HDD with MHDD. In case of a bad sector, part of a very important OS file can lead to similar errors.
3.Reinstall clean operating system
If this cannot help, replace the motherboard. The partnumber is on a sticker below the ram or on the connector of the ram. Search it on ebay.
4 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: drivers for HP Compaq Presario V2000 laptop
you can download drivers from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&lang=en&dlc=en&product=500508&
may this help,
melnavz
PS:pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on May 22, 2008
pls send compaq notebook presario v2000 audio driver
Posted on Sep 20, 2008
martyshaw152
  • 157 Answers
SOURCE: HARDWARE MALFUNCTION
Hello sumeetbapu,
Here are 2 suggestions which might be helpful in determining the cause of the nmi error:
• 1. Use the Windows Memory Diagnostic tool to test the RAM on your computer:
http://oca.microsoft.com/en/windiag.asp
• 2. Review this article from Microsoft Developers Network: What does an NMI error mean?
http://blogs.msdn.com/b/oldnewthing/archive/2007/02/27/1769274.aspx
Finally, you may need to replace a memory module. If you need help with replacing the memory, please be sure to ask.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Posted on Jul 07, 2010
When i switch on my compaq presario V2000 laptop it beeps three times and then freezes giving me the option to press f1 or f10 but when i press f1 or f10 it still doesn't work and is still frozen
Hi....
Actually beep sound indicates hardware error or BIOS error.
Don't press F10 while starting.
Let your laptop to start wait for 10min....
If it will not starts..........
Press F1(BIOS Settings for some pc F2 is Bois Setting)
If it will load BIOS.......... then your BIOS is OK
Then you need to change hard disk...
If not you need to change BIOS hardware(IF you i will tell you the way restore BIOS but it's very difficult task.It needs a trained person.)
Thank you have a nice day............
Feb 06, 2011 | HP Compaq Presario V2000 Notebook
I have a compaq presario v2000 and the wireless assistant wont open at all, my blue wifi light wont come on when i click it, and i cant even find device manager
The Compaq Presario v2000 came in many different releases. Underneath the Laptop, the model number will be displayed, and is usually like v2xxx, where xxx is 3 different numbers.
Find this model number, and then enter on this web site:
http://welcome.hp.com/country/us/en/support.html
Download the drivers for the hardware that is giving you trouble.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 26, 2010 | HP Pavilion dv6000z Notebook
Compaq Presario V2000 laptop stuck on compaq logo screen
when turning on the system go into the BIOS and reset back the seeting s to factory defaults and reboot the system .. If this fails then reseat the Hard drive may have come loose or ?
did you recently add new software ? drivers ? hardware?
Oct 14, 2009 | HP Compaq Presario V2000 Notebook
Presario v2000 keyboard issue
well you just might need an external keyboard or just pray for the miracle. i hope you are a christian
Sep 16, 2009 | HP Compaq Presario V2000 Notebook
My compaq presario stays on the 1st screen that says COMPAQ and will not change screens no longer how long I wait.
Pull out your hard drive, it is probably stalled on a malfunctioning piece of hardware. Once you pull the hard drive out, try to boot it up. It should say something like No OS found.
If this doesnt work, repeat but try the RAM, wireless card, battery, etc.
If none of these steps work then you will need to replace the motherboard
Aug 02, 2009 | HP Compaq Presario V2000 Notebook
Using XP OS CD Writing gives Blue Screen Death in CompaqV2000
This could be a virus, but try reloading the drivers from HP at
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=432985
It the problem does not go away after loading the CD-ROM drive, let me know and we'll discuss the next steps.
Apr 30, 2009 | HP Compaq Presario V2000 Notebook
Compaq Pressario V2000
If you know how ?reset the memory and restart the computer
at the boot press F8 if the menu appears try last known good confiuration that worked if this does not work you need to format and reinstall the os the blue screen is and indication of driver failuer or hardware conflick and if the system.last good config will only work 1 time after that it will wipe out the os and you will have to restore from the restore disk,and the best way to do that is to reformat the drive and do a clean install ,but if you have windows there is a restore mode your disk will say press F2 to restore now
Mar 28, 2009 | HP Compaq Presario V2000 Notebook
Cannot boot up computer
if you notebook is in warranty ....call hp and they will do some troubleshooting steps and they will fix it foryou .....
run hdd self test from bios and then call them to save time
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
Give free driver of presario v2000 laptop
Compaq Presario V2000T: download here.
Compaq Presario V2000Z: download here.
Jan 16, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 boot problem
Bios is not on an hard drive, is on a memory chipinside computer. Your main problem is not with Bios, but with system.
On many Compaq you can start the recovery tool by pressing f10 or f11 on startup. The system recovery tool it is located on hard disk, if it does not start it had been deleted or is damaged.
In your case Windows is corrupted, that is the reason why it is freezing , and then giving the blue error screen.
You need to get a Windows setup disk and reintall Windows. If you install windows from a generic setup disk you will need to install drivers after installing.
Drivers can be downloaded from HP website.
Another solution is calling the phone number listed on the user manual to contact HP. you can buy from them an original recovery CD, in this case you won't need drivers.
Otherwise you can ask a quote to a local repair shop for a system reinstall, I think it is about $80.
Sep 02, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
