Question about Hotpoint Refrigerators
I have a Hotpoint HTS 2866 fridge and get water leaking from the back left of the appliance. Inside the fridge seems OK (no water build up) and all seems to be working OK. Advice please Thanks Glyn Davies cathandglyn@live.co.uk
    Problem Solver:
  • 14 Answers
Check your connections at the water valve.
Posted on Aug 08, 2010
Water leaking from inside the fridge
Clear ice build up from drain plug using hot water in a syringe. Works well I just did mine. Located behind access panel inside fridge. Blue tube running down the back. Pull down and remove ice from the drain at the top.
Jun 22, 2010 | Refrigerators
Intermittant water leak front left hand side and ice build up on inside base of freezer compartment, but no evidence of water leaking out from door it seems to come from underneath the appliance.
Sounds like the drain hose from fridge unit to evaporator pan built on top of compressor is plugged. The drain holes are small and clog easily. I like to make the holes bigger. A pipe cleaner helps to clean the inside of the drain hose.
Make sure water is dripping onto evap tray.
Nov 25, 2009 | Refrigerators
Got water leaking from bottom of fridge/freezer on the front left side,also ice build up inside of freezer at the bottom.dont no if these are linked
If you take all the drawers out of the freezer - you will find 8 screws with 'bolt type' heads - 2 top, 4 at sides and 2 to the bottom.
Turn the power off. Undo all these screws and remove the rear panel. You will notice the 'gubbins' of the freezer. At the bottom you should notice there is a shaped plate with some piping running around and then up into the cooling 'radiator'. Towards the middle left of the plate there should be a hole - this is the drain hole. Is it blocked with a 'slug' of ice! Yes is my guess. This needs defrosting as will the rear panel you took out by any guess.
I did ours this morning as the fridge freezer was making a heck of a racket. Took about 30 minutes with the wife's hairdryer - and I'm no expert.
I just enjoy the fact I'd probably saved £50 plus on a callout.
Jun 13, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Water leaking from refrigerator
hi thanks for the question you can, remove the spout use a flat screw driver and pry off . now clean it pull fridge away from the wall remove the drain tube from the back clean reinstall thanks the appliance doc
Sep 28, 2008 | Refrigerators
Hotpoint ffA71
ffa71 fridge and freezer warm and food defrosted. red light is on. Back of freezer making normal noise. Help.
Aug 27, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
GE side by side leaks water onto floor, no ice
There is a pipe that runs up the back of the appliance and feeds the ice maker , if this freezes inside then it canpush the fitting off the back of the appliance and cause water to go everywhere. Usual problem is a leaky watervalve causeing water to drip into the pipe which freezes and builds up until it is totally blocked.
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint RLA54 fridge
Under charge of refrigerant is one of the ice build up in the unit, but try the defrosting method and after all ice are gone operate the unit and check vents if air is present. If no is air present inside the unit may be the blower motor inside has a defect. Its either stock up, burned, or worn out bearing
Mar 04, 2008 | Refrigerators
Freezer compartment
You need to defrost the whole fridge and at the back in the freezer compartment you will c a small drainage hole.. look for it.. The get a piece of say hanger wire and clean this pour some hot water from a kettle down it and then start your fridge up again. that should sort your problem out ... if not then its either a sensor or a board fault...
Dec 03, 2007 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Nov 04, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
136 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
