Question about Bosch WTE86300 Electric Dryer
My dryer has a build up of water and give an F03 error. What can do to fix it?
  • 4 Answers
Have owned the same dryer for about a year and just started having this F03 problem. The condensation drain hose is the soft flexible rubber hose coming out of the back of the dryer and it drains into the same drain as a washer. It's easy to pull the hose off its connector at the back of the dryer and just blow hard into it to make sure there's no lint clogging the hose and reconnect it to the dryer. Next open the panel on the left of the dryer and thoroughly rinse (water only, no soap) clean the two parts behind the door (first is plastic and behind that is the condensation filter which probably is loaded with lint). Sometimes the lint in the condensation filter channels (those that run from front to back) can be quite stuck. Use a long pipe cleaner to get in there or a garden hose with a spray nozzle. Shake the excess water out of the condensation filter and dry off the outsides of two parts. Clean all the lint out the compartment where the parts go. There is one more crucial step not mentioned in the manual. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver or a blunt table knife under the panel and gently pop it open. Under the panel is a small chamber that you can't see very well where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Use paper towel to get it all out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place as well as the condensation filter and the plastic part. Take out the lint filter (within the dryer drum compartment) and wash it with soap and water. Use an old toothbrush or something to clean the screens thoroughly. Rinse well and dry it completely. Clean all the lint out of the empty compartment. Put all three parts back into the dryer. Clean all lint off the door. Using paper towel moistened with white vinegar clean the two metal sensors in drum compartment on the front wall and lower left. Run the dryer empty but with heat on for a few minutes to make sure all the water is drained out. Now try drying a load. I think it's a good idea to rinse clean the condensation filter at least once a month since it collects a lot of lint. Hope this works for you.
Posted on Nov 09, 2010
  • 1 more comment
  • bellor01 Dec 19, 2010
    Just an update on my previous suggestions listed above. Eventually F:03 came back and more frequently. The hidden chamber described above had no lint but would fill with water and dryer would give F:03 error. I discovered a small pump that is not documented in any of the user or service manuals. This pump is supposed to empty the chamber via the condensation hose in the back of the dryer. I replaced the pump 2 months ago and the F:03 error has disappeared altogether. If any of you that are technically inclined and wish to replace the pump, it can be purchased from just about any online appliance part store. Search for the pump model number directly (640456) as it will not be found by looking via the dryer model number. I paid around $45 and have seen it as low as $28 on ebay.
  • vivavivian Jan 22, 2011
    How did you go about replacing the pump?
  • Rick Bello Jan 25, 2013
    Hopefully the last update on this topic. Several months after replacing the pump the F:03 error returned. I removed the pump once again and looked over things. There was no obvious collection of lint blocking the pump and nothing obviously wrong with the pump. Upon closer inspection I noticed I fine "ring" of gelatinous material around the pump intake. Keep in mind the intake sits just a couple of millimeters above bottom of the hidden chamber. I removed the "ring" and re-installed the pump. The F:03 error was gone again!!! It has since happened a couple more times. Knowing how the pump is situated in its chamber and how to reach the pump and chamber from the front access panel, I am now able to clean out this gelatinous "ring". The easiest tool for this is a wooden coffee stirrer from Starbucks. Simply break it in 2 pieces as it is too long otherwise. Remove the panel behind the condensation filter as above. The pump intake can barely be seen towards the left. Place the wooden coffee stirrer flat on the bottom of the pump chamber. Slide it under the pump intake and sweep it side to side. Remove it and look carefully. You will see some gelatinous material. That stuff is what causes the F:03. Replace all the parts. Hope this works for you. At least if it happens again I won\'t have to take my dryer apart.
Just replaced motor on the Aquarius hotpoint
F03 Front thermistor open or
short circuit.
• Check security of module connector J12;
• Test from connector pins (approximately 500 Kohms);
• If open or short circuit, test thermistor and wiring between
thermistor and J12 to locate fault.
Sep 16, 2014 | Washing Machines
How to fix recurring F09 error in Bosch condensing dryer WTE86300US
How long is the connection including the duct work in the house?
Jul 31, 2014 | Bosch WTE86300US Axxis Electric Dryer
F03 DISPLAY ON MY NV-SD300 PANASONIC
go to panasonic.com/vcr and give them the model/serial # and ask what the F03 error code means and they can give you a solution for the problem.
Jerry
Aug 27, 2012 | Panasonic Televison & Video
Error code F03 flashing and beeping
hello,
what this error F03 code mean is an indication of over flow of water from the sensor reader temperature which might cost a chance of loose wire connection on the water temperature.
what you are to do to fix up the problem is to open (unscrew) the washer and then fix up the wire that have loose it position then clean up all liquid around the wire and the panel and (screen).then couple it pack make sure all power supply are OFF before doing this .
thank you.
Jun 12, 2010 | Bosch WFMC 3200 Front Load Washer
Dryer stops and bips - message F03
03 indicates as a rule that the alloted drain period has elapsed. Usually it is a pump failure or a blocked (or partially blocked) drain out system? You say you have cleaned out all the hoses and replaced the pump, well now it's best you just run a test to see how quickly the machine empties? In fact it should be less than 60 seconds and if it's slower than that I guess you've got a button or something blocking the drain outlet somewhere and acting as a gate valve no doubt.
The other thing you could check whilst your at it is the air chamber at the back of the tub. White clear plastic bottle above the motor, if that is gunged up you could get spurious error warnings like F03?
Feb 27, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Front load frigidaire washer w/ error code F03....doesnt want to drain. Tried spin/drain, delicates, and normal and all end up with F03!! Please help!!! Thanks Royce
The F03 code is a problem with your water system. your inlet valves may have failed.
Open up the bottom panel and you will find a tech sheet that explain the codes and gives trouble shooting techniques. here is the service manual, good luck, hope this helps......
http://frigidaireservicetips.com/pdf...icControls.pdf
Jan 06, 2010 | Frigidaire GLTF2940ES Front Load Washer
Panasonic DMR-EZ47V Error Code F03
I saw this same issue. I would unplug and plug in the DVD and it would still show error code F03.
It turns out that one of my kids had shoved a couple of small objects inside the VHS opening and it was blocking the operation. I removed the objects and it works fine.
This error code is not listed in the manual that came with the DVD player.
Dec 21, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hotpoint CTD80 Tumble Dryer F03 error
hiya
sounds like you will need a thermostat kit and possibly a heater unit, if your getting them shipped to oz you will probably use them. i would change the thermostats first as this will more than likely be the cause.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj.
p.s if its still broken this time next year i'll come and have a look just waiting of my visa :)
Jul 24, 2008 | Hotpoint Aquarius WD63 Front Load...
Wd640 hotpoint washer dryer - error code F03
This indicates that the wash thermistor is "Open Circuit" and I think it is situated on the heater assy at the back of the machine.
Check the wiring and contacts between the thermistor and the PCB. If you still get the fault it could be the Thermistor ( which means replacing the heater ) or a faulty board.
If it is under 5 years old - Call Hotpoint as you have a 5 years Parts Guarantee mind you the call out is £89.98 but thats cheap if it happens to be the board!
Mar 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Bosch WTE86300 Electric Dryer Logo
1,099 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
