Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint BF1620 eco light stuck on eco and unable to move it, also not washing
  • 351 Answers
SOURCE: Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Posted on Mar 23, 2008
SOURCE: Hotpoint BF1620
hi i had the same problem and what i did was started putting the tablet on the top shelf, making sure it didnt fall through and never found an undissolved tablet since, but we shouldnt have to do this!
terry
Posted on Apr 27, 2008
SOURCE: hotpoint dishwasher bf1620 - 1st
Posted on Jun 02, 2008
SOURCE: hotpoint bf1620 dishwasher flashing light fault
Hi ,When this happens I keep the button with the letter "P" Pressed until the fault lifgt resets,my row of buttons is inside the top edge of the unit.
Posted on Sep 20, 2008
SOURCE: hotpoint fdw60 eco error code
I would like to thank Philhusbands for his advice on flashing eco light. After being told by hotpoint i would need an engineer plus call out fee. i decided to take a quick look on internet & to my surprise found this artical. So after reading it i did as advised & tipped my dishwasher to one side low & behold water came gushing out. After several minutes of mopping tried selecting programme again & it's working !!Yippee so than you who ever you are.
Posted on Nov 08, 2008
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
Door on Hotpoint Diswasher BF1620 won't shut
To better assist you I need the Hotpoint Model n serial # look like this;
HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher HLD4040NSA Hotpoint® Built-In Dishwasher HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher
Let me know wish one is yours.
Thank you
May 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
May 07, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Failed to complete cycle.
Probably blockage in pump or sump hose from drum to pump.
Remove and clean.
Nov 22, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Eco and Fast lights flashing
I had a hotpoint engineer try to fix this type of problem.
He insisted that there was something stuck in the bottom of the pump.
Sure enough there was.
1. Unplug your dishwaser at the wall.
2. Remove the grill under the bottom rack.
3. Ensure that the filter is free from food and other obstacles and clean the filter.
4. Before replacing filter etc, get a piece of metal coat hanger wire and care fully insert it down the channel under the filter to free any lodged items. You may also see a small white impleller try to turn this with your finger or the coat hanger wire (this is the info from the engineer!).
5. replace filter and retry a wash.
This routine fixed or machine twice and will hopefully fix yours!
Don't forget to rate me!
Jul 04, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Mar 21, 2008 | Dishwashers
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
127 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
