Question about Refrigerators
Maytag fridge freezer gc225pekw freezer is on highest setting and not freezing
    Genius:
  • 1,622 Answers
HI,
A freezer is great for storing additional food that may not fit in your fridge freezer. If your freezer stops working, it's important to be able to troubleshoot it quickly so that food waste is kept to a minimum. Keep the following tips in mind if your freezer stops working. Check the Electricity If your freezer doesn't seem to be working at all, check the outlet that the freezer is plugged into. Unplug the chest freezer from the wall and plug something else in such as a lamp or digital clock. If the new appliance doesn't work either, you know the problem is with your outlet and not your freezer. If the appliance does work, you will need to refer to other troubleshooting methods. Inspect the Relay The relay is a component that helps power the compressor. It is housed in a plastic box with the motor terminals and the overload protector and is connected to the Compressor; the relay is the largest component in the box. Closely inspect the relay and make sure it is not burned out. The relay can also be tested using a multimeter. If you see any signs that the relay has shorted out, you'll will need to replace it. If the relay makes a rattling sound when shaken, this is also a sign that it has shorted out. Examine the Compressor The compressor is essential to the performance of your chest freezer. It is the motor that powers the entire cooling system and if your freezer has ceased to work, you need to check it. This unit is located at the back of the freezer and sits in plastic housing; it can be identified by its football shape. You can tell that the compressor is broken if your relay is fine or if you hear a light hum followed by a clicking sound and silence. If your freezer is relatively new, it might still be under warranty and you could get a replacement compressor for free. If not, your compressor will need to be replaced by a professional. Investigate the Thermostat The fact that your chest freezer is not working could be down to the thermostat. This is the unit that regulates the temperature inside the freezer. To test your thermostat, remove the access panel on the side of the freezer. Next, use a screwdriver to remove the actual thermostat from the inside wall but do not disconnect the tube that runs from the unit into the freezer. Set the range scale on Rx1 on your multimeter to test for continuity. If your multi-tester reads continuity, your freezer problem lies in another spot. If your multi-tester does not read continuity, it means your thermostat is not working and you will need to replace it. Remove the tube from the old thermostat and attach it to the new one. Screw the new unit into place on the freezer wall and make sure the tube is not coiled or kinked as this will prevent the new thermostat from working properly.
Take care.
Posted on Aug 08, 2010
The fridge part strugles to get temp below 45 with thermostat set to highest level. The fridge has plenty of ventilation
There's probably something wrong in the freezer, that's where the cold air comes from. Check the temp in the freezer, it should be at least +10F.
Feb 23, 2011 | Maytag MSD2756GES Side by Side...
My freezer wasn't defrosting and the fridge wasn't as cold as it should be. I emptied it out and unplugged the fridge for 2 days and plugged it back in. Settings for freezer and fridge are on the highest...
hi how are you...please turn down setting to original setting from factory...in the freezer,does the back panel have ice on it....if so you have defrost problm...if not remove panel...if one one place on coil has ice ,but not whole coil...then has a freon problm....allow 24 hours for settings to readjust....hope this helps...good luck...michael doctor airr appl.repair..843-384-8474...call if need assistance...good luck...
Mar 26, 2010 | Maytag MTB1956G Top Freezer Refrigerator
Fridge freezer HNMF2805-80. fridge is freezing
isnt that the highest you could put it. how about taking it down to 1 or 2. it should say on the nob.
Jan 28, 2010 | Hoover Refrigerators
Refridgator too cold and on highest setting
i'm guessing your fridge is over - packed with alot of food - i found if i made more space - temperature returned to normal cooling.
hope this helps
marneypants
Oct 02, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
I have the same problem.
test thermostat. when fridge is running, turn dial to lowest setting , fridge should turn off. then when fridge is not running,turn to highest setting, fridge should turn on. if it fails this test thermostat is faulty and needs to be replaced
Sep 10, 2009 | Maytag MBB2256G Bottom Freezer...
My performa refrigerator,on top,of unit is freezing all the food .where should the dial be set?
The fridge section shouldn't ever freeze anything.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 02, 2009 | Maytag Performa PAV2200
Fridge not staying cool, freezer still freezing
The defrost thermostat on the defrost heater is probably bad, it's a good place too start.
Mar 18, 2009 | Maytag MBB1956GES Bottom Freezer...
Fan is a big issue. New problem though.
good day!first and foremost, in most freezers, the highest freezing point is 7.in regards with the water dripping from the air vent hole, you have to minimize your your freezing setting to the middle.turn it to 3 or 4 freezing point.
Aug 22, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Kg34na90gb fridge freezer - fridge temperature cold, no matter what the setting on door control. Fresh food suffers as a result of almost freezing conditions.
turn the freezer up to highest setting and set the refrigerator control to about half way. this will block some of the airflow into the refrigerator.
Jul 06, 2008 | Siemens Refrigerators
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
