Question about Dell Inspiron 1545 Notebook
I have a insprion 1545 that half of the screen is white with vertical lines on a white back ground. The other half is fine but can only view the left half of the screen. I hooked it to an external monitor and it works fine with no problems. Is it a screen problem or a mother board problem.
  • 225 Answers
It is a screen problem. You have to replace the LCD. It is either cracked or the electronics of the LCD is faulty. Find the part number on the back of the LCD and look for it on ebay.
Posted on Aug 08, 2010
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
How do I fix vertical lines and no picture.
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Evenly spaced vertical lines
Hello
Check the smoothing capacitor to video output supply voltage, usually derived from any one winding of the LOT. It will come around 10uF350VDC to 47uF 350VDC range. If this capacitor is faulty, or gone less in capacitance with time, this type of fault will occur. Check the green volour output transistor on the video output card, can be located attached to the neck of the picture tube; for any loose soldering or leakage. OK.
Oct 19, 2011 | JVC AV-32P903 32" TV
How to fix white vertical lines on one half of my panasonic plasma screen
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help to solve the problem...
Sep 09, 2011 | Televison & Video
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
Plasma only showing half picture
This is beyond consumer ability to repair. Please have it looked at by a qualified electronics service company.
Nov 23, 2009 | Panasonic Televison & Video
I have a dell insprion 9300 laptop, it has
try connect you laptop to a external monitor, if the image is fine, then the screen needs to be replaced. It cannot be fixed.
Apr 07, 2009 | Compaq Presario M2000 Notebook
CRT TV with a white line half way up the screen
The white line is result of a Vertical failure. Believe it or not, the whole picture is contained in that one white line, but it is not spread out from top to bottom on the screen.
Usually, a vertical failure is IC or capacitor related. Should be an easy, fairly inexpensive fix for a competent repair shop.
Hope this helps you...
Jan 05, 2009 | Televison & Video
Dell Inspiron 1545 Notebook Logo
533 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
