Question about Cameras
Olympus u(mju)u760 all weather camera screen showing D8234 8282 8234 8282 8234 please tell me what code means?
Jeap
  • 114 Answers
SOURCE: Olympus Mju 400 error code d: 1E12
the lens is with problems and needs to be changed. doesn´t happen when u connect to computer, because when is connected the lens doesn´t move.
Posted on Jan 23, 2007
SOURCE: Olympus mju 410- Orange lamp flashing
I had this happen and fixed it by removing the battery and leaving it out overnight and making sure it was fully charged - the next day battery inserted and it was ok. Prior to inserting battery I opened shutter cover and help down shutter release to try to drain any residual power. - Worth a try.
Posted on Aug 21, 2008
wipdhuls
  • 133 Answers
SOURCE: Olympus mju 700 - error D: 5e02
Hello Jakub,
As you might already know that you are not the only one who is getting this error.. there are thousands of others with you .. If that makes you happy :D
This code is a troubleshooting service code for "malfunction of focus motor/sensor". It is a motor/sensor issue and is normally caused by sand or dirt in the lens cover mechanism. Try to turn on camera while holding it with the lens pointing up.
You might even try hitting the camera on your palm in that position (by hitting, i don't mean a real HIT .. be sure that you are gentle not to break the camera).
If that doesn't work then try this... when the lens is trying to come out and cannot come out completely then you can assist the lens by pulling it out manually (once again, understand that its a delicate camera and I don't want you to show how powerful you are by pulling it with all your mighty vigor.. be hard and gentle at the same time .. I hope you understand what i mean)
Please let me know if any of the above steps work for you and do rate the solution :)
All the best.
Regards,
Srinivas
Posted on Apr 08, 2009
BillB-SA
  • 2761 Answers
SOURCE: My camera will not take any snaps
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
  • 11967 Answers
SOURCE: Olympus MJU 400 Digital camera keeps turning off -
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 26, 2009
Testimonial: "I blew firmly in and around around the lens shutter - seems to have worked. Camera does not keep switching off - thank you!"
Hi, After taking the camera snorkling, it seemed to stop functioning. The camera powers up but only shows up a blank screen. It may also sometimes show a camera icon - stating that the "camera...
How deep did you take the camera? The manufacturer website states: WATERPROOF (16FT.). A revolutionary system of waterproof seals and gaskets keeps water out so you can take pictures as deep as 16 feet underwater.If it was deeper than that, the gaskets probably let water in due to the pressure of being underwater. (Basically it means the camera let water in and as such probably will not work right again)
May 17, 2011 | Olympus Stylus Tough 6020 / mju Tough6020...
Please help my Olympus Stylus Tough 6020 seems to be stuck in playback mode. I can review the photos no problem but when I press the button to change the mode to take aphoto the screen reverts back to...
Unfortunatly the Olympus 6020 does not hav a dedicated hardreset switch, nor a key sequence to initiate reset. So if you cant get into the camera menu, and reset the camera from there. Or if that does not work. The camera has to be serviced by proffesionals.
Mar 08, 2011 | Olympus Stylus Tough 6020 / mju Tough6020...
My Olympus u760 only displayed a blue screen and gave the message "5F08 8234" The lense will now not retract either.
The gears of lens may gone jammed, need little push for more detail refer to my earlier solution HERE
Good Luck
Mar 02, 2011 | Olympus Cameras
The camera is off but there is still a picture on the screen
"Off" might mean the lens has retreated, but that doesn't always stop the power as you can tell. Some Olympus cameras have a view mode (look for a button and icon near your view window). You may have accidentally bumped it. Push it again and the picture should turn off. You'll probably see more than one choice -- read the button labels to determine which is the right one.
Apr 15, 2010 | Olympus Stylus / mju 1040 Digital Camera
Hello Jakub,
All the best.
Regards,
Srinivas
Apr 08, 2009 | Cameras
The screen stays black
It could mean your battery or memory card is not inserted properly.. Mine also does this when my battery is low.
Jan 02, 2009 | Olympus Stylus / mju 1040 Digital Camera
Camera stopped operating
Well I know what the review says about underwater to five meters http://www.ephotozine.com/article/Olympus-Mju-725SW
but I would take it with a pinch of salt frankly.
You could get onto Olympus and tell them you know- 'You said I could take it under water - now it wont work' - They may replace it
Jul 12, 2008 | Olympus Mju 725 SW Digital Camera
Camera lens of my Olympus u760 wouldn't close and when I try to power it up in camera mode, the lcd preview screen just shows a blue screen with hexadecimal values.
A lens that won't retrac usually means that one of the gears has either come out or is off line and not meshing. Have to get it repaired. But worst case would be the board has fried.
May 02, 2008 | Cameras
Oct 12, 2007 | Olympus MJU 400 Digital Camera
Olympus 300 mju
well sometimes that happen, and can be two things 1st the camera got very wet, or the button inside got broken and needs to be replaced.
Feb 09, 2007 | Olympus MJU 300 Digital Camera
Cameras Logo
64 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
