Question about Electrical Supplies
Hello, I just bought a second hand Kawasaki GA1400A generator, motor works ok, but I just dont get any electricity out from that machine. All fuses are ok (I measured), I also checked brushed of stator and they were ok also. I also measured the voltage from the brushes (connectors there) when the motor was running, but could get hardly 2...3 volts out. Is there something else what could be broken. br jussi
  • 68 Answers
SOURCE: motor not running in Asko 10504 washing machine
The motor might have burned out. Another possibility would be a partially fried control board.
Posted on Jan 17, 2009
  • 83 Answers
SOURCE: I have a Coleman Powermate 5000 / No power output
Two suggestions. One: check for voltage from the secondary coil wires (if it has one). Two: unless stated do not do this, I have always flashed the excitor circuit through the 120vac receptical. Give these a shoot and I hope it works for you.
Posted on Mar 30, 2009
  • 1388 Answers
SOURCE: i get no 110 or 220 volt power
generac was purchased by Briggs Stratton some years ago, however some information is available at the following web address, just enter your model number:
http://www.generac-portables.com/service_support/owner_manuals/owner_manuals.cfm
The small board that you describe is the bridge rectifier that converts ac from the windings to dc for the armature. You can test the brush/board by removing the part from the generator and applying 12 to 16 volts ac to the input tabs/wires then test/read dc (dc voltage will be lower than input ) voltage at the brushes. Use meter to make sure that you are getting dc. I use a small power supply less than one amp that I purchased at the thrift store for a couple of dollars. If test fails replace part. If it tests ok re-install brushes and re-connect the ac power supply to brush/board which in turn will energize the armature. At this point test the armatrue for magnetic power. I use a thin welding rod or wire against armature. If you feel a magnet start the engine. If the windings are good you should get some voltage at the plugs and the two wires that feed the brushes (will not be full voltage). If voltage is present, kill engine and disconnect ac power supply and connect the original wires to brushes/board and start engine. If you now have voltage at plugs you spiked the system indirectly by energising the armature. If still no voltage you may have an open circuit that feeds the brushes or diode pack is failing with the incresased voltage. Good luck with your repair and email if you have questions.
Posted on Apr 14, 2009
mamicheddy
  • 79 Answers
SOURCE: only 2v on 220 outlet , brushes are still good , what next
Your voltage regulator is shot. Needs voltage regulator.
Posted on May 12, 2009
SOURCE: I have a honda generator em2500x voltage problem
Cummins P2200, 2KWatt, it starts fine, but after a couple of minutes, it gives quite high voltage output, meter needle goes beyond 300v, engine speed seems high since throttle is increased, indicator light on generator also becomes bright, after a minute or so, things come to normal, sometimes takes few minutes to come to normal, situation is same, with/without output load. this happens within initial 15 minutes after startup, afterward everything is normal.
Posted on Aug 14, 2009
What are the carberator adjustments for a kawasaki GA1400A generator
I don't believe there are any adjustments other then IDLE
Mar 04, 2016 | Electrical Supplies
GA1400A generator,engine running well, but no electric output! Can you help me please!
Probably has lost exciter current. It can be restored : take wires from a 12 volt battery, use something like 16 or 18 gauge, and with generator running insert bare ends into the AC outlet - one to neutral and one to hot (doesn't matter which is positive or negative). Insert and remove quickly. There should be a flash and current restored. If not, do it again until you get that flash. Once you have that, the exciter current is restored and you will now have power. The reason for the light gauge wires is if you are too slow to remove the wires and AC is restored while still connected to the battery, the wires themselves (or one of them) will burn out and protect the battery from AC current. So be careful! I assume all breakers on the unit are on?
Apr 10, 2014 | Electrical Supplies
Workshop manual GA1400A
IS THE KAWASAKI GA1400A GENERATOR N INVERTER GENERATOR
PLEASE SEND YOUR REPLY TO
pearlyking@gmx.co.uk
Feb 07, 2012 | Stanley 8000 Watt 10000 Surge Watts 15 HP...
My maytag dishwasher apparently blow a fuse in Fuse Box. I then throw the switch it worked ok, next day or two my wife try to start the dishwasher it would not turn on. I bought new fuse to put in...
It seems you may have an Electrical Insulation Break Down fault with your machine.
My suggestion would be to get a Registered Appliance Technician to test the internal circuit of the machine before attempting to switch on the appliance or rectify any fuses.
The appliance needs to be issued with a (PAT) test first to determine if the appliance is safe to touch when applying power to the machine so you dont electrocute your self.
Once the (PAT) test has been applyed then the technician can visually inspect the high voltage internal parts that could be the result of the insulation break down.
I strongly suggest if any kitchen appliance trips the main fuse for any reason I would recommend not trying to change any fuses as this second atempt to reboot the machine may have blown the machines 'Power Control Module'!
Apr 30, 2011 | Maytag 24 in. MDB9150A Built-in Dishwasher
I have a generac 50G. How do I flash the field so it will generate?
This is the easiest way, get a hand held power drill and plug it into one of the 120 volt recepticals. Make sure all the cicut breakers are pushed in before you do this. OK here is the trick, with the generator running, pull the trigger on the drill and spin it hard BACKWARDS. You must keep the trigger pulled and DONT hangonto the chuck after you spin it......... It will just take off spinning. If it doesnt work at first do it again, if it does not work, make sure you are spinning it as fast as you can. If the drill motor does not just take off after three attemps, you might have a bad diode that needs to be replaced.
Hope this works, Let me know :)
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 04, 2010 | Guardian Rv Generator 4800 Watt, Gasoline,...
Starts but electrical plugs dont work. have
The field probably has lost the bit of magnetism it needs to get started. Search Google for methods of recharging this field. One method I have used consists of connecting two series light bulbs between the generator 120 volts and the utility power. Some have been able to take a standard electric drill without variable speed triger and plug in and give the drill a spin which sometimes will drive enough into the generator to start remagnetizing it.
Note: If an accidental short occured on your generator, the rotating diodes may have been destroyed in which case it will need replacemnt of the diodes.
Mar 30, 2010 | Northstar Generator 9 Hp, 5500 Watt,...
Kawasaki ga1400a generator manual
If it's a Parts Manual you need, it can be found HERE.
I've searched the Kawasaki website (and several others) and was unable to locate a free Owner's Manual.
Hope this helps,
Dolf-
Oct 15, 2009 | Electrical Supplies
Hotpoint wm53 unknown problem
Hi.
Unplug the motor and try it again, if it does not trip, then the prob is the motor, could be worn carbons.
Re the noise, remove belt, and spin drum round by hand, if it is noisy and rumbling, then main bearings have failed, quite a big job to put right.
Please rate my comments.
Thanks.
Jun 17, 2009 | Hotpoint Washing Machines
Electrical Supplies Logo
165 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
