Question about HP Officejet 7130 All-In-One InkJet Printer
Loud Noise Hello, First, let me thank you for the excellent pictures and written instructions for disassembly of the 7130 unit. They made it very easy to disassemble and reassemble the unit. I took the unit all apart, including disassembly of the entire service station, cleaned all of the service station parts of residual ink, and reassembled the unit completely per your instructions. I did not have a 'dead' motor, so I did nothing with it except remove it so I could wash out the ink residue from the station compartments without getting water into themotor on on its attached circuit board. I reassembled the printer, but the rat-a-tat-tat noise is still there and the printer reacts as it did before taking it apart. The sound seems to be coming from the lower right side of the printer (the service station area as you look at the front panel). The noise is representative of a plastic gear rotating against another plastic gear that is stuck and the noise is quite loud. I did not see any gear teeth wear when I took all of them out for cleaning. I also now notice a sound (represents a very short squeak) that sounds like an RF signal, likely from either the motor, one of the circuit boards, or some other electronic component. I heard this sound before I took the printer apart, but only since this problem loud noise began a few days ago; I did not hear this sound before this problem started. My theory is that there is a sensor or circuit board component failure that does not allow a positioning sensor to work properly; either on the long skinney board attached to the service station itself or the rotational sensor attached to the back of the motor, consequently the print head wiping / sealing positioning motor runs through the 'stop' command position, thus causing the gears to clash creating the machine gun noise. If you have any experiences or thoughts about my theory or what might be the cause and how to correct it, I would appreciate your input. Please feel free to call me or give me your phone number so I can call you so we can converse about this; a much quicker way to talk through the problem / test solutions than E-mail. By the way, I am the GUEST or second person with the LOUD NOISE problem you responded to on FIXYA.COM Thank you in advance for your help Criag Draves 641-210-9695
  • 1 more comment
  • TimmyToes May 16, 2008
    I have the exact same issue as HangMan's loud noise. Rat-a-tat-tat coming from the lower right - completely disables the printer. I do not see any obvious solution and am about ready to give up on this. Anyone with a solution???
  • Probes May 20, 2008
    Same problem here - do I throw this printer away?
  • verlieag Jul 03, 2008
    I have the same problem, a loud rat-a-tat noise coming from the lower front right of the printer went I press the print button. The light comes on and the lcd panel shows one bar abd it just stays there. In addition to that noise, I can not turn the printer off without unplugging it. Please help.
    Problem Solver:
  • 9 Answers
My apologies for just now responding to this message; apparently my fixya mails have been getting caught by a filter and trashed without my seeing them.
I can think of a couple strong possibilities for this issue, and you're right; talking it through would be a good idea.
I will get in touch as you requested.
Posted on May 12, 2008
The dryer has a loud, high pitched squeek
Hello Robin, thank you for your post!
From the information you have provided your Frigidaire dryer is making a loud high pitched squeaking noise. This noise could be coming from your belt, motor, or spider arm. In order to find out which component might need to be replaced you would need to disassemble the dryer. We would recommend having a professional technician out to perform a proper repair. Improper disassembly of the dryer could result in personal injury or a problem with the dryer later in its life cycle. I hope that this information is helpful to you. -Matt
Feb 07, 2016 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Packard bell hera gl fan making loud noise
It may just need cleaning. If you feel confident taking it apart you can usually find info for disassembling on the internet, then check the fan for a build up of dust and give the insides a really good clean out. It's best to use compressed air.
Feb 25, 2013 | Packard Bell iMedia Computers & Internet
Making loud noise like a fan or disk?
Most likely it is a fan problem. The fan could either be failing or caked up with dust. Most likely the laptop would have to be disassembled to get to the fan and repair/replace the fan.
thank you,
Jul 11, 2011 | HP Pavilion dv7-1245dx Notebook
My Sony Grand Vega (KDF-E50A10) LCD just made a loud pop sound and now there is no picture. The only sounds are a loud buzzing coming from the this a burned out lamp??
Yes, loud pop sound was broken lamp in tv, replacement of lamp will fix tv problem.
Lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Nov 02, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Cartride jam with loud noise
Hello sir; un-plug machine, now you move cartridge much easilier, just move for and back ,to find out what's block the way.
Apr 12, 2009 | HP Officejet 7130 All-In-One InkJet...
Euro-Pro 7130
hi sherry , you requested a manual for the Euro-Pro model 7130 .
here is a link to the 7130 FAQ's
7130 FAQ's
and here is the instructions manual.
7130 instruction manual pdf
thanks for using FIX YA!
Jan 24, 2009 | Euro-Pro Shark 80 - 7133
Loud noise
Hi There,
It's quite possible that you both are experiencing the same or similarly related problem for which I just posted some advice. Please take a look at the entry linked below and see if this won't be of help to you. You're also welcome to email me for further outline or assistance in resolving your issue; I have 6 of these machines and do a lot of work helping others with them. Here's the post:
Mar 21, 2008 | HP Officejet 7130 All-In-One InkJet...
Gear Racheting Noise
Not a easy gear to get to, entire side frame must be removed. I always just replace the whole left frame as pictured, but really you only need to replace gear pic at top, like I say not easy, take pics so you know how to reassemble it.
Jan 10, 2008 | Brother MFC-8440 All-In-One Laser Printer
HP 7130 Random grinding noise resulting in a stall
Filka, You are most likely beginning to experience issues with service station function usually created by the buildup of ink which becomes gelled and gooey, resulting in sticking parts. Two primary points of trouble can be involved; one very easy to see and reach- the other requires a fair amount of disassembly but once inside the job is not hard.
First, right on the edge of the service station (the black box beneath the carriage when it's parked on the right) you will see a narrow white wedge-shaped piece. This is a retracting "wiper" which is supposed to slide forward when the carriage is parked, and to the back when the carriage is preparing to move. It has a small rubber tab at the front edge which wipes ink from a gold contact surface right in front of the wiper. I've yet to see one truly do well at keeping the surface free of ink, but it does keep it from building up. It is quite easy for this wiper to become "glued in place" by all of this ink. Start by raising the maintenance door, causing the carriage to move out to the center and the wiper to retract(if they will). You can then use a dampened paper towel or cotton swabs to clean the contact in front of the wiper, then gently pull forward on the top of the wiper to slide it forward over the cleaned surface. This will remove some of the ink on the rubber tab and begin letting you clean the wiper itself.
The second area of trouble is the service station itself. The sleds and tray are likely to be heavily coated and the only real way to clear them is to disassemble the case for access. You can use the following link to go to a step-by-step photo/instruction guide that will show you exactly what's involved-
Jan 10, 2008 | HP OfficeJet 7130 All-In-One Printer
Crosley CDE/CDG22b7
Please describe "rolling noise".
Oct 21, 2007 | Crosley CDE6000 Electric Dryer
HP Officejet 7130 All-In-One InkJet Printer Logo
182 people viewed this question
Ben Johnson
