Question about Hyundai Televison & Video
The player keeps loading and does not play the disc.
    Genius:
  • 1,622 Answers
All you need to do is to open the DVD player, clean the lens with a cotton bud soaked with Some isopropanol alcohol, use this to clean the lens, but if otherwise, check the ribbon cable that is use to connect the laser lens to the circuit board , if this the ribbon cable is okay the lase lens will popup a red light indicating the lens is well connected, and if otherwise you have to replace the DVD DRIVE, the DVD DRIVE come with a whole of a mechanism and laser lens. This will solve the problem .........
Posted on Aug 08, 2010
5 Suggested Answers
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
romsky79
  • 822 Answers
SOURCE: Player justs keeps saying "bad disc" !!
clean your dvd lens with dvd disc cleaner.
Posted on May 30, 2009
  • 146 Answers
SOURCE: dvd player doesnt play the movies
Try another DVD. If problem persists and it does not work with any type of DVD, whether recordeable burnt DVDs or original pressed DVDs then your unit is bad - either dirty lens or the laser diode is bad.
Posted on Sep 26, 2009
jdvillanueva
  • 2098 Answers
SOURCE: My DVD player keeps
Diagnosing the fauty parts on dvd player is quite technical but i will suggest a diy solution that may help you on your problem.
Try cleaning the Lens of your DVD(It might be covered by dust thats why it can't read any disc) by a soft cotton bud. Be careful while doing these and try if it will work.
If the problem is still there then i've advice you to send it to repair shop to replace the faulty parts.
Thanks for using fixya.
Posted on Jan 09, 2011
Says loading disc then no disc pops up and it just won't play. Tried the phillips lense cleaner still does same message (loading the no disc)
The reason the player keeps loading and showing no disc is simply because the lens of the player is weak.
To fix this,
  1. Open the cover of the player with the appropriate screwdriver,
  2. Open the disc tray,you will see the lens, like a crystal or diamond like object,
  3. Replace the lens by removing it with the mechanism that supports it and fixing the new lens,
  4. Test it with a DVD disc.
  5. Cover the player back.
Take care
Jun 21, 2010 | Televison & Video
My logik lpd850 portable dvd player is turning on but doesnt seem to play any discs it just keeps reading no disc any solutions please.
the fault is obviously from the laser (lens) of your player. The lens is very weak such that it cannot load/read data on discs.
The best to do now is to replace the lens and your player will play all discs again.
Take care.
Jun 04, 2010 | US Logic DVD800P Portable DVD Player
May 30, 2009 | Cyberhome CH-DVD 300 DVD Player
Won't load DVD
call support from manufacturer on how to reset your player,
For instance, on Samsung players after it is powered on you hold in both channel buttons for 10 sec and the player restarts. that fixed mine that had the same problem
Apr 21, 2009 | Televison & Video
Teac dvd player
U LASER NEEDS REPLACEMENT
Dec 07, 2008 | Audio Players & Recorders
Problem with dvd player. Trutech 7 inch
I was told that they could reset it but I can not find a number on this company
Mar 20, 2008 | TruTech PVS12701 Portable DVD Player
Sd370e dvd player
the dvd player does not actually play hd dvds just upscales normal ones
Nov 29, 2007 | Toshiba SD370E DVD Player
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Televison & Video Logo
266 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
