Question about ATI RADEON® 9250, (128 MB) AGP Graphic Card
I can't get the catalyst to work. it keeps on saying i'm not the administrator.. etc
  • 86 Answers
Ok. you are working on a limited account first create a admin. account from control panel if you have you should log in from there and install catalyst
Posted on Aug 08, 2010
My volkswagen beetle is throwing a code of p0420 catalyst converter. i had two different mechanic tell me two different things. one says i have to replace ev erything from the manifold back and the other...
P0420 Volkswagen - Catalyst System Efficiency Below Threshold Bank 1 Possible causes:
- Three way catalyst converter Bank 1
- Exhaust tube
- Intake air leaks
- Fuel injectors may be faulty
- Fuel injector leaks
- Spark plugs may be faulty
- Improper ignition timing
- Engine Control Module (ECM)
Don't guess, check out the possible causes above.
Jun 05, 2014 | 2001 Volkswagen Jetta TDI
Po422code coming up
Hi there:
DTC P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
A vehicles' catalytic converter (catalyst) helps improve tailpipe emissions by oxygenating the exhaust gasses. It helps convert hydrocarbons (HC), Carbon Monoxide (CO), and oxides of Nitrogen (NOx) into water vapor (H20), Carbon Dioxide (CO2), and Nitrogen (N).
The PCM (Powertrain control module) monitors the catalyst efficiency by means of a post-catalyst Oxygen sensor. This sensor is used primarily for this purpose. It should switch much slower than the front oxygen sensors. If at any point the PCM detects that the post-catalyst o2 sensor is switching too rapidly (indicating no change between the inlet and outlet of the catalytic converter) it interprets this as a catalyst that isn't functioning properly.
Bank 2 is the side of the engine that has cylinder #1.
Symptoms of a P0422 DTC may include:
Increased tailpipe emissions
MIL (Malfunction Indicator Lamp) illumination
Potential causes of a P0422 code include:
Bad or non-functional catalyst
Engine operating out of optimal air:fuel ratio
Possible Solutions: Catalytic converters contain precious metals like platinum, palladium, rhodium among others. Basically, the cheaper the cat, the less precious metals used. It should be noted that there are some automobile makes that are very finicky when it comes to catalytic converters and the logic that the PCM uses to monitor them. Just because the parts guy says it will work doesn't mean that it will. The reason is that the engineering of the vehicle was done with a high quality catalyst in mind and it can't be replaced with a low cost catalyst. There are also different kinds of catalysts. Some makes will allow for a cheaper catalyst while others simply will not. Toyotas & Subarus are the most notorious for this. Subarus require CARB certified catalysts to keep the check engine light off and won't tolerate an aftermarket catalyst, no matter how expensive.
So basically if you have a recurrence of this code after replacing the catalyst with an aftermarket catalyst, this may be your problem. If you have this code and haven't replaced the cat, there's basically two likely causes: The catalyst is no good, or the engine is running out of optimal air:fuel ratio. A tune up or engine repair may correct it. Otherwise you'll need to replace the catalyst.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 02, 2012 | 2001 Hyundai Elantra
Code p0455 & p0422
Hi there:
DTC P0422 - Main Catalyst Efficiency Below Threshold (Bank 1)
Possible Solutions:
DTC P0455 - Evaporative Emission Control System Leak Detected (no purge flow or large leak)
This indicates a fuel vapor leak or lack of purge flow in the EVAP control system. It means a large leak has been detected. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
A code p0455 most likely means one or more of the following has happened:
A loose or improperly affixed gas cap
A non-conforming gas cap (i.e. not factory/original brand)
Other leak or damaged piece in EVAP system
Possible Solutions: with a p0455, the most common repair is to:
Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
Otherwise, replace the gas cap, and/or
Inspect the EVAP system for cuts/holes in tubes/hoses (you may hear a vacuum noise or smell fuel), repair if necessary
Jul 12, 2012 | 2003 Dodge Dakota Club Cab
Catalyst control center not working
You need to reinstall the video driver, it was corrupted somehow. Get it from here
http://bit.ly/aPUziC
Jul 01, 2010 | Toshiba Satellite L505DGS6000 Notebook
Check engine code 0420
catalyst below threshold (bank 1) p0420- There are a number of things that could be causing this p0420 catalyst efficiency code. The most common thing is the catalytic converter itself is no longer functioning properly. The other likely thing is the rear O2 (oxygen) sensor is no longer working properly. Other things could include exhaust leaks, damaged exhaust pipes, damaged O2 sensor wiring/connectors, plugged catalytic converter, etc
May 23, 2010 | 2002 Pontiac Grand Prix
My car got a po420 code reading when i went to get it inspected. whats that mean
The PO420 means that the Catalyst System has an Issue'
The actual error is
"Catalyst system below Threshold (bank 1)"
As mentioned above, the code's description is Catalyst System Efficiency Below Threshold (Bank 1). OK, now tell me that again in plain English please.... let's break it down: the catalyst system being referred to is your three-way catalytic converter; so the catalytic converter is not working properly (i.e. it's not efficient). Bank 1 refers to the side of the engine which contains cylinder #1. On inline engines such as 4 & 5 cylinder engines, there is only one bank. So, to really simply things let's just say that the efficiency of the catalytic converter and/or exhaust pipe and/or O2 sensor is not so great.
There are a number of things that could be causing this p0420 catalyst efficiency code. The most common thing is the catalytic converter itself is no longer functioning properly. The other likely thing is the rear O2 (oxygen) sensor is no longer working properly. Other things could include exhaust leaks, damaged exhaust pipes, damaged O2 sensor wiring/connectors, plugged catalytic converter, etc.
You can search for the Information on the web. Just type in the actual error above into you fav search engine!
Hope that helps...
Dec 28, 2009 | 2004 Nissan Altima
Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Aug 01, 2009 | Kenmore Washing Machines
Catalyst Control Permission Problem
It seems u dont have administrator privileges to do it
Dec 26, 2008 | ATI Computers & Internet
Hopefull plea before i go mad
Sounds like a driver problem to me. I recommend removing all video drivers from the computer, restart the computer, then install the newest catalyst drivers. The error saying that the exe has encountered a problem and needs to close may not be fixed by this. I would recommend re downloading them or getting a new copy from some where else.
Nov 06, 2007 | ATI RADEON X1650 Xt, (256 MB) Graphic...
ATI RADEON® 9250, (128 MB) AGP Graphic Card Logo
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
