CAN I CONNECT THE PRINTER VIA BLUE TOOTH OR INFRA RED. DOES THE PRINTER HAVE THE FEATURE IN BUILT
    President:
  • 1,188 Answers
Go to the manufacturer's website and search for your printer. Check the specs and see if it has IR or bluetooth (BT) capability. If it has then you can connect it via IR or BT provided your laptop/PC has an IR/BT port built-in or a USB device having such capability.
Note that using IR may not be a good idea as it reuires the sensors to be aligned all the time or a print error will be generated. Better use USB/wired connection or use BT if possible. Also you will need proper drivers and software in each case. These can be found on manufacturer's website as well.
Posted on Aug 08, 2010
Im trying to print my pictures from my Android cell phone via USB cable, any help would be appreciated!!
Well, a couple things here. First to try is to connect the phone to one end and then the USB side to your printer directly. Your device should be recognized or prompted to install software. If it prompts you to install software I would hook the USB up to your computer and install the device there. Then it will import your photos to your computer and you can print it from there. You should also have a Blue Tooth feather that will allow you to connect wirelessly with your printer (if your printer has this feature)
Sep 22, 2014 | Lexmark Polaroid P310 Photo Printer
How to add remote control (connecting via Bluetooth/Infra-red) for a laptop to play Media player?
http://www.retrevo.com/s/SMK-Link-VP6600-Universal-Remotes-review-manual/id/2881bh146/t/1-2/
this is the blue-tooth solution ..it is a remote for the player via blue-tooth ..its charges on the card slot ..and last up to one week
Or if your cell phone supports ..some models can be used to remote control the laptop via bluetooth ..usually all you have to do is install the feature in the phone..
o r..this is a infrared one ..
using a usb connection ..
http://compare.ebay.com/like/140411021885?ltyp=AllFixedPriceItemTypes&var=sbar&afsrc=1
Jan 20, 2011 | Computers & Internet
R/sir i could not connect my cellphone to PC how to connect this please help me
For your Cell phone to able to connect to your PC, you must have a cable that can connect your phone to a PC via a USB Cable or your phone must have a Blue tooth wireless adapter on your PC and your Phone.
Install the USB cable driver or the Blue tooth software on your PC.
Connect your phone via the USB cable to your PC, or from your phone search for the blue tooth device of your PC.
Oct 21, 2010 | Computers & Internet
How to connect sony ericsion w395 via blue tooth
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Can I connect wirelessly to this printer from my laptop
If this printer has Wi-Fi then yes you can connect to your router.
The printer must have an internal Wireless PServer it will have a Node Name this is what is needed to connect to the Router. If your router is set for Wireless and the SSID is working (ie no wirless isolation) then when you set up the printer driver it will ask you to connect to the router via an ethernet 100MB patch cable first to load the correct type of port for the printer drive, you only need do this once.
Then if the printer is set to boot in WLAN mode it should get an IP address via DHCP on your router.
Hope this helps, please rate my advice I will post more help if needed just add on to the end of this post.
Oct 15, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I would like to transfer files from my laptop to phone
have a problem with infra red, it is enabled, but comes up with problem with infra red driver. is this hard ware, or soft ware
May 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
Transfer data
If you old device includes a "blue-tooth" feature then it should be equipped to transfer all your contacts via blue-tooth.
Now if your device DOES NOT have any "blue-tooth" feature, then you can visit your nearest carrier store, and transfer contacts using their handy tool.
Thanks.
Mar 17, 2009 | Motorola Mobility RAZR V3
How do i connect my nokia 6080 via infra to my pc?
You cant connect bcoz pc doesn't have infra red feature. You can connect your handset though USB cable provided with your nokia phone.
Nov 25, 2008 | Nokia 6080 Cellular Phone
Cannot connect wireless keyboard and mouse
I am assuming that this is an INFRA-RED device, with
plug and play capability.
1) Make sure that the infra-red port is turned ON on your PC,
in the BIOS and in Windows (using control panel)
2) Make sure that the infrared driver is working:
My Computer ==> Right Click ==> Properties ==>
Hardware ==> Device manager ==> ....
Find the Infra-red device and check its status.
Some laptops have a mechanical switch witch controls all
wireless ports. If you shut-off the Wi-Fi, the blue-tooth and
the infra-red will also be disabled.
3) Check for tiny reset buttons on the keyboard, mouse and
the receiver. Press them repeatedly.
4) If the device is communicating, and infra-red ICON
should appear on you taskbar (RHS).
Right click the icon and make sure you enable IR
communications AND plug and play.
5) Make sure you have installed any drivers that came with
the keyboard, if any.
6) Again, make sure that infra-red communications are enabled
in the control panel.
5) Failing that, it is possible that the keyboard is defective,
or the infra-red port on your laptop is NFG, it would not
be the first time.
6) You may want to take your keyboard to a computer
shop, and ask the staff the try it with a different PC.
Alternately, try a different keyboard with the laptop.
Martin
May 07, 2008 | Computers & Internet
56 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
