Question about Refrigerators
Hi. I have got a caple Wi6113 wine cooler. I took the overload relay off the compressor and it rattles so i looked for a replacement part but no luck. The compressor is made by LG, the model number of the compressor is MB62NAEG 1PH- 20- 240V 50HZ Can you help me out by telling were i could get the replacement part from. Kind Regards Craig
watugot
  • 290 Answers
SOURCE: Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Thanks/Mike
Posted on Dec 06, 2007
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
SOURCE: danby wine cooler repair
I am having a problem with my wine cooler also.I found the upper evap fan not running.So i opened up the control board and plugged the fan that was not working into one of the other 2 sockets,and the fan worked.so i have a circuit board problem.If you go online to sears parts and repair.put in your model# and search,it will bring up a diagram of most of the parts available.And no it doesnt have to be a GE product.
Posted on Jul 08, 2008
  • 171 Answers
SOURCE: Haier Wine Cooler
Hi LinnieMcAdam,
I'm Harvey the Master Plumber.
Your question is: Where can you find a 10 Watt replacement light bulb for your Haier Wine Cooler?
I usually have success at the hardware store. Start there. Then you can try the store where you bought it or call Haier.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
Nothing works except the upper lighted panel in front of Allavino wine cooler. What might be the problem, and Can I fix it?
that one in the picture looks like it has a code. it is usually the cooling sensor.if it run on compressor it need relay overload and sensor check.
Apr 20, 2015 | Furniture
Why does My marvel 61WCM wine fridge turn on but right away off again?
First make sure it is not plugged into an extension cord. Low voltage could cause this type of problem. If you have it plugged directly in ,It is probably the compressor or overload relay on the compressor. You can bypass the thermostat to see if it is the problem, by first unplugging the device, then removing the wires from the thermostat, and jumping them together. Then plug it in If it still acts the same way the problem is in the compressor or overload relay mounted on the compressor. Sometimes the relay can be purchased and replaced or a hard start might work solve your problem.
Aug 07, 2014 | Marvel 61WCM Luxury 45 Bottle Wine Cooler...
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
My wine cooler just stop working. I hear a clik sound occasionaly.
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 16, 2011 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine cooler is not cooling. The digital readout is working, but the fan on the rear is not.
Hi!
Leo Ponder
Aug 30, 2011 | Emerson (025806803716) Wine Cooler
Wine cooler clicking, not cooling, light still works
pull the relay off and see if it rattles...if so, its bad, i have seen these be bad and not rattle...its either relay, or compressor...
Jan 23, 2011 | Magic Chef MCWC30MCG Compact Wine Cooler
Electricity works, unit doesn't cool.
Hi and welcome to FixYa. I am Kelly.
This is a 6 or 8 bottle free-standing wine cooler from what I can tell.
I am not having much luck determining if this is a manual defrost type unit or not. Given the inital sales price now of $79.95 I have to assume it is a manual defrost type.
There are a few things that can cause your problem.
1. PTC relay and KliXon thermal overload assy on the compressor.
2. Run capacitor
3. Temp control
You said the fan does not run so I cab not rule out the temp control.
I can not even find a parts break down of the unit.
With no fan running the very first suspect is the temp control but you can at least listen for a CLICK when you cycle it from off to any other position. If you hear a click I would start looking at compressor start / run parts.
If you have access to your units compressor note the manufacturer, hp if stated (1/8hp etc) and Model number.
Then call or visit your local appliance parts supply store with that information in hand. The will have a PTC relay / KilXon thermal overload AND run capacitor that will fit your unit. I am pretty sure that will get you going again UNLESS you have a broken wire somewhere.
The replacement parts are going to run about 50% of the cost to replace the whole thing.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Emerson (025806803716) Wine Cooler
My wine cooler does not start i plug it in an nuthng happens i can get a tester an i hve sum experiance in electricty so i want to fix it my self
You could have an issue with one of the following:
* compressor
* attachments to compressor (e.g.: relay, capacitor (if applicable), overload protector)
* temperature control assembly
Feb 16, 2010 | VinoTemp (VT60GNV) Wine Cooler
Compressor locked on Franklin FWC36 wine cooler. won't start. current relays bad. is it possible to get spare parts or nhot?
you might be able to get one at the junk yaqrd or dump
its a relay overload on the compressor
look back at the compressor
there should be a block on one side that the relay and overlaod
go to repair clinic they sdhould have what you need
Oct 07, 2009 | Franklin FWC36 Wine Cooler
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
