Question about IBM (40K1042) 36 GB SAS Hard Drive
Performed a clean installation of windows xp sp2 which I purchased and the installation won't complete it says error 1 cannot boot from drive how to fix this ?
    Genius:
  • 1,121 Answers
You need a raid controler then use a raid driver disk before install windows, because you use sas as primary disk. these disk is for unix and server blade server, using sometimes windows server as Op System.
is a tradicional steps when using special hard disk
Posted on Aug 08, 2010
I can't install Windows Xp Sp2 For Compaq Presario Cq60 Model. a blue screen error occured after completing the files from cd to ram before entering lience agreement
You need to check your system ram or memory. If you have 2 system ram or memory unplug the other memory and install the windows xp sp2 again. If still having a blue screen try the other memory then run the setup again. Also if you have an extra hard disk drive you can test it that or plug your hard disk drive to the other laptop and run the windows xp sp2 using your hard drive. If you can install the windows xp sp2 on the other laptop that means your hard disk drive are good. If your memory and to the other laptop are compatible plug it and run the windows xp sp2 installer to see and to diagnose what are really causing problem. Have a nice day.
Apr 02, 2011 | Computers & Internet
I have HP mini laptop which is already windows7 preloaded , but now I want to format and install a windows xp sp2 , that's I have already tried but can'nt complete the instalation
1. You should a working Windows XP Sp2 setup.
2. Just boot through the bootable pendrive or CD rom whichever you are using.
3. There should be no problem in installation.
4. If installation is completed then download the necessary drivers required from HP website particularly for your model.
Mar 27, 2011 | HEWLETT-PACKARD Hewlett Packard HP Mini...
Windows XP boots re-boots after installation of SP2
try removing 1 RAM then let it boot completely,
Aftrer a success boot shut it down then put back the RAM that you removed
if the above solution did not work reformat your PC and repartition it
pls rate if this thing helps
Jan 30, 2010 | Computers & Internet
Computer will reboot on Virus/Spyware scan at random. I have: 1. Installed clean XP SP2 parallel system and booted that one. Same problem. 2. Memory Test at boot time is OK. 3. Air circulation from Power...
The weak airflow from the power supply unit (PSU) is suspect. Virus / Malware scanning is a disk and processor intensive operation - resulting in greater load on both. Increased load translates to heat. Check to be sure that the processor (CPU) fan is running, too. An overheating PSU and CPU can cause all types of problems.
Are you using a genuine XP install disk/image or a disk of questionable origin? Use of bogus OS disks is "asking for trouble".
If your system BIOS or set up (accessed during boot) allows, try to located the page that displays component temperatures and fan speeds. Check this immediately after rebooting from a an unplanned shut down - if unable to locate this set up page, download HWMonitor at:
http://www.cpuid.com/hwmonitor.php
It is a free program - choose the 32 or 64 bit version. Note fan RPM and CPU core temps to help determine where heat is coming from - or which fans aren't operating correctly.
Sep 18, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Windows XP SP2 Repair
Solution: Rename the C:\WINDOWS\SYSTEM32\CATROOT2 folder to something such as catold to prevent WinXP's Setup program from locating the folder and halting the installation. If you are still in Setup, press SHIFT-F10 to launch a command prompt from within Setup. At the command prompt, type cd\win dows\System32 to open the System32 folder and then type rename CATROOT2 catold, press ENTER, restart the computer, and attempt the upgrade again.
If you cannot reach a command prompt from Setup, reboot the computer from a Win95, Win98, or WinMe startup disk and rename the folder from the command prompt. You can also launch a command prompt by booting from the WinXP installation CD and running the Recovery Console.
Mar 25, 2009 | Toshiba Satellite 5105-S501 Notebook
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Xp sp2
no isn't virus
i advice you to clean you Ram
and change you cd xp2
Jan 26, 2009 | Microsoft Windows Xp Home Edition Sp2...
Explorer.exe Application Error in Windows XP Professional SP2
Bring a bootable XPSP2 cd & boot from it ....when installling choose C: & format ..
Nov 27, 2008 | Computers & Internet
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
XP Reboots by itself on arrival of login screen
have you tried safe mode? if safe mode is still a failure, you have no choice but to reformat 1 of those drives an do a clean installation of windows xp
Mar 17, 2008 | Computers & Internet
IBM (40K1042) 36 GB SAS Hard Drive Logo
106 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
