Question about Samsung MW5371G/MW5370W Microwave Oven
I have an older model Samsung Microwave MW5370W Countertop White. The START BUTTON did not respond one time until I opened and closed the door and kept trying to get it to turn on. It finally responded to my finger/knuckles rolling across the button, started, and worked normally. Then the Start Button continued to work with ease as normal for a couple of weeks. Now I cannot get the Start Button to work no matter how hard I try. Every other button, door latch, light all still work great. Can I repair it myself, and can you please explain how to fix it? Thanks!
Kenmore elite micowave still runs after door is closed with no time on menu
The door switch may be adjusted. If not then it will have to be replaced.
Aug 18, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
GE Countertop Microwave Oven Door is stuck closed
Remove the cover. You should be able to access the two latches and release them. Once open you will have to take the door apart and repair the latch
May 05, 2014 | GE Profile Spacemaker Over-the-Range...
After a power surge, the display comes on. Yet, the buttons do not work. Is there a button to reset?
Is this a one time event? Try unplugging the unit from the wall for at least one hour and plugging it back in. Open the door and close it. I'm not familiar with this particular model but I have to guess that you push the stop/reset button to set the clock after plugging it in. It may be a bad touch pad or a bad door sensing switch.
Sep 19, 2013 | Danby Designer Series DMW077BLSDD 0.7 cu....
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
Jul 19, 2012 | Samsung SMH9187 Microwave Oven
Microwave door latch stuck
First of all, Do you have it on a level surface?
Jun 30, 2017 | Sharp Microwave Ovens
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwwave is not heating,
Hello
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol (like the "Start" button in the photograph).
Oct 05, 2011 | Sanyo Microwave Microwave Oven
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Microwave Ovens Logo
154 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
