Question about Compaq TFT8020 18.1" Flat Panel LCD Monitor
Signal outof range - Compaq TFT8020 18.1" Flat Panel LCD Monitor
    Scholar:
  • 45 Answers
  • Make sure the pins on the video cable are not bent or damaged.
  • Make sure there are no extension cables or switch boxes attached to the monitor.
  • Verify that you have the proper drivers installed for the video card.
  • Verify the problem at all possible resolutions and refresh rates.
  • Make sure the refresh rate does not exceed maximum value for any resolution.
  • Test the monitor on a different computer.
  • Contrast is recommended to be set at a higher range while the brightness should be set at middle range. This helps to increase the text clarity while reducing the bright background.
  • If your monitor is equipped with moire control, adjusting this may improve the clarity of the text. Moire is a wavy distortion pattern caused by interference between the dot pitch of the CRT and the picture signal. The pattern may vary depending on the screen amplitude, contrast, brightness, and other characteristics of the input signal.
  • Monitor's performance may be affected by the Earth's magnetic field. Try rotating the monitor to different directions to improve misconvergence.
  • Most video cards offer a software utility that changes the frequencies and sync polarities for all resolutions. If the setup does not match with the monitor's characteristics, an incorrect signal may be displayed on the screen. Sometimes, the image may also appear blurry.
  • Posted on Aug 08, 2010
    Looking for a wiring diagram for a range selector sensor plug for a 2004 chevy silverado 1500,4x4,4.8L with a 4KCD transmission
    Connector Part Information • 15416722 BLK
    • ASM Conn 12 F GT
    Pin Wire Color Circuit No. Function
    1 DK GRN 1433 Clutch Start Switch Signal
    2-3 -- -- Not Used
    4 YEL 772 Transmission Range Switch Signal B
    5 BLK/WHT 771 Transmission Range Switch Signal A
    6 GRY 773 Transmission Range Switch Signal C
    7 BLK/WHT 451 Ground
    8 WHT 776 Transmission Range Switch Signal P
    9 LT GRN 275 Park Neutral Position Switch Signal
    10 GRY 1524 Back-Up Lamp Supply Voltage
    11 PNK 839 Ignition 1 Voltage
    12 PPL 639 Ignition 1 Voltage
    This all I could find, hope it is the correct one.
    Apr 08, 2016 | Cars & Trucks
    I have epson emp700 projector - blue horizontal bars comming in picture but when i adjust the focus it goes but picture shows outof focus
    i didn't get your question well. so you have good picture with blue horizontal bars. and when you change focus you have out of focus picture with no bars ?
    try to do factory reset cos it seems like you have some settings wrong.
    after that try to see if bars coming with signal connected or no.
    if its only with signal try different cable and different input.
    Mar 29, 2011 | Epson Projector Lamp for EMP-500, EMP-700
    I cannot get 3/4 of my channels. Says i am not suscribed. I just installed a replacement receiver. Service tech to come out sat.
    Hi dillis1940I see you can not get ¾ channels, I am very sorry they are not showing. Thereare some things you can check when this happens, the first thing you will wantto do is unplug the receiver for 10 seconds and then after plugging it back init will reacquire the signal and download the program guide. If after that itdid not bring back the channels you will want to press the buttons ofMenu-6-1-1 and select Check Switch and TEST, after the test completes exit outof all menus and the receiver will reacquire the signal and download theprogram guide and you will have all your programming.
    Feb 26, 2011 | DISH Network Televison & Video
    No network coverage signal
    If you are not receiving a signal ... you are out of range. You will have to move within range of the signal tower to use your device. I suggest you contact your service provider concerning this. There is otherwise little or nothing that you can do until you get within range of the tower signal.
    Thanks for your visit today.
    Jan 25, 2011 | Cell Phones
    Water is coming outof the detergent/conditioner
    is the machine still filling may be as simple as to much water pressure turn the tap down a little
    Mar 29, 2010 | Washing Machines
    Left side of screen looks outof focus. can
    Convergence is dead.U know how to solders?Must replaced the 2 convergence ICS,and some or all the resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
    Feb 24, 2010 | Hitachi 43UWX10B 43" Rear Projection...
    Can not dial out gives me a message that says no link to base
    several things check the base is connected to mains power and switched on.
    You have obviously checked to see if it is outof range,and checked the batteries.
    If you are using more than one base check that you ar connected to the right one.
    Also if you have too many appliances connected to the phone point they won`t run.
    Nov 05, 2009 | Panasonic Phones KX-TG5571
    Linksys WRE54G WIRELESS 802.11G RANGE EXPANDER Range
    The actual max distance of the range expander is about 50 feet, and sorry to say but it cannot bounce the wireless signal from it on a wall....
    Jan 25, 2009 | Linksys Wireless-G Range Expander (WRE54G)
    Problem with monitor
    goto the safe mode and uninstall the video drivers and then restart the system normally and then reinstall video drivers..
    Sep 28, 2008 | LG 42LC2D 42 in. LCD HDTV
    Compaq TFT8020 18.1" Flat Panel LCD Monitor Logo
    112 people viewed this question
    Top Compaq Computers & Internet Experts
    Alun Cox
    Abhinandan  Patil
    Abhinandan Patil
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
