Question about Apple iPod touch
Ipod touch 16gb(1st) home button not working. How to fix
    Problem Solver:
  • 12 Answers
On the iPod touch 1st Gen device, the home button is prone to failure due to the design, most can be fixed for a nominal fee, fixed mine, it was one of the hardest iPods to repair for its time, but with practice, is usually never an issue. Once it is open, then the removal of the battery and then the logic board removal requires experience. As far as the button is concerned, Usually, the "pop" disappears and it feels stuck in the down position, simple fix by introducing an iPod Touch 4th Gen device design upgrade (as far as button is concerned.)
This particular model, the iPod Touch 1st Gen, does not have a replaceable home button module design. It is part of the logic board and so it has to be repaired and not replaced. The small outer disc can be removed and recovered, clean or replaced with another comparable size disc, if the issue is with moisture exposure, corrosion. The sign for moisture exposure issues is that it still "pops" but no longer functions.
I have repaired these successfully and with no issues. www.zfixit.com Ipod touch 16gb(1st) home button not working. How - 78c71099-06cd-4a93-9b81-39199bce2261.jpg
Posted on Sep 14, 2014
  • 4 Answers
SOURCE: my home button wont work
hi guys dont worry about it. its not really a major problem because sometimes the ipod has really really tiny malfunctions like this and no, im not from the apple store so dont ask anyway all you have to is this: plug in your ipod to the computer using the usb cable. now it should say that it is syncing if not, sync your ipod. while it is syncing, press cancel sync on your ipod touch and it should cancel and take you back to the home screen. This shouldnt happen again but if it does, at least you have a way to return to your home menu cya :)
Posted on Jan 20, 2009
  • 502 Answers
SOURCE: Ipod Touch Home Button
This usually happens if the membrane of the sleep/wake button deteriorates and the gold plated contacts between membrane and logic board do no longer establish good contact.
There are specialized online tutorials with iPod Repair instructions that will guide you through the steps of taking it apart and reinforcing the contact or replacing the button altogether otherwise you'll have to send it to any third party iPod repair service and they'll replace the membrane for you.
Posted on Jun 05, 2009
  • 22 Answers
SOURCE: Ipod wifi button is greyed out unable to access help please!
me too. i have the same problem but what you need to do is go to any apple store and get it replaced it was maybe caused by a liquid spill.
Posted on Aug 10, 2009
  • 5 Answers
SOURCE: iPod Touch, 1st gen, "slide to unlock" broken
If you jailbreak (quickpwn.com) there is an app on cydia that will change it to tap to unlock rather than slide so it should be more sensitive.
Posted on Aug 31, 2009
SOURCE: 16gb ipod touch 1st gen sleep wake button doesn't work.
Connect to itunes and do a restore from there. Assuming you can switch the thing on! Mine is the same, It started with the wake button only working sometimes, then by itself and eventually squeezing the case near the wake button would do the trick. I did try to fix but without success. These are very fiddly and the wake button disconnects from the main board when the case is opened making it very hard to test.
When not in use I keep the brightness at minimum and set the auto lock to never.
Good luck
Posted on Nov 12, 2009
My 16gb apple ipod touch was disabled because i had gotten my pass code. how can i enable it to start functioning?
Hey, If its the ipod with home and power key, all what u have to do is to press the 2 buttons in the same time for 10 seconds and then realise the power key and keep holding the home key for another 5 seconds.
That will put your ipad into DFU mode or recovery mode.
Plug it to itunes, itunes will come up with a message saying that it detected your ipod in recovery mode, and it will give you the option to restore the sw and wipe the device completely.
Then everything should be fine
Mar 15, 2013 | Apple Ipod Touch 1st Generation 16gb Mp3...
My Ipod Screen Went White And Now It Wont Turn On, How Do I Fix It?
Try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod
Dec 05, 2009 | Apple iPod touch 1st Generation (8 GB) MP3...
Ipod touch 1st Gen turns off during restore. (Need Help!) Please?
You might want to try holding the top button and the home button until it turns on, then let go of the top button. Keep the home button held down until the "Plug Into iTunes" picture comes up. You should be able to normal restore now. If this doesn't work, just go get it repaired.
Oct 16, 2009 | Apple iPod touch
Good luck
Oct 10, 2009 | Apple iPod touch
Hi i have an ipod touch first generation. and one day it was charging and then i went to listen to it and all it did was stay on the "welcome loading please wait" home screen. i dont know what to do :( the...
    Complete a Regular Restore
  1. Back up your iPod Touch's data to your computer before the restore to prevent losing data. You'll need to reinstall it after the restore process.
  2. Connect to the Internet and install the latest version of iTunes from the Apple website.
  3. Make sure your iPod Touch is connected to your computer.
  4. Pick "iPod Touch" in the Source pane of the iTunes program.
  5. Click on the Summary tab.
  6. Choose "Check for Update."
  7. Select "Restore" and follow the instructions to finish restoring your iPod Touch. Complete an Advanced Restore
  8. If following the steps in the previous section did not work, follow these steps to perform an advanced restore. Turn off the power on the iPod Touch.
  9. Plug the iPod Touch into your computer.
  10. Power on the iPod Touch.
  11. Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  12. Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  13. Return to the above section and follow those steps to restore your iPod Touch.
WARNING
Restoring iPod Touch software will return the iPod to its factory condition, and the restoration process will erase all data.
Sep 16, 2009 | Apple iPod touch 1st Generation (8 GB) MP3...
I don"t have the 4 digit code for Ipod Touch 16GB and can't use
try following the solution step by step as it is a couple of times if it didn't work for the first time.
Sep 03, 2009 | Apple iPod touch
White screen with lines
It appears to be a sleep state that the phone enters into.
How, I do not know. If your iphone/ipod touch screen is
pure white...here's a simple fix, gaurantee to work.
Hold the power button, and the home button, and the apple
logo will appear....release both buttons, phone will resume back to
normal.
Jun 06, 2009 | Apple iPod touch
Apr 29, 2009 | Apple iPod touch 1st Generation (8 GB) MP3...
Apple ipod touch home button does not return to the home screen.
Where does it go? Does it work at all? if it does then the problem is in preferences
Check: Settings>General>Home you will discover where it is set to go
Now if the home button does not work at all, then it is a hardware issue and you need Apple (for free if under the one year warranty) or a tech store to fix it.... probably better off getting a new one considering the price they charge
Mar 29, 2009 | Apple iPod touch
My itouch (16gb) can't get connected
hi kidcrazy,
u have to go to felix bruns website to download ipod touch firmware and after that u have to restore your ipod touch to factory setting. steps you need to know include
1. open itune
2. connect your ipod touch to your system
3. press and hold home button and hold button for 10seconds(your itune will recognise your ipod touch forcefully.
4. after that press shift key and restore to find the firmware u have downloaded from felix bruns site.
safe..............................
i pray it works for your ipod touch.
Dec 31, 2008 | Apple iPod touch
Apple iPod touch Logo
169 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
