Question about Quasar VV-2002 20 in. TV/VCR Combo
Using a portable dvd player
I connected a portable dvd player to a quasar tv/vcr combo purchased in 1996, when disconnected now I just a black box on the screen that will go away when pressing any button on the remote, but comes back. How do I get rid of it?
  • renees801 Apr 27, 2008
    please help with a solution
  • 78 Answers
That's the one of the closed caption options in the tv set. on your remote control there should be a button labeled "cctv", cycle through the options untill you find the off mode. this could also be in the tv menu.
Posted on May 03, 2008
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
What kind of cable would I need to connect a DVD player to this combo, a RF Coaxial or AV cable?
Check the back of your TV for external input connections. Usually there will be one to three connections available for the various types of cables. Check the back of your DVD for the output connections, usually one to three as on your TV. Choose one and use the cable type that matches the DVD output and the TV input connections and you are done.
Feb 11, 2012 | Quasar VV-1302 13 in. TV/VCR Combo
Quasar tv/vcr combo
A converter box is not needed to connect a DVD player to a TV. However, you do need a single cable with red, white, and yellow adapters orconnecterson one end and at least yellow and white on the other end. Ok if you have red; just don't worry if there isn't a hole to plug into.
I would like to connect a DVD player to my Quasar TV/VCR combo. No clue.....
Look in the back or the front of ur tv have a (Video Audio holes In).Look in ur DVD player in the back or the front have a (video Audio holes Out).Used a component AV video cable hook both devices together.Find the Video Mode in ur tv 1 or 2,now play the DVD player with a dvd disc.Now u should be playing the content of the dvd disc.If u don't have a AV video cable,tries websites like Amazon.com,Ebay.com to buy a set of AV video cable.
Dec 10, 2010 | Quasar VV-1302 13 in. TV/VCR Combo
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
Connecting older model quasar to dvd/vcr player (magnavox)
Hi and welcome to FixYa,
Initially, the only reason you would need/use a modulator is when the DVD/VCR has no RF OUT and the Quasar TV has no Audio/Video IN. If this were the case, then connections would be:
  • yellow Video Out of DVD/VCD to yellow Video IN of modulator;
  • red/white Audio Out of DVD/VCR to red/white Audio In of modulator;
  • modulator RF Out to RF/ANT/CABLE IN of the Quasar;
  • TV has to be set to either Channel 3 or 4;
  • if Modulator has no RF OUT but instead has a small antenna, still the TV has to be set to either Channel 3 or 4.
If however, the DVD/VCR has an RF OUT, then a coaxial patch cord from this could be connected to the RF/ANT/CABLE IN of the Quasar. The TV has to be set to either Channel 3 or 4. There would be no need for the modulator.
Good luck and Thank you for using FixYa.
Jan 03, 2009 | Televison & Video
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
How to connect dvd to television
I am trying to connect the portable DVD 1002 player and a vcr to an old tv that only has one cable jack on the back. Can anyone help me with a step by step how to connect. Please start with step 1 as connect cable from wall into...... and so on. Thanks so much for your help.
Mar 10, 2008 | Televison & Video
Hooking up a DVD player to a Quasar TV/VCR Combo
Yes, for a workaround. The adapter would be 2 RCA female to 1 RCA male. You have to connect both the red and white to the female RCAs and use the male to connect to the TV's Audio INput. The yellow goes to the video. There should be no negative technical effect other than lost of stereo quality. The audio output of the DVD is line level and could normally tolerate this condition.
The correct method is to use a simple line level audio mixer and mix the L& R audio signal to produce a mono signal or to use a stereo amplifier for the sound output.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Quasar VV-1302 13 in. TV/VCR Combo
Quasar 13" TV/VCR combo
not sure y it is b+w since the video is only one and audio is r and l.
Nov 05, 2006 | Quasar VV-1302 13 in. TV/VCR Combo
Quasar VV-2002 20 in. TV/VCR Combo Logo
107 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
