Question about Danby DPAC9008 Portable Air Conditioner
The external tank is not filling up and the unit is leaking and soaking my carpet
3 Suggested Answers
SOURCE: external water tank
Dear ziba1--posted the same problem two days ago and it doesn't appear to be on the site yet. Anyway, picked away at this again today (literally took the machine apart) and found the problem to be a clog in the drainage system. This explains why your external tank will not fill and why there is a leak--the drip tray under the compressor is not draining due to the clog in the drainage system. I fixed this simply by taking a narrow device and gently scraping out the drain hole of the drip tray (which is located just below the compressor...the compressor is located on the same side as your air filter). After successfully cleaning out this drain, I proceeded to flush the water out thoroughly with water. Give it a try--worked for me. I had all but given up and had already set up an appointment to have it serviced. Cheers
Posted on Aug 01, 2007
  • 8404 Answers
SOURCE: unit has leaked from somewhere
Your bucket is not sitting in the proper position. In MY Danby, the unit will not power up if the bucket is not in place.
I am not "the office" and I'm not even an employee @ FixYa.com, BTW. I am a volunteer question answerer here at FixYa.com - presently working in my home ... I just finished supper.
My catch bucket has a place to attach a hose which I have led to a floor drain. Please check the position of your bucket and the condition of the switch that the bucket rests against to allow operation (if yours has such a thing).
I have not had the experience you have had ... My Danby is top notch as far as I am concerned. I believe there is some simple step you are not seeing. I encourage you to take another look.
Of course there is that possibility there is a problem with your machine. Is there a service center near your location where you can have the device inspected for proper operation?
I am sorry to hear of your trouble and hope you find these comments to be helpful.
Thank you for your interest in FixYa.com
Posted on Jul 21, 2011
Testimonial: "Thank you very much...my apologies for venting, and I appreciate you using your personal time to assist testy people like myself :) Very helpful. "
I need some info. On schematics for plumbing for 1986 holiday rambler 5th wheel as I have a leak in the grey water pipes that feed into the tank...I think.? I can’t find where it’s coming from.
Good luck on finding any piping information, even from the MFR for that. Your best bet is to remove the access panels where the fresh water inlet connects to the camper and distributes throughout the unit. Typically, the connection will be near the hot water heater then once inside, there will be a "T" connection where the water will split off to the Hot Water Heater. After that, you should see the water go back towards the wall to go through a bypass valve, which is the lever used to bypass the tank fill or direct the water into the tank fill. This is where is can get difficult to find. Many 5th wheels will have the fill line go into and behind panels that are not easily accessible or they get directed under the camper where you will have to remove belly skin panels to be able to trace.
At each one of these areas where there is a connection or corners, have someone outside turn water on/off to prevent excessive water spillage and keep any water from getting inside your unit to get soaked into wood and carpeting.
Feb 20, 2018 | Holiday Rambler RVs
How to prime pump in bissell carpet cleaner
Turn off and unplug unit. Remove both tanks. Fill Solution tank and install it. Fill Heat Tank and install it. Plug unit in and turn on, wait one minute and engage sprayer till spraying. Stop sprayer. Consumer Care # 1-800-237-7691 for further assistance.
Aug 06, 2015 | Bissell Vacuums
My car alarm on a passat tdi diesel 02 plate keeps going off , i have reset it , started the engine , still keeps going off
these passats where prone for this. they had an issue with the plenham chamber drains blocking and filling the chamber up with water. this would then leak thru the pollen filter housing seal into the passenger foot well . the control unit for your alarm/central locking is under the passenger carpet (of all places). The carpet & underlay is very thick so even if it feels dry on top it could be soaking wet underneath . lift the carpet, check the control unit, in particular the wiring plug for signs of corrosion. there is also an earth point there, where there will be 3 or 4 wires bolted to the body, examine this as well. if corrosion is evident, the control unit itself may well be knackered, but try drying/cleaning up first
Feb 24, 2015 | 2002 Volkswagen Passat
I just lit my hot water pilot and filled my water tank,maybe overflowed. now I have soaked carpet in front of the pull out couch right in the middle of my aljo trl. what could do this? where r the tanks...
The water heater may be cracked and have to be replaced. Look for a leak from the tank. Always fill the tank before lighting the pilot light if you don't there is a possibility that you could damage the tank.
Dec 30, 2014 | Water Heaters
My floor boards in my Cavalier are Soaked ..
If you've been using your air conditioner during this time, and it hasn't rained at all, then the small drain at the bottom of the a/c evaporator core may be plugged. When you use the a/c to cool the car the evaporator coil [located next to the heater core in the ductwork under the dash] is very cold and moisture from the hot humid air condenses on it as a result. This condensation dribbles down the core and accumulates in the plastic housing under it where it should then drain out a small hole and drip onto the ground. If the small drain gets plugged, which happens quite often, then the water fills up the housing until it overflows and then runs out and soaks the carpet on the front passenger side. The drain is located on the engine side of the firewall, passenger side, down low where the firewall begins to curve under. Usually a puff of air will clear the clog and the drain will work fine again. If the carpet is really wet it would be a good idea to remove it and get everything dry again as it tends to get pretty smelly if left wet. One last note: usually a leaky a/c unit will only make the passenger side carpet wet unless it's been leaking for a long time while a leaky windshield seal can make both sides wet depending on where it is leaking. Good luck, hope this helps you out!
Jul 29, 2010 | 1993 Chevrolet Cavalier
2002 suburban has leak in driver side rear floor. Cannot see where water would be coming from?
We had same--water on driver side rear floor (soaked!). Driver side front floor seemed dry until feeling UNDER rug, was slightly damp. We found the location of TWO leaks causing this.
Leak #1 was through the parking brake line/cable seal; Recaulked with silicone. Removed plastic trim on floor between floor and door to reveal metal channel filled with water.
Leak #2 was where the door meets the car, near the hinge. It was the accordian-looking tube housing the wiring for the door. The big, rubber, circular plug connecting it to the main part of the car had come loose and water ran down through that, into the SAME metal channel filled with water from leak #1; will seal with silicone.
Note: We found that the channel filled extensively near the front door, BUT the carpet edge from the floor near the rear seat was dipping into it, wicking it up to the rear floor. Also, upon acceleration, the water in the channel gushed toward the back, thus soaking the rear carpet.
These leaks were found by removing all plastic trim (covering edges of carpet by doors), then one of us pouring water into specific areas of the exterior of the vehicle, and the other one watching closely with a flashlight for any signs of dripping.
Feb 18, 2010 | 2002 Chevrolet Suburban
External tank not filling
I recently encountered the same issue. First off, with the external tank installed is there an icon on the display panel indicating the tank is installed?
No? Then the two sensors are not picking up the magnets in the the "arms" on the back of the tank. It's a poor design for sure, on my unit the tank does not sit flush enough to the back of the AC, if I held the tank firmly to the back the icon would come on. I just used a bit of cardboard at the bottom of the support tray to press the tank firmly to the back of the AC.
Theory is as the external tank fills up, water will run into the "arms" and raise the magnets tripping the switch which tells the unit it needs emptying. But the magnets in the arms are not strong enough if they are not close enough to the sensors. So my cardboard solution lasted only one tank.
I ended up getting some flat neodymium magnets (that I scavenged out of a hard drive), and taped to the sensor that had the gap. I wouldn't recommend doing this to both sensors since it would eventually overfill, only one sensor needs to "trip" for the compressor to turn off.
If you answered yes to the first question (the bucket icon is there), then it's most likely the pump not working on the internal reservoir, or something related to that. Can't help you there...
Aug 01, 2009 | Danby Portable Air Conditioner
LEAKS
Try to just fill the tank with water and set it upright on a table. If it leaks, the tank is cracked and needs to be replaced. Order one at kaz.com (search using model#). I have had this tank leak if the special cap is not sitting properly on the base. Make sure that the steam tower is properly locked in place before you place the water tank in the reservoir. The cap on the tank has a spring release that has to be correctly lined up so it only releases water when the water level in the reservoir drops.
May 08, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Danby DPAC9008 Portable Air Conditioner Logo
89 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
