I have a LG WF-T502C fuzzylogic washing machine, Since last few days it does not function in Wash & rinse function. That is the drum tub does not spin clockwise and anticlockwise to full extent and moves very slowly. because of which the clothes cannot be washed or rinsed only spin function is working. Please let me know what can be the problem?
  • 96 Answers
SOURCE: does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Posted on Feb 17, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Posted on Feb 27, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: LG WF-17014PP will not rinse or spin
check the pump, there is probably a small piece of cloth in there like a sock. This happens all the time. When the motor cant turn the other direction, the locking mechanism to the gears wont engage to do the spin cycle. Turn the wsher on its side, the pump should be easy to remove, they are fasten by two long clips. get back with me if this solves the problem
Posted on Jul 01, 2009
  • 1738 Answers
SOURCE: error e1. washing machine will not drain
Two problems. Step one check the drain pump motor, to see if it draining the water out. Next step if the drain pump working you have a clock in the hose between the drain from the tub to the pump. Messy job witht he machine being full of water. I suggest take a small bucket and empty try to empty it out as much as you can.
Posted on Aug 10, 2009
SOURCE: washing machine will not advance through the wash cycle
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Posted on Aug 12, 2009
Sounds like a screw or similar spinning on the spin cycle but can't get the screw out of my fuzzy logic 6.5kg WF-T652 washing machine. Don't want to force it... left or right. ??
watch the videos
Search Results
LG washer - Inner Tub Assembly replacement - Diagnostic & Repair ...
? 1:01
https://www.youtube.com/watch?v=vTKJFuKuUZg
Apr 30, 2015 - Uploaded by ApplianceVideo.com
WT1001CW LG Washer, Visit us at http://www.appliancevideo.com Do-it-yourself diagnostic and repair videos ...
ApplianceJunk.com - LG Top Load Washer Removing Bearing ...
? 4:17
https://www.youtube.com/watch?v=osTIeI7BIMI Dec 15, 2011 - Uploaded by ApplianceJunk
12:56. LG washer - Inner Tub Assembly replacement - Diagnostic & Repair - Duration: 1:01. ApplianceVideo ...
LG Top Load Washer Wash Plate Replacement #AGZ72909702 ...
? 1:39
https://www.youtube.com/watch?v=HBw4DvtrIjs Apr 11, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacing the wash plate on a LG top-loading washing ...
lg wf t652 washing machine remove drum Google Search
Apr 01, 2018 | Washing Machines
I have a lg top loader washing machine model:wf-t1391tp when wasing and rinsing it makes a huge grinding and crackling sound like is going to brake something underneath motor or gearbox.
Check whether the inner rotating drum is contacting the stationary tub.
The other problems that cause this condition is the clutch assembly and or the motor drive system.
Check both assemblies for security and free movement of rotating parts.
Check also the tub supporting dampers for condition.
Feb 23, 2016 | LG Washing Machines
The Tub Clean function never ends
why do you use tub clean function, we have never had the need to reclean the tub having just run hot detergent and water thru it .
Oct 04, 2015 | LG WM Washing Machines
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 17, 2014 | Washing Machines
Lg fuzzy logic manual wf-t552th
I have an LG WF-T502C T552.
It makes a loud squeal noise on the spin cycle.
I am thinking of replacing the belt. Is it possible it could be the bearings or the transmission?
Dec 24, 2013 | Washing Machines
Lost manual to LG washing machine WF-T502c Fuzzy Logic. Just want to know where detergent and softener go?
I do not know this model. However, on other top load LG washers, the powdered detergent goes in a box at the back (top) of the washer, and the fabric softener when diluted gets poured into a spot near the left side of the top of the washer. (The bleach goes near the front of the washer.) For front-loading washers, the detergent and fabric softener are poured into the detergent drawer. The largest compartment is for detergent (wash cycle) and is usually on the left. The smallest compartment is for fabric softener.
Manuals for most LG appliances are available at their site. Start at http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WF-T502C&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WF-T502C&initialTab=documents&targetPage=support-product-profile . The manual is in a DjVu format.
A partial manual is also available here: http://monitor.diplo-best.com/review/LG/WF-T502C . You will need to review the washer or enter a code.
I hope this helps.
Jun 13, 2011 | Washing Machines
My hotpoint wf 000 will wash but wont rinse or spin any suggestions please
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear....
May 05, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have Model WF-S6607?WF-S6607TC. Washing Machine. Loaded the clothes, pressed the POWER button, pressed the WATER LEVEL button, pressed the PROCESS button, and pressed the START/PAUSE button, But few...
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Apr 04, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
