Question about Cell Phones
I am having signal problems with my w810i. The network coverage for my area is good but recently I cant get a signal
  • sijimon Jun 03, 2008
    I am having signal...
  • Anonymous Oct 07, 2008
    signal problem
Iam having the same problem the blonde
Posted on Apr 29, 2008
My phone goes to no network coverage area message without network bar in phone.I had reset to factory settings but its not resolved
there is not enough info to answer this question. is it att/tmob? or is it verizon/sprint? are you in a low signal area? are other people with the same service missing service too? have you recently changed your network settings? if you can answer this for me i can almost certainly tell you whats wrong. TIA
Nov 25, 2015 | Samsung Galaxy Note 2
My mobile has a special problem. The mobile shows a weak signal and sometimes zero signal at my home even though the other nokia mobile signals are very high at my home.(same network other nokia mobile...
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
Oct 31, 2011 | Nokia Cell Phones
I ve a nokia 2730 classic model ...m using airtel service... when i set umts mode there is no network coverage
This probable if your Network does not have 3G/UMTS coverage in that specific area.
I would set your phone so that it will automatically select 2G or 3G network services (e.g. often referred to as Dual-mode) so that if 3G/UMTS is available and has the best coverage/signal, it will automatically be selected. Setting UMTS coverage only would be very restrictive in many area as the signal is usually weaker (especially in Buildings).
Hope it helps!
Sep 24, 2011 | Nokia 2730 Cell Phone
I m new beginner in hardware field guide me how i check signal fault in any mobile guide me sir pl
Hi Buddy,
Signal has a wide range field or area in diagnosing a network problem,it depends the situation on what happen to the phone,weather it was watered damage,drop off the ground or suddenly lost network.
Let's start with the Software Problem
* check your network settings if set to DUAL mode,it means you've 2G or 3G signal,if this mode is far away from your area or out of coverage,you will experience signal dropping, If you are not using 3G signal,better switch to GSM mode and it will stick the signal along your area.
For Hardware Problem
* Base on source and latest issues about signal problem is by replacing 2n2 capacitor,before reheating or removing some main parts like PA (Power Amplifier) and other IC,better focus on this capacitors,Here is a illustration and have a look were it is located
* For no access,change the upper part.
* For no network coverage, change the lower part.
For the meantime,just stick with this solution before doing hardware modification,If you have some questions,don't hesitate to reply,i will give more ideas regarding signal problem.
Thank you for visiting FixYa.
Jul 24, 2011 | Nokia N70 Cellular Phone
Samsung B209 network Problem does not show the network and dose not connect the call
Welcome to FixYa!
It means that there is no network coverage in your area. In most cases, your operator or service provider is the best source of assistance with issues regarding network coverage.
When you are in outdoors, move your position to find a good signal network coverage area. When you are in indoors ( like building, basement and subway station), change your position by small spaces, or move towards a window.
If other mobile phones with the same operator or service provider as yours does not have a signaltoo, then it is conclusive that there is no network coverage.
If other mobile phones with the same operator or service provider as yours does have a signal, then you need to upgrade your cell phones firmware. Unfortunately, there is no upgrade available from Samsung's Website http://www.samsung.com/in/consumer/mobile-phone/mobile-phone/cdma-phone/SCH-B209ZKAREL/index.idx?pagetype=prd_detail&tab=support
Samsung B209 uses CDMA Technology at 800Mhz frequency. If your operator or provider uses GSM Technology, then your phone will not get any signal.
Thank you for using FixYa.
Have a great day.
Jas247
Jun 04, 2011 | Cell Phones
Sir i have Samsung B209 Set this cell does not show network & does not connect the call so plz send me any sol.................
Welcome to FixYa!
If other mobile phones with the same operator or service provider as yours does not have a signal too, then it is conclusive that there is no network coverage.
Have a great day.
Jas247
Sir, recently i buy lephone dual sim u 505 model.I get network coverage problem where other mobile have good signal in the same area..Any idea to solve it.
Hi, I would like to buy Lephone 505U. Can you pl suggest that can support for 3G services and how about network service
Jan 01, 2011 | Cell Phones
No network Coverage
Set your network to the default one. It might just be the area you are in. There might be something interfering with the signal. If you are in an office or other type of building they might have put in a field on the roof so you cant get signal. try walking around
Feb 24, 2009 | Nokia 6263 Cellular Phone
W810no network coverage
well its not your mobile problem sometimes the service providers signal become weak or in simple way dont able to reach to your handset
try to insert sim of other service provider if problem still persist than it must be your handset problem
try to consult your authorised dealer
Dec 07, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Cell Phones Logo
146 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
